1.简介
龙迅LT86102SXE是Lontium的第四代2端口HDMI / DVI分配器,可以将一个HDMI / DVI信号转发到2个HDMI / DVI信号集,最多支持2个不同的HDMI / DVI接收/显示端子。它基于ClearEDGETM技术,每个通道支持高达3.4Gbps的数据速率,符合HDMI 1.4 / 2.0&DVI 1.0规范。
2.功能
•符合HDMI 1.4 / 2.0&DVI 1.0规范
•支持高达3.4Gbps数据速率的3D视频格式和4Kx2K扩展分辨率格式,以及60Hz YCbCr 4:2:0格式的4Kx2K
•自适应均衡和去加重以补偿长电缆损耗
•ODT和校准
•符合HDCP 1.4规范的集成HDCP转发器引擎
•完全由硬件控制或可选的软件控制的HDCP操作
•预编程的HDCP密钥集或外部EEPROM存储的密钥集
•集成CEC控制器
•集成EDID影子RAM和嵌入式EDID
•耐5V的DDC接口
•1个HDMI / DVI输入端口,最多2个HDMI / DVI输出端口
•无限级联,用于更多输出端口或信号转发
•80针PQFP封装
3.应用
•多显示器/电视支持
•HDMI / DVI信号分离/重复
1. Description
LT86102SXE is Lontium’s 4rd generation 2-port HDMI/DVI splitter which can repeat one HDMI/DVI signal to 2 HDMI/DVI signal sets, support up to 2 different HDMI/DVI receiving/display terminals. BaSED on ClearEdgeTM Technology, it supports up to 3.4Gbps data rate per Channel, compliant with the HDMI 1.4/2.0&DVI 1.0 SPECifications.
2. Features
• HDMI 1.4/2.0&DVI 1.0 specifications compliant
• Support 3D video formats and 4Kx2K extended resolution formats up to 3.4Gbps data rate and 4Kx2K @60Hz YCbCr 4:2:0 format
• Adaptive equalization and de-emphasis to compensate long cable losses
• ODTs and calibration
• Integrated HDCP repeater engine compliant with HDCP 1.4 specification
• Fully hardware-controlled or optional software-controlled HDCP operations
• Pre-programmed HDCP key sets or external EEPROM stored key sets
• Integrated CEC controller
• Integrated EDID shadow RAM and embedded EDID
• 5V-tolerant DDC interfaces
• 1 HDMI/DVI input port, up to 2 HDMI/DVI output ports
• Unlimited cascADIng for more output ports or signal repeating
• 80-pin PQFP package
3.APPlications
• Multiple display/TV support
• HDMI/DVI signal splitting/repeating
