mongols C++服务器基础设施
消耗积分:0 | 格式:zip | 大小:4.73 MB | 2022-06-23
陈丽
分享资料个
授权协议 MPL-2.0
开发语言 C/C++
操作系统 Linux
软件类型 开源软件
软件简介
mongols 是一个 C++ 库。
依赖:
  • linux
  • pcre-devel
  • hiredis-devel
  • zlib-devel
  • openssl-devel
  • curl-devel
sudo yum install pcre-devel zlib-devel openssl-devel hiredis-devel libcurl-devel
或者:
sudo apt-get install libpcre3-dev zlib1g-dev libssl-dev libhiredis-dev libcurl4-openssl-dev
特性:
epoll or epoll + multi-threading
  • tcp sever
  • http server
  • websocket server
  • web server
  • leveldb server
  • lua server
  • sqlite server
  • utils
安装:
make clean && make -j2 && sudo make install && sudo ldconfig
使用:
pkg-config --libs --cflags mongols
例子:
#include#include#include#include#include#include#include#include/*
//websocket server
int main(int,char**){
int port=9090;
const char* ;
mongols::ws_server server(host,port,5000,2048,4);
auto f=[](const std::string& input
            , bool& keepalive
            , bool& send_to_other
            , mongols::tcp_server::client_t& client
            , mongols::tcp_server::filter_handler_function& send_to_other_filter){
keepalive = KEEPALIVE_CONNECTION;
send_to_other=true;
if(){
keepalive = CLOSE_CONNECTION;
send_to_other = false;
server.run(f);
//server.run();
//tcp server or tcp multi-threading server
 , bool & keepalive
keepalive= KEEPALIVE_CONNECTION;
send_to_other=true;
return input;
int port=9090;
const char* ;
//mongols::tcp_threading_server
mongols::tcp_server
server(host,port);
server.run(f);
//http server or multi-threading server
auto f=[](const mongols::request&){
return true;
auto g=[](const mongols::request& req,mongols::response& res){
//std::unordered_map::const_iterator i;
//if((i=req.session.find("test"))!=req.session.end()){
//long test=std::stol(i->second)+1;
//res.content=std::to_string(test);
//res.session["test"]=res.content;
//}else{
//res.content=std::to_string(0);;
res.content=std::move("hello,world");
res.status=200;
int port=9090;
const char* ;
mongols::http_server
//server(host,port,5000,1024,4);
server(host,port);
server.set_enable_session(false);
server.set_enable_cache(false);
server.run(f,g);
//web server or multi-threading server
if(req.&&req.uri.find("..")==std::string::npos){
return true;
return false;
int port=9090;
const char* ;
mongols::web_server
server(host,port);
server.set_root_path("html");
server.set_mime_type_file("mime.conf");
server.set_list_directory(true);
server.run(f);
//leveldb_server or multi-threading server
int port=9090;
const char* ;
mongols::leveldb_server
server(host,port);
server.run("html/leveldb");
压力测试:
[centos@localhost demo]$ uname -a
Linux localhost 3.10.0-862.9.1.el7.x86_64 #1 SMP Mon Jul 16 16:29:36 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
[centos@localhost demo]$ cat /proc/cpuinfo| grep "processor"| wc -l
4
[centos@localhost demo]$ cat /proc/cpuinfo| grep "cpu cores"| uniq
cpu cores: 2
[centos@localhost demo]$ cat /proc/cpuinfo| grep "physical id"| sort| uniq| wc -l
1
ab -c1000 -n100000 http://127.0.0.1:9090/
Server Software:        mongols/0.9.0
Server Hostname:        127.0.0.1
Server Port:            9090
Document Path:          /
Document Length:        13 bytes
Concurrency Level:      1000
Time taken for tests:   8.180 seconds
Complete requests:      100000
Failed requests:        0
Write errors:           0
Keep-Alive requests:    0
Total transferred:      13300000 bytes
HTML transferred:       1300000 bytes
Requests per second:    12225.00 [#/sec] (mean)
Time per request:       81.800 [ms] (mean)
Time per request:       0.082 [ms] (mean, across all concurrent requests)
Transfer rate:          1587.82 [Kbytes/sec] received
Connection Times (ms)
              min  mean[+/-sd] median   max
Connect:        0   66 263.3      7    3020
Processing:     2   11  11.9      9     831
Waiting:        0    8  11.5      7     829
Total:          6   77 265.8     16    3033
Percentage of the requests served within a certain time (ms)
  50%     16
  66%     20
  75%     22
  80%     23
  90%     29
  95%   1017
  98%   1025
  99%   1030
 100%   3033 (longest request)
ab -kc1000 -n100000 -H'Connection: keep-alive' http://127.0.0.1:9090/
Server Port:            9090
Document Path:          /
Time taken for tests:   1.935 seconds
Failed requests:        0
Write errors:           0
Keep-Alive requests:    100000
Total transferred:      13800000 bytes
Requests per second:    51671.74 [#/sec] (mean)
Time per request:       19.353 [ms] (mean)
Time per request:       0.019 [ms] (mean, across all concurrent requests)
Transfer rate:          6963.57 [Kbytes/sec] received
Connect:        0    0   3.2      0      48
Processing:     8   19   1.4     18      48
Waiting:        0   19   1.4     18      25
Total:          8   19   3.1     18      64
  50%     18
  66%     19
  75%     19
  80%     19
  90%     20
  95%     21
  98%     23
  99%     28
 100%     64 (longest request)
评论(0)
发评论
下载排行榜
