【C语言应用】使用查表法计算CRC8
笔者曾经在一个项目中,有一个数据协议对接需要用到简单的CRC8校验。当初我们实现的方法是使用查表法,现将实现代码分享下。
//CRC8查表法
static uint8_t R_CRCTABLE[] =  //reversed, 8-bit, poly=0x07
    0x00, 0x91, 0xE3, 0x72, 0x07, 0x96, 0xE4, 0x75,
    0x0E, 0x9F, 0xED, 0x7C, 0x09, 0x98, 0xEA, 0x7B,
    0x1C, 0x8D, 0xFF, 0x6E, 0x1B, 0x8A, 0xF8, 0x69,
    0x12, 0x83, 0xF1, 0x60, 0x15, 0x84, 0xF6, 0x67,
    0x38, 0xA9, 0xDB, 0x4A, 0x3F, 0xAE, 0xDC, 0x4D,
    0x36, 0xA7, 0xD5, 0x44, 0x31, 0xA0, 0xD2, 0x43,
    0x24, 0xB5, 0xC7, 0x56, 0x23, 0xB2, 0xC0, 0x51,
    0x2A, 0xBB, 0xC9, 0x58, 0x2D, 0xBC, 0xCE, 0x5F,
    0x70, 0xE1, 0x93, 0x02, 0x77, 0xE6, 0x94, 0x05,
    0x7E, 0xEF, 0x9D, 0x0C, 0x79, 0xE8, 0x9A, 0x0B,
    0x6C, 0xFD, 0x8F, 0x1E, 0x6B, 0xFA, 0x88, 0x19,
    0x62, 0xF3, 0x81, 0x10, 0x65, 0xF4, 0x86, 0x17,
    0x48, 0xD9, 0xAB, 0x3A, 0x4F, 0xDE, 0xAC, 0x3D,
    0x46, 0xD7, 0xA5, 0x34, 0x41, 0xD0, 0xA2, 0x33,
    0x54, 0xC5, 0xB7, 0x26, 0x53, 0xC2, 0xB0, 0x21,
    0x5A, 0xCB, 0xB9, 0x28, 0x5D, 0xCC, 0xBE, 0x2F,
    0xE0, 0x71, 0x03, 0x92, 0xE7, 0x76, 0x04, 0x95,
    0xEE, 0x7F, 0x0D, 0x9C, 0xE9, 0x78, 0x0A, 0x9B,
    0xFC, 0x6D, 0x1F, 0x8E, 0xFB, 0x6A, 0x18, 0x89,
    0xF2, 0x63, 0x11, 0x80, 0xF5, 0x64, 0x16, 0x87,
    0xD8, 0x49, 0x3B, 0xAA, 0xDF, 0x4E, 0x3C, 0xAD,
    0xD6, 0x47, 0x35, 0xA4, 0xD1, 0x40, 0x32, 0xA3,
    0xC4, 0x55, 0x27, 0xB6, 0xC3, 0x52, 0x20, 0xB1,
    0xCA, 0x5B, 0x29, 0xB8, 0xCD, 0x5C, 0x2E, 0xBF,
    0x90, 0x01, 0x73, 0xE2, 0x97, 0x06, 0x74, 0xE5,
    0x9E, 0x0F, 0x7D, 0xEC, 0x99, 0x08, 0x7A, 0xEB,
    0x8C, 0x1D, 0x6F, 0xFE, 0x8B, 0x1A, 0x68, 0xF9,
    0x82, 0x13, 0x61, 0xF0, 0x85, 0x14, 0x66, 0xF7,
    0xA8, 0x39, 0x4B, 0xDA, 0xAF, 0x3E, 0x4C, 0xDD,
    0xA6, 0x37, 0x45, 0xD4, 0xA1, 0x30, 0x42, 0xD3,
    0xB4, 0x25, 0x57, 0xC6, 0xB3, 0x22, 0x50, 0xC1,
    0xBA, 0x2B, 0x59, 0xC8, 0xBD, 0x2C, 0x5E, 0xCF,
 * copy from java code, warning "unsigned char" and "char"
 * 计算input的CRC
 * @param input
 * @return 返回CRC值
uint8_t get_crc8(const void *Buf, uint32_t Len)
    uint8_t *input = (uint8_t*)Buf;
    uint8_t fcs = (uint8_t)0xFF;
    int32_t i;
    for (i = 0; i < (int32_t)Len; i++)
        fcs = R_CRCTABLE[fcs ^ (uint8_t)input[i]];
    return (uint8_t) (0xFF - fcs);
该段代码是成熟的代码,不过值得注意的是,像这种需要两边对等校验数据的通讯,在代码实现时,最好两边都使用相同实现的校验代码,保证不会因为校验算法的实现不同,而出现相同报文却计算出不同校验值的情况。
在使用场景上,CRC8一般用于对数据校验不是那么严格的场景,毕竟单用1个字节做校验,很多时候可能会产生误判。所以,如果对数据校验要求更高时,需要使用其他更高级的数据校验方法。
延伸阅读:
【C语言】使用余式表的方式计算CRC16
架构师李肯
架构师李肯全网同名),一个专注于嵌入式IoT领域的架构师。有着近10年的嵌入式一线开发经验,深耕IoT领域多年,熟知IoT领域的业务发展,深度掌握IoT领域的相关技术栈,包括但不限于主流RTOS内核的实现及其移植、硬件驱动移植开发、网络通讯协议开发、编译构建原理及其实现、底层汇编及编译原理、编译优化及代码重构、主流IoT云平台的对接、嵌入式IoT系统的架构设计等等。拥有多项IoT领域的发明专利,热衷于技术分享,有多年撰写技术博客的经验积累,连续多月获得RT-Thread官方技术社区原创技术博文优秀奖,荣获CSDN博客专家、CSDN物联网领域优质创作者、2021年度CSDN&RT-Thread技术社区之星、2022年RT-Thread全球技术大会讲师、RT-Thread官方嵌入式开源社区认证专家、RT-Thread 2021年度论坛之星TOP4、华为云云享专家(嵌入式物联网架构设计师)等荣誉。坚信【知识改变命运,技术改变世界】!
欢迎关注我的gitee仓库01workstation ,日常分享一些开发笔记和项目实战,欢迎指正问题。
同时也非常欢迎关注我的CSDN主页和专栏:
【CSDN主页-架构师李肯】
【RT-Thread主页-架构师李肯】
【C/C++语言编程专栏】
【GCC专栏】
【信息安全专栏】
【RT-Thread开发笔记】
【freeRTOS开发笔记】
有问题的话,可以跟我讨论,知无不答,谢谢大家。
 审核编辑:汤梓红
