Pandas中使用Merge、Join、Concat合并数据的效率对比
在 Pandas 中有很多种方法可以进行DF的合并。
本文将研究这些不同的方法,以及如何将它们执行速度的对比。
合并
Pandas 使用 .merge() 方法来执行合并。
import pandas as pd
# a dictionary to convert to a dataframe
data1 = {'identification': ['a', 'b', 'c', 'd'],
      'Customer_Name':['King', 'West', 'Adams', 'Mercy'],         'Category':['furniture', 'Office Supplies', 'Technology', 'R_materials'],}
# our second dictionary to convert to a dataframe
data2 = {'identification': ['a', 'b', 'c', 'd'],
      'Class':['First_Class', 'Second_Class', 'Same_day', 'Standard Class'],
      'Age':[60, 30, 40, 50]}
# Convert the dictionary into DataFrame
df1 = pd.DataFrame(data1)
df2 = pd.DataFrame(data2)
运行我们的代码后,有两个 DataFrame,如下所示。
identification Customer_Name         Category
0             a         King       furniture
1             b         West Office Supplies
2             c         Adams       Technology
3             d         Mercy     R_materials
identification           Class Age
0             a     First_Class   60
1             b   Second_Class   30
2             c       Same_day   40
3             d Standard Class   50
使用 merge() 函数进一步合并。
  代码
# using .merge() function
new_data = pd.merge(df1, df2, on='identification')
这产生了下面的新数据;
identification Customer_Name Category     Class           Age
0     a           King         furniture     First_Class     60
1     b           West         Office Supplies Second_Class   30
2     c           Adams         Technology     Same_day     40
3     d           Mercy         R_materials Standard Class   50
.join() 方法也可以将不同索引的 DataFrame 组合成一个新的 DataFrame。我们可以使用参数‘on’参数指定根据哪列进行合并。
  代码   让我们看看下面的例子,我们如何将单索引 DataFrame 与多索引 DataFrame 连接起来;
import pandas as pd
data1 = {
      'Customer_Name':['King', 'West', 'Adams'],
    'Category':['furniture', 'Office Supplies', 'Technology'],} 7
data2 = {
Ndata = pd.DataFrame(data1, index=pd.Index(['a', 'b', 'c'], name='identification'))
index = pd.MultiIndex.from_tuples([('a', 'x0'), ('b', 'x1'),
                                ('c', 'x2'), ('c', 'x3')],
                                names=['identification', 'x']) 19
Ndata2 = pd.DataFrame(data2, index= index)
print(Ndata, "
", Ndata2)
# joining singly indexed with
# multi indexed
result = Ndata.join(Ndata2, how='inner')
我们的结果如下所示;
identification x                                                     3 a         x0       King       furniture     First_Class     60
b         x1       West     Office Supplies   Second_Class   30
c         x2       Adams       Technology       Same_day     40
        x3       Adams       Technology Standard Class     50
连接DF
  Pandas 中concat() 方法在可以在垂直方向(axis=0)和水平方向(axis=1)上连接 DataFrame。我们还可以一次连接两个以上的 DataFrame 或 Series。
让我们看一个如何在 Pandas 中执行连接的示例;
import pandas as pd
#perform concatenation here based on horizontal axis
new_data = pd.concat([df1, df2], axis=1)
print(new_data)
这样就获得了新的 DataFrame :
identification Customer_Name         Category identification
0             a         King       furniture             a   3 1             b         West Office Supplies             b   4 2             c         Adams       Technology             c   5 3             d         Mercy     R_materials             d
        Class       Age
0     First_Class   60
1   Second_Class   30
2       Same_day   40
3 Standard Class   50
Merge和Join的效率对比
  Pandas 中的Merge Joins操作都可以针对指定的列进行合并操作(SQL中的join)那么他们的执行效率是否相同呢?下面我们来进行一下测。   两个 DataFrame 都有相同数量的行和两列,实验中考虑了从 100 万行到 1000 万行的不同大小的 DataFrame,并在每次实验中将行数增加了 100 万。我对固定数量的行重复了十次实验,以消除任何随机性。下面是这十次试验中合并操作的平均运行时间。
代码
  上图描绘了操作所花费的时间(以毫秒为单位)。
正如我们从图中看到的,运行时间存在显着差异——最多相差 5 倍。随着 DataFrame 大小的增加,运行时间之间的差异也会增加。两个 JOIN 操作几乎都随着 DataFrame 的大小线性增加。但是,Join的运行时间增加的速度远低于Merge。
如果需要处理大量数据,还是请使用join()进行操作。
  审核编辑:汤梓红
