ArkUI如何自定义弹窗(eTS)
自定义弹窗其实也是比较简单的,通过CustomDialogController类就可以显示自定义弹窗。
接下来我们通过代码来看一下
大家也都用过@Entry,@Component等弹窗的话,只要用@CustomDialog就可以
先来预览一下我实现的效果:
Component
import
CustomDialogExample
from
'./customdialog'
Entry
Component
struct
Index
// 方式一:使用箭头函数
onAccept
console
info
'确定'
this
dialogController
close
dialogController
new
builder
CustomDialogExample
cancel
this
onCancel
confirm
this
onAccept
alignment
DialogAlignment
Center
cancel
console
log
"cancel"
// 点击蒙层的回调
autoCancel
true
// 允许点击蒙层关闭弹窗
customStyle
false
// 使用自定义样式
onCancel
console
info
'取消'
build
Column
Button
'    自定义弹窗'
onClick
//打开弹窗
this
dialogController
open
width
"100%"
height
"100%"
alignItems
HorizontalAlign
Center
justifyContent
FlexAlign
Center
 * Copyright (c) 2021 JianGuo Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *    http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
//通过CustomDialogController类显示自定义弹窗。
CustomDialog
struct
CustomDialogExample
controller
cancel
void
confirm
void
build
Flex
justifyContent
FlexAlign
Center
alignItems
ItemAlign
Center
alignContent
FlexAlign
Center
Button
'取消'
fontSize
36
onClick
//方式二:关闭弹窗
this
controller
close
this
cancel
backgroundColor
0xffffff
fontColor
Color
Black
Button
'确定'
fontSize
36
onClick
//            this.controller.close()
this
confirm
backgroundColor
0xffffff
fontColor
Color
Red
margin
bottom
10
width
"100%"
height
200
export
default
CustomDialogExample
上面就是一个简单的自定义弹窗
接下来看一下它的有关属性
CustomDialogController 定义了 open()close() 方法,它们说明如下:
open:打开对话框,如果对话框已经打开,则再次打开无效。
close:关闭对话框,如果对话框已经关闭,则再次关闭无效。
value:创建控制器需要的配置参数,
  • CustomDialogControllerOptions
说明如下:
builder:创建自定义弹窗的构造器。
cancel:点击蒙层的事件回调。
autoCancel:是否允许点击遮障层退出。
alignment:弹窗在竖直方向上的对齐方式。
offset:弹窗相对 alignment 所在位置的偏移量。
customStyle:弹窗容器样式是否自定义。
源码
declare interface CustomDialogControllerOptions {
   * Custom builder function.
   * @since 7
  builder: any;
   * Defines the cancel function.
   * @since 7
  cancel?: () => void;
   * Defines if use auto cancel when click on the outside of the dialog.
   * @since 7
  autoCancel?: boolean;
   * Defines the dialog alignment of the screen.
   * @since 7
  alignment?: DialogAlignment;
   * Defines the dialog offset.
   * @since 7
  offset?: Offset;
   * Defines if use costom style.
   * @since 7
  customStyle?: boolean;
   * Grid count of dialog.
   * @since 8
  gridCount?: number;
DialogAlignment的位置
名称 描述
Top 垂直顶部对齐。
Center 垂直居中对齐。
Bottom 垂直底部对齐。
Default 默认对齐。
TopStart8+ 左上对齐。
TopEnd8+ 右上对齐。
CenterStart8+ 左中对齐。
CenterEnd8+ 右中对齐。
BottomStart8+ 左下对齐。
BottomEnd8+ 右下对齐。
参考文档
自定义弹窗
语法糖
 审核编辑:汤梓红
