WLAN网络优化故障案例
现象描述
如下图所示,STA不关联或不漫游至就近的AP 2,而是主动关联了AP 13。
WLAN
02
原因分析
STA使用的某网卡,仅支持2.4G bgn协议,相对于13信道,更偏爱1~11信道,即在STA同时收到13信道和其它信道相同的SSID时,更易连入非13信道的AP。
03
操作步骤
1. 查看AP 2和AP 13信道及功率情况。
a)执行命令display radio查看AP的发射功率和信道。
[AC] displayradio ap-id 2
AP IDName    RfID  Band   Type   ST  CH/BW     CE/ME  STA    CU    WM
2     xxxx     0     2.4G   11ax    on  13/20M     20/29  2      16%   normal
2     xxxx     1     5G     11ax    on 52/40M+   28/30   1     1%    normal
Total:2
[AC] displayradio ap-id 13
13    xxxx     0     2.4G   11ax   on  9/20M      12/29   0     18%   normal
13    xxxx     1     5G     11ax    on 44/40M+    28/30   0     2%    normal
b)执行命令display station sta-mac查看终端上报的AP功率情况,确认在STA上接收到就近AP(AP 2)的场强比接收到的AP 13的场强更强。
[AC-wlan-view]display station neighbor sta-mac sta-mac
DeviceMAC         Device ID   Device Name        Radio ID  Channel Probe info(RSSI/HHSS)   11kinfo[RCPI/RSNI/HHSS]
xxxx-xxxx-0410     13         AP13               0         9        -67/2035                180/ - /2030
xxxx-xxxx-0490     2          AP2                0         13       -45/2047                184/ - /2009
 c)执行命令display ap neighbor ap-id 13查看AP 13的邻居信息,确认AP 2是AP 13的邻居AP且相比其他邻居AP的场强更强。
[AC-wlan-view]display ap neighbor ap-id 13
Radio: RadioID of AP
In controlAP:
Radio  AP ID AP name    Channel  Received RSSI(dbm)  RSSI pathloss(db)  RSRP pathloss(db)  Last Update Time
0      12    AP12       13       -76                 105                108                2021-06-27/2008
0      2     AP2        13       -57                 86                 87                 2021-06-27/2008
2. 检查AP对终端的漫游引导动作。a)查看智能漫游配置,AC上正常配置了智能漫游功能。
[AC-wlan-view]rrm-profile name default
[AC-wlan-rrm-prof-default]display this
smart-roamroam-threshold snr 35
smart-roamquick-kickoff-threshold snr 10
sta-load-balancedynamic disable
b)分别在AP和AC上查看STA的漫游标志
# 在AC上查看终端信息,结果显示为粘性终端。
[AC] displaystation sta-mac sta-mac
Autonavigationroaming optimization support   : No
Available forroaming                         : Yes
Stickystation or not                         : Yes
Aimlessroaming support in sticky state       :Yes
Stationdevice type                           : -
# 在AC上查看终端迁移记录,可以观察到终端没有被迁移的目标AP,也就是终端被盲切了,而且终端最终还是关联了AP 13,也就是终端未能迁移成功。
[AC-wlan-view]display station steer-history | include sta-mac
S/T/A:Source/Target/Actual
Flag:V[Voice/Video/ActiveSTA]
BTM successtimes/BTM total times:441/919
Deauthsuccess times/Deauth total times:0/0
Time                    Sta             Device(S/T/A)   Radio(S/T/A) Rssi(S/T/A)   Reason       Move-mode  BTM_CODE Flag  Result
2021-06-27/1907     sta-mac         13/-/13         0/-/0         -71/-/-71     Sticky       BTM        -         -    Not Move
2021-06-27/1900     sta-mac         13/-/13         0/-/0         -71/-/-72     Sticky       BTM        -         -    Not Move
# 在AP执行命令displayumac station sticky-table,发现该终端被标志为粘性终端。
[AP13-diagnose]display umac station sticky-table
STA MAC            Frequency       SNR      State       SSID
sta-mac              2.4G            29         sticky      office
结合上述信息分析可知,STA被盲切,但STA并未关联就近的AP 2。按正常情况,即使终端首次接入网络不关联AP 2,也会被智能漫游功能迁移到AP 2上,而实际STA并未及时关联至AP 2,而是关联到了远端的AP 13。
3. 尝试将AP 2(信道13 )与AP 13(信道9)进行信道调换测试,确认STA对信道是否有特殊偏爱。
[AC] wlan
[AC-wlan-view]ap-id 2
[AC-wlan-ap-2]radio 0
[AC-wlan-radio-2/0]calibrate auto-channel-select disable
[AC-wlan-radio-2/0]channel 20mhz 9
Warning: Thisaction may cause service interruption. Continue?[Y/N]y
4. 将2.4G射频的调优信道集设置为1,6,11,进行调优之后测试,该STA接入和漫游均正常。[AC]wlan [AC-wlan-view]regulatory-domain-profile name default[AC-wlan-regulate-domain-default]dca-channel 2.4g channel-set 1,6,11
审核编辑 :李倩
