HAB boot的启动流程与实现步骤
1.2w人已加入
问题简介
在《深扒HAB boot 启动安全性》中,小编介绍了HAB boot的启动流程(如图1所示),其中的1、2、3验证步骤本质上就是验签过程。
Boot图1
验签过程在公钥可信的情况下,可用于检测数据的完整性(Integrity),身份认证(Authentication)和不可否认(Non-repudiation/Undeniable),而hab4_pki_tree.sh和hab4_pki_tree.bat脚本又保证生成的公钥与私钥对,证书是可信的,所以能“完美闭环”,使得HAB boot的安全性得到保证。
在应用手册AN12079中,介绍了实现HAB boot的步骤,大致可分为:
  • 生成证书与密钥
  • 对bootable image进行签名
  • 打包签名后的bootable image生成SB文件
签名过程需借助elftosb工具和BD文件,其中BD文件包含了实现签名的命令,
options {
    flags = 0x08;
    startAddress = 0x60000000;
    ivtOffset = 0x1000;
    initialLoadSize = 0x2000;
    entryPointAddress = 0x60004645;
sources {
    elfFile = extern(0);
constants {
    SEC_CSF_HEADER              = 20;
    SEC_CSF_INSTALL_SRK         = 21;
    SEC_CSF_INSTALL_CSFK        = 22;
    SEC_CSF_INSTALL_NOCAK       = 23;
    SEC_CSF_AUTHENTICATE_CSF    = 24;
    SEC_CSF_INSTALL_KEY         = 25;
    SEC_CSF_AUTHENTICATE_DATA   = 26;
    SEC_CSF_INSTALL_SECRET_KEY  = 27;
    SEC_CSF_DECRYPT_DATA        = 28;
    SEC_NOP                     = 29;
    SEC_SET_MID                 = 30;
    SEC_SET_ENGINE              = 31;
    SEC_INIT                    = 32;
    SEC_UNLOCK                  = 33;
section (SEC_CSF_HEADER;
    Header_Version="4.2",
    Header_HashAlgorithm="sha256",
    Header_Engine="DCP",
    Header_EngineConfiguration=0,
    Header_CertificateFormat="x509",
    Header_SignatureFormat="CMS"
section (SEC_CSF_INSTALL_SRK;
    InstallSRK_Table="............Users
xa07025secure_provisioning000000000000000000000000000gen_hab_certsSRK_hash.bin",
    InstallSRK_SourceIndex=0
section (SEC_CSF_INSTALL_CSFK;
    InstallCSFK_File="............Users
xa07025secure_provisioning000000000000000000000000000crtsCSF1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallCSFK_CertificateFormat="x509"
section (SEC_CSF_AUTHENTICATE_CSF)
section (SEC_CSF_INSTALL_KEY;
    InstallKey_File="............Users
xa07025secure_provisioning000000000000000000000000000crtsIMG1_1_sha256_2048_65537_v3_usr_crt.pem",
    InstallKey_VerificationIndex=0,
    InstallKey_TargetIndex=2)
section (SEC_CSF_AUTHENTICATE_DATA;
    AuthenticateData_VerificationIndex=2,
    AuthenticateData_Engine="DCP",
    AuthenticateData_EngineConfiguration=0)
section (SEC_SET_ENGINE;
    SetEngine_HashAlgorithm = "sha256",
    SetEngine_Engine = "DCP",
    SetEngine_EngineConfiguration = "0")
section (SEC_UNLOCK;
    Unlock_Engine = "SNVS",
    Unlock_features = "ZMK WRITE"
在运行类似下面的命令后,bootable image的组成会有如图2所示的变化。
./elftosb.exe -f imx -V -c imx-flexspinor-normal-signed.bd -o ivt_application_signed.bin led_demo_evk_flexspi_nor_0x60002000.srec
Boot图2
在仔细查看BD文件后,我们会发现里面有加载SRK公钥,IMG1和CSF1证书等命令,却没有了关于私钥的相关命令?那么私钥是如何参与bootable image的签名过程的呢?
私钥在哪里?
图3的左边部分表示elftosb.exe执行如下命令后,首先application和CSF(Command Sequence File)会进行Hash运算生成摘要,跟着私钥会对其加密生成签名。
Boot图3
那么elftosb.exe是从哪里加载私钥的呢?答案就是在与证书所处文件夹crts同一层目录下的keys文件夹中,且elftosb.exe会加载与BD文件中的公钥证书所对应的私钥文件,比如上述BD文件的公钥证书是CSF1_1_sha256_2048_65537_v3_usr_crt.pem和IMG1_1_sha256_2048_65537_v3_usr_crt.pem,那么对应的私钥文件就是CSF1_1_sha256_2048_65537_v3_usr_key.pem和IMG1_1_sha256_2048_65537_v3_usr_key.pem,当然,你也可以移除keys文件夹来进行验证。
Boot图4
  审核编辑:汤梓红
