HomeKit-Bridge插件
消耗积分:0 | 格式:zip | 大小:89.96 MB | 2022-04-20
分享资料个
授权协议 Unlicense License
开发语言 JavaScript
操作系统 跨平台
软件类型 开源软件
所属分类 其他开源物联网
软件简介
HomeKit Bridge
This plugin for the Indigo Domotics home automation platform that publishes Indigo devices and action groups to Homebridge so that you can use your Indigo devices and actions in HomeKit and with Siri.
Supported HomeKit Devices
The following list represents all of the HomeKit devices (which is 99% of all of them) that are supported via this plugin. Their ability to work with your Indigo devices depends on the type of device you are using. At this point do not plan on custom plugin devices that do not use standard Indigo device types (switches, dimmers, sensors, thermostats, irrigation, fans, etc) to work as very little custom plugin mappings have been built into this plugin. That being said, many users find that using a wrapper from another plugin, such as Masquerade or Device Extensions, has aided them in getting their custom device to work.
Known Issues
You should always refer to the Git issues section to see what the outstanding problems are before reporting a new issue. Reporting issues via Git is the preferred method of making sure your issue gets resolved as it's easy to get lost in the Indigo forums.
The biggest current issue is only for new installations, please read the quick start guide in the Wiki to familiarize yourself with that issue that requests that you disable Homebridge Buddy prior to installing HomeKit Bridge (you can re-enable it after the initial installation). Since this is a very small audience of people it may not get addressed as it's be very difficult to reproduce the problem.
评论(0)
发评论
下载排行榜
