美信电子推出MAX14566AE、MAX14566BE和MAX14566E紧凑型交换机支
新品快讯
29人已加入
Compact charger identification switch supports USB, Apple, and CCSA YD/T charging
Maxim's new charger identification switch provides a complete solution for supporting major charging standards, thus minimizing software overhead.
SUNNYVALE, CA—January 11, 2011—Maxim Integrated Products (NASDAQ: MXIM) introduces the MAX14566E, a USB charger identification solution that supports the charging of portable devices from notebook computers, even when the computer is in sleep or hibernate mode. This switch supports the USB Battery Charging Specification, Revision 1.1, as well as the CCSA YD/T 1591-2006 standard for the Chinese market. The compact (2mm x 2mm) MAX14566E saves board space and reduces software overhead as compared to discrete implementations.
The MAX14566E automatically identifies the type of portable device connected using its charger identification circuit. Requiring no external software, this circuit allows a host USB port to support USB Battery Charging Specification, Revision 1.1-compliant devices with shorted D+/D- detection, as well as Apple® devices by using a resistor bias. The MAX14566E also features a high-performance, Hi-Speed USB switch with low 4pF (typ) on-capacitance and low 4Ω (typ) on-resistance.
Operating over the -40°C to +85°C extended temperature range, the MAX14566E is available in a 2mm x 2mm, 8-pin TDFN package. Prices start at $1.55 (1000-up, FOB USA). An evaluation kit is available to speed designs.
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells high-performance semiconductor products. The Company was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, it has developed over 6400 products serving the industrial, communications, consumer, and computing markets.
