如何使用Arduino控制大型线性执行器
本文将向你展示如何使用 Arduino 和两个按钮对大型线性执行器进行基本的手动控制。在第一组代码中,第一个按钮伸出执行器,第二个按钮缩回执行器。在第二组代码中,两个按钮将线性执行器移动到预设位置。
  大型线性致动器传统上具有五根导线。两根线用于为电机供电,三根线连接到内部电位计以读取位置。这两个继电器用于切换电机的正负电源,以确定活塞的行进方向。代码的第一位不使用这个,第二个使用这个来达到目标​​位置。让我们开始吧。
  第 1 步:接线
Arduino
  第 2 步:代码 1 - 手动控制
  此部分代码显示了如何使用 Arduino 和两个按钮对大型线性执行器进行基本手动控制。第一个按钮伸出致动器,第二个按钮缩回致动器。
  const int button1Pin = 2; // the number of the pushbutton1 pin
  const int button2Pin = 4; // the number of the pushbutton2 pin
  const int relay1Pin = 7; // the number of the Realy1 pin
  const int relay2Pin = 8; // the number of the Relay2 pin
  // variables will change:
  int button1State = 0; // variable for reading the pushbutton status
  int button2State = 0; // variable for reading the pushbutton status
  const int sensorPin = 0; // select the input pin for the potentiometer
  int sensorValue = 0; // variable to store the value coming from the sensor
  void setup() {
  //start serial connection
  Serial.begin(9600);
  // initialize the pushbutton pin as an input:
  pinMode(button1Pin, INPUT);
  pinMode(button2Pin, INPUT);
  // initialize the relay pin as an output:
  pinMode(relay1Pin, OUTPUT);
  pinMode(relay2Pin, OUTPUT);
  void loop(){
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  //print out the value of the pushbutton
  Serial.println(sensorValue);
  // read the state of the pushbutton values:
  button1State = digitalRead(button1Pin);
  button2State = digitalRead(button2Pin);
  // check if the pushbutton1 is pressed.
  // if it is, the buttonState is HIGH:
  // we also ensure tha the other button is not pushed to avoid conflict
  if (button1State == HIGH && button2State == LOW) {
  // turn relay1 on:
  digitalWrite(relay1Pin, HIGH);
  // When we let go of the button, turn off the relay
  else if (digitalRead(relay1Pin) == HIGH) {
  // turn relay1 off:
  digitalWrite(relay1Pin, LOW);
  // repeat the same procedure for the second pushbutton
  if (button1State == LOW && button2State == HIGH) {
  // turn relay2 on:
  digitalWrite(relay2Pin, HIGH);
  else if (digitalRead(relay2Pin) == HIGH) {
  // turn relay2 off:
  digitalWrite(relay2Pin, LOW);
  第 3 步:代码 2 - 使用位置反馈预设位置
  此部分代码显示了如何使用 Arduino 和两个按钮对大型线性执行器进行基本控制,每个按钮预设到一个位置。
  int goalPosition = 350;
  int CurrentPosition = 0;
  boolean Extending = false;
  boolean Retracting = false;
  void setup() {
  Serial.begin(9600);
  //preset the relays to LOW
  void loop(){
  CurrentPosition = analogRead(sensorPin);
  // print the results to the serial monitor:
  Serial.print(“Current = ” );
  Serial.print(CurrentPosition);
  Serial.print(“\t Goal = ”);
  Serial.println(goalPosition);
  if (button1State == HIGH) {
  // set new goal position
  goalPosition = 300;
  if (goalPosition 》 CurrentPosition) {
  Retracting = false;
  Extending = true;
  Serial.println(“Extending”);
  else if (goalPosition 《 CurrentPosition) {
  Retracting = true;
  Extending = false;
  Serial.println(“Retracting”);
  if (button2State == HIGH) {
  goalPosition = 500;
  Retracting = false;
  Extending = true;
  Retracting = true;
  Extending = false;
  if (Extending = true && CurrentPosition 》 goalPosition) {
  //we have reached our goal, shut the relay off
  Serial.println(“IDLE”);
  if (Retracting = true && CurrentPosition 《 goalPosition){
  以上就是该项目所需的全部功能代码,到这一步就可以验收了。
  第4步:拓展
  在可以控制大型线性执行器之后,你打算用它做什么?您可以制作一张可以变形的桌子,以变换坐姿或站姿。同时你还可以使用一些光传感器,制作一个跟踪太阳的太阳能电池板。
