基于库函数的SD卡硬件驱动层代码实现方案
嵌入式开发中经常会用到对外部SD卡进行相关的读写操作。下图是CPU硬件连接示意图
SD卡CPU硬件连接
   引脚配置瑞如下:
void SD_LowLevel_DeInit(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  /*!< Disable SDIO Clock */
  SDIO_ClockCmd(DISABLE);
  /*!< Set Power State to OFF */
  SDIO_SetPowerState(SDIO_PowerState_OFF);
  /*!< DeInitializes the SDIO peripheral */
  SDIO_DeInit();
  /*!< Disable the SDIO AHB Clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_SDIO, DISABLE);
  /*!< Configure PC.08, PC.09, PC.10, PC.11, PC.12 pin: D0, D1, D2, D3, CLK pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /*!< Configure PD.02 CMD line */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
DMA部分配置如下:
void SD_LowLevel_DMA_TxConfig(uint32_t *BufferSRC, uint32_t BufferSize)
  DMA_InitTypeDef DMA_InitStructure;
  DMA_ClearFlag(SD_SDIO_DMA_FLAG_TC | SD_SDIO_DMA_FLAG_TE | SD_SDIO_DMA_FLAG_HT | SD_SDIO_DMA_FLAG_GL);
  /*!< DMA2 Channel4 disable */
  DMA_Cmd(SD_SDIO_DMA_CHANNEL, DISABLE);
  /*!< SDIO DMA CHANNEL Config */
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SDIO_FIFO_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)BufferSRC;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_BufferSize = BufferSize / 4;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(SD_SDIO_DMA_CHANNEL, &DMA_InitStructure);
  DMA_ITConfig(SD_SDIO_DMA_CHANNEL, DMA_IT_TC, ENABLE);
  /*!< SDIO DMA CHANNEL enable */
  DMA_Cmd(SD_SDIO_DMA_CHANNEL, ENABLE);
void SD_LowLevel_DMA_RxConfig(uint32_t *BufferDST, uint32_t BufferSize)
  /*!< SDIO DMA CHANNEL disable */
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)BufferDST;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
uint32_t SD_DMAEndOfTransferStatus(void)
  return (uint32_t)DMA_GetFlagStatus(DMA2_FLAG_TC4);
SDIO函数中断部分
///sd卡状态判断
void SDCARD_Config(void)
	SD_Error Status = SD_OK;
	Status = SD_Init();	        //初始化SDIO
	if (Status != SD_OK)
		Display_ErrorWithoutSD((u8 *)"No_SDCard");
	SDCARD_NVIC_Config();
//中断配置 部分
void SDCARD_NVIC_Config(void)
	NVIC_InitTypeDef NVIC_InitStructure;
	/* Configure the NVIC Preemption Priority Bits */
	NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
	NVIC_InitStructure.NVIC_IRQChannel = SDIO_IRQn;
	NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
	NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
	NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
	NVIC_Init(&NVIC_InitStructure);
中断函数
void SDIO_IRQHandler(void)
	/* Process All SDIO Interrupt Sources */
	SD_ProcessIRQSrc();
审核编辑:符乾江
