详解tcpdump命令的六个常用选项
tcpdump用于捕获和分析网络流量。系统管理员可以使用它来查看实时流量或将输出保存到文件中并在以后进行分析。下面列出6个常用选项。
-D 选项
tcpdump的-D获取接口设备列表。看到此列表后,可以决定要在哪个接口上捕获流量。它还告诉你接口是否已启动、正在运行,以及它是否是环回接口,如下所示:
[root@localhost ~]# tcpdump -D
1.ens160 [Up, Running]
2.lo [Up, Running, Loopback]
3.any (Pseudo-device that captures on all interfaces) [Up, Running]
4.bluetooth-monitor (Bluetooth Linux Monitor) [none]
5.nflog (Linux netfilter log (NFLOG) interface) [none]
6.nfqueue (Linux netfilter queue (NFQUEUE) interface) [none]
7.usbmon0 (All USB buses) [none]
8.usbmon1 (USB bus number 1)
9.usbmon2 (USB bus number 2)
接口
-c [数字]选项
-c 选项捕获 X 个数据包,然后停止。否则,tcpdump 将无限地继续运行。因此,当只想捕获一小部分数据包样本时,可以使用此选项。但是如果接口上没有数据流量,tcpdump 会一直等待。
[root@localhost ~]# tcpdump -c 5 -i any
dropped privs to tcpdump
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
1747.713379 IP localhost.localdomain.ssh > 192.168.43.1.39970: Flags [P.], seq 714380127:714380371, ack 1854022435, win 388, length 244
1747.713785 IP localhost.localdomain.36821 > _gateway.domain: 36365+ PTR? 1.43.168.192.in-addr.arpa. (43)
1747.713939 IP 192.168.43.1.39970 > localhost.localdomain.ssh: Flags [.], ack 244, win 4104, length 0
1747.716053 IP _gateway.domain > localhost.localdomain.36821: 36365 NXDomain 0/1/0 (78)
1747.716543 IP localhost.localdomain.57441 > _gateway.domain: 61445+ PTR? 131.43.168.192.in-addr.arpa. (45)
5 packets captured
9 packets received by filter
0 packets dropped by kernel
接口
-n 选项
-n选项不将IP地址解析为域名,直接以IP地址显示:
[root@localhost ~]# tcpdump -c 5 -i any -n
1738.980756 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 714383039:714383283, ack 1854024303, win 388, length 244
1738.981032 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 244:440, ack 1, win 388, length 196
1738.981096 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 440:604, ack 1, win 388, length 164
1738.981153 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 604:768, ack 1, win 388, length 164
1738.981208 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 768:932, ack 1, win 388, length 164
5 packets captured
5 packets received by filter
接口
-s 选项
带有-sXXX 的 tcpdump 可帮助你控制捕获数据包的大小。在上一个输出的第三行中,可以看到它表示捕获大小 262144 字节。可以使用-s选项更改捕获数据大小。如果你只想检查数据包标头,则可以使用较小的大小进行捕获:
[root@localhost ~]# tcpdump -c 5 -i any -n -s64
listening on any, link-type LINUX_SLL (Linux cooked), capture size 64 bytes
1744.437891 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 714405271:714405515, ack 1854033767, win 388, length 244
1744.438153 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 244:440, ack 1, win 388, length 196
1744.438220 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 440:604, ack 1, win 388, length 164
1744.438301 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 604:768, ack 1, win 388, length 164
1744.438361 IP 192.168.43.131.ssh > 192.168.43.1.39970: Flags [P.], seq 768:932, ack 1, win 388, length 164
5 packets captured
接口
端口捕获
tcpdump 允许你指定使用某个端口作为源或目标的网络数据包。例如,要捕获 DNS 流量,你可以使用端口 53。可以在 port选项前加上 src/dst。如 src port 53  dst port 53 并进一步过滤它。
[root@localhost ~]# tcpdump -i any port 53 -n
1748.158109 IP 192.168.43.131.47054 > 192.168.43.2.domain: 58704+ A? www.baidu.com. (31)
1748.158152 IP 192.168.43.131.47054 > 192.168.43.2.domain: 60504+ AAAA? www.baidu.com. (31)
1748.159180 IP 192.168.43.2.domain > 192.168.43.131.47054: 60504 1/1/0 CNAME www.a.shifen.com. (115)
1748.162018 IP 192.168.43.2.domain > 192.168.43.131.47054: 58704 3/0/0 CNAME www.a.shifen.com., A 180.101.49.11, A 180.101.49.12 (90)
接口
 下面只获取源端口为53的数据包,其中-nn选项表示不解析IP地址和端口:
[root@localhost ~]# tcpdump -c 5 -i any src port 53 -nn -s64
1841.604216 IP 192.168.43.2.53 > 192.168.43.131.48245: 50676[|domain]
1841.606390 IP 192.168.43.2.53 > 192.168.43.131.48245: 19947[|domain]
1841.631001 IP 192.168.43.2.53 > 192.168.43.131.54536: 31350 NXDomain[|domain]
1846.110591 IP 192.168.43.2.53 > 192.168.43.131.42379: 17512[|domain]
1846.110603 IP 192.168.43.2.53 > 192.168.43.131.42379: 40562[|domain]
5 packets captured
接口
下面只获取目的端口为53的数据包:
[root@localhost ~]# tcpdump -c 5 -i any dst port 53 -nn -s64
1822.568585 IP 192.168.43.131.49444 > 192.168.43.2.53: 27625+[|domain]
1822.568623 IP 192.168.43.131.49444 > 192.168.43.2.53: 42481+[|domain]
1822.595257 IP 192.168.43.131.45790 > 192.168.43.2.53: 28116+[|domain]
1823.850730 IP 192.168.43.131.34861 > 192.168.43.2.53: 23444+[|domain]
1823.850762 IP 192.168.43.131.34861 > 192.168.43.2.53: 23964+[|domain]
5 packets captured
接口
-w 选项
如果要将 tcpdump 的输出写入文件,请使用选项-w选项写入文件。如果想查看写了多少数据包,可以加-v选项。
[root@localhost ~]# tcpdump -c 4 -i any port 53 -nn -w dns.pcap -v
tcpdump: listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
4 packets captured
6 packets received by filter
接口
总结
tcpdump 用于收集有关网络流量数据的出色工具。数据包捕获为故障排除和安全分析提供了有用的信息。
原文标题:tcpdump 命令的常用选项
文章出处:【微信公众号:Linux爱好者】欢迎添加关注!文章转载请注明出处。
审核编辑:汤梓红
