EWB系列---列车车载电源介绍
1.2w人已加入
EWB系列---列车车载电源
车载电源
车载电源
Version C  (100x70x20mm)  Version K
车载电源
Version S (100x41x17mm)
EWB系列电源特点:
陶瓷基板PCB
丝印电阻
效率高达94.5%
工作温度范围:-40℃~+85℃
EMC/EMV符合EN55155,EN50121-3-2
防火等级:UL94-V0
RoHS认证
SMT - on ceramic technology
Metal case in different shapes
100% burn-in & parameter  test
Assembling according to  ANSI/IPC-A-610
Laser trimmed thick film resistors
High efficiency up to 94,5%
Short circuit proof
Extended temperature range: -40°C to +85°C
Designed to meet EN50155 and EN50121-3-2
Integrated hold-up-time
Integrated Input filter
Integrated reverse polarity protection
OVP: Burst EN61000-4-4   2kV (5/50ns,      5kHz)
Surge EN61000-4-5   2kV Line-Earth;1kV Line-Line
RoHS compliant
UL94V-0 compliant
Examples of Part Number
Model Input Output Efficiency Connection
EWB150-24-12-C 14V
 to
34V
12V /
12,5A
91% Cable
EWB150-24-12-K Connector
EWB150-24-12-S Connector
EWB150-24-24-C 14V
 to
34V
24V /
10A
93% Cable
EWB150-24-24-K Connector
EWB150-24-24-S Connector
EWB150-36-28-C 21V
 to
51V
18V /
8,33A
93% Cable
EWB150-36-18-K Connector
EWB150-36-18-S Connector
EWB150-110-24-C 66V
to
154V
24V /
6,25A
94% Cable
EWB150-110-24-K Connector
EWB150-110-24-S Connector
General electrical specifications (Note1)
INPUT Nominal
input voltage
24V DC 36V DC 110V DC
Input voltage range 14V to
34V DC
21V to 51V DC 66V to
154V DC
Low side turn off / on 12V /
13,5V
18V / 20V 58V /
64V
High side
 turn off / on
37 / 35V 54V / 53V 165V /
160V
Max. input
voltage
± 80V
DC
± 100V DC ± 200V
DC
No load input current 50 mA 50 mA 50 mA
Nominal
 input current
6,87 A 4,53 A 1,46 A
Hold-up-time (Class S2) - - >10ms
for Pout<100W
Efficiency 90,6% to 92,6% 91,8% to 93,5% 92,3% to 94,5%
OUTPUT Output
voltage
12V 15V 18V 24V
Output
current
12,5A 10A 8,33A 6,25A
Output voltage accuracy ± 1%
Regulation
line³ (Note 2)
± 1%
Regulation
load (Note 3)
± 2%
Ripple
 (20 MHz)
< 80 mVpp < 100 mVpp < 125 mVpp < 150 mVpp
PROTECTION Short circuit
protection
current limiting
Overload protection Thermal shutdown @ ca 120°C
Reverse polarity See max. input voltage
ISOLATION Isolation I/O 2500V DC
Isolation I/ case 1500V DC
Isolation O/case 1000V DC
Environment Operating
temperature
-40 to +85°C
(Note 4) Storage temperature -55 to +125°C
Other Temperature
coefficient
0,02%/°C
Notes:
1. Typical specifications at Ta = 25°C under normal line voltage and full load conditions, unless otherwise noted
2. Ui min to Ui max
3. Imin = 0 to Imax = 100%
4. Case temperature
机械结构:
Version C
车载电源
all dimensions in mm
tolerance: ±1mm
Red: 200mm / 0,75mm² + Input
Black: 200mm / 0,75mm² - Input
Orange: 2 x 200mm / 0,75mm² + Output
Blue: 2 x 200mm / 0,75mm² - Output
Version K:
车载电源
tolerance: ±0,5mm
Version S:
车载电源
tolerance: ±0,5mm
原理框图:
车载电源
EMI/RFI:  EWB150-XX-XX
Radiated
车载电源
Conducted
车载电源
效率
EWB150-110-12
车载电源
EWB150-110-15
车载电源
EWB150-110-18
车载电源
EWB150-110-24
车载电源
电源输出功率与温度曲线
车载电源
电源输出纹波@额定输入,额定负载
EWB150-XX-12
车载电源
EWB150-XX-15
车载电源
EWB150-XX-18
车载电源
EWB150-XX-24
车载电源
编辑:黄飞
