如何将pytorch的模型部署到c++平台上的模型流程
导读 本文主要讲解如何将pytorch的模型部署到c++平台上的模型流程,按顺序分为四大块详细说明了模型转换、保存序列化模型、C ++中加载序列化的PyTorch模型以及执行Script Module。
最近因为工作需要,要把pytorch的模型部署到c++平台上,基本过程主要参照官网的教学示例,期间发现了不少坑,特此记录。
1.模型转换
libtorch不依赖于python,python训练的模型,需要转换为script model才能由libtorch加载,并进行推理。在这一步官网提供了两种方法: 方法一:Tracing 这种方法操作比较简单,只需要给模型一组输入,走一遍推理网络,然后由torch.ji.trace记录一下路径上的信息并保存即可。示例如下:
import torch import torchvision # An instance of your model. model = torchvision.models.resnet18() # An example input you would normally provide to your model's forward() method. example = torch.rand(1, 3, 224, 224) # Use torch.jit.trace to generate a torch.jit.ScriptModule via tracing. traced_script_module = torch.jit.trace(model, example) 缺点是如果模型中存在控制流比如if-else语句,一组输入只能遍历一个分支,这种情况下就没办法完整的把模型信息记录下来。 方法二:Scripting 直接在Torch脚本中编写模型并相应地注释模型,通过torch.jit.script编译模块,将其转换为ScriptModule。示例如下:
class MyModule(torch.nn.Module):     def __init__(self, N, M):         super(MyModule, self).__init__()         self.weight = torch.nn.Parameter(torch.rand(N, M))     def forward(self, input):         if input.sum() > 0:           output = self.weight.mv(input)         else:           output = self.weight + input         return output my_module = MyModule(10,20) sm = torch.jit.script(my_module)
forward方法会被默认编译,forward中被调用的方法也会按照被调用的顺序被编译
如果想要编译一个forward以外且未被forward调用的方法,可以添加 @torch.jit.export.
如果想要方法不被编译,可使用[@torch.jit.ignore](https://link.zhihu.com/?target=https%3A//pytorch.org/docs/master/generated/torch.jit.ignore.html%23torch.jit.ignore) 或者 [@torch.jit.unused](https://link.zhihu.com/?target=https%3A//pytorch.org/docs/master/generated/torch.jit.unused.html%23torch.jit.unused)
# Same behavior as pre-PyTorch 1.2 @torch.jit.script def some_fn():     return 2 # Marks a function as ignored, if nothing # ever calls it then this has no effect @torch.jit.ignore def some_fn2():     return 2 # As with ignore, if nothing calls it then it has no effect. # If it is called in script it is replaced with an exception. @torch.jit.unused def some_fn3():   import pdb; pdb.set_trace()   return 4 # Doesn't do anything, this function is already # the main entry point @torch.jit.export def some_fn4():     return 2 在这一步遇到好多坑,主要原因可归为一下两点
1. 不支持的操作
TorchScript支持的操作是python的子集,大部分torch中用到的操作都可以找到对应实现,但也存在一些尴尬的不支持操作,详细列表可见unsupported-ops(https://pytorch.org/docs/master/jit_unsupported.html#jit-unsupported),下面列一些我自己遇到的操作: 1)参数/返回值不支持可变个数,例如
def __init__(self, **kwargs): 或者
if output_flag == 0:     return reshape_logits else:     loss = self.loss(reshape_logits, term_mask, labels_id)     return reshape_logits, loss 2)各种iteration操作 eg1.
layers = [int(a) for a in layers]  报错torch.jit.frontend.UnsupportedNodeError: ListComp aren’t supported 可以改成:
for k in range(len(layers)):     layers[k] = int(layers[k]) eg2.
seq_iter = enumerate(scores) try:     _, inivalues = seq_iter.__next__() except:     _, inivalues = seq_iter.next() eg3.
line = next(infile) 3)不支持的语句 eg1. 不支持continue torch.jit.frontend.UnsupportedNodeError: continue statements aren’t supported eg2. 不支持try-catch torch.jit.frontend.UnsupportedNodeError: try blocks aren’t supported eg3. 不支持with语句 4)其他常见op/module eg1. torch.autograd.Variable 解决:使用torch.ones/torch.randn等初始化+.float()/.long()等指定数据类型。 eg2. torch.Tensor/torch.LongTensor etc. 解决:同上 eg3. requires_grad参数只在torch.tensor中支持,torch.ones/torch.zeros等不可用 eg4. tensor.numpy() eg5. tensor.bool() 解决:tensor.bool()用tensor>0代替 eg6. self.seg_emb(seg_fea_ids).to(embeds.device) 解决:需要转gpu的地方显示调用.cuda() 总之一句话:除了原生python和pytorch以外的库,比如numpy什么的能不用就不用,尽量用pytorch的各种API
2. 指定数据类型
1)属性,大部分的成员数据类型可以根据值来推断,空的列表/字典则需要预先指定
from typing import Dict class MyModule(torch.nn.Module):     my_dict: Dict[str, int]     def __init__(self):         super(MyModule, self).__init__()         # This type cannot be inferred and must be specified         self.my_dict = {}         # The attribute type here is inferred to be `int`         self.my_int = 20     def forward(self):         pass m = torch.jit.script(MyModule()) 2)常量,使用_Final_关键字
try:     from typing_extensions import Final except:     # If you don't have `typing_extensions` installed, you can use a     # polyfill from `torch.jit`.     from torch.jit import Final class MyModule(torch.nn.Module):     my_constant: Final[int]     def __init__(self):         super(MyModule, self).__init__()         self.my_constant = 2     def forward(self):         pass m = torch.jit.script(MyModule()) 3)变量。默认是tensor类型且不可变,所以非tensor类型必须要指明
def forward(self, batch_size:int, seq_len:int, use_cuda:bool): 方法三:Tracing and Scriptin混合 一种是在trace模型中调用script,适合模型中只有一小部分需要用到控制流的情况,使用实例如下:
import torch @torch.jit.script def foo(x, y):     if x.max() > y.max():         r = x     else:         r = y     return r def bar(x, y, z):     return foo(x, y) + z traced_bar = torch.jit.trace(bar, (torch.rand(3), torch.rand(3), torch.rand(3))) 另一种情况是在script module中用tracing生成子模块,对于一些存在script module不支持的python feature的layer,就可以把相关layer封装起来,用trace记录相关layer流,其他layer不用修改。使用示例如下:
import torch import torchvision class MyScriptModule(torch.nn.Module):     def __init__(self):         super(MyScriptModule, self).__init__()         self.means = torch.nn.Parameter(torch.tensor([103.939, 116.779, 123.68])                                         .resize_(1, 3, 1, 1))         self.resnet = torch.jit.trace(torchvision.models.resnet18(),                                       torch.rand(1, 3, 224, 224))     def forward(self, input):         return self.resnet(input - self.means) my_script_module = torch.jit.script(MyScriptModule())
2.保存序列化模型
如果上一步的坑都踩完,那么模型保存就非常简单了,只需要调用save并传递一个文件名即可,需要注意的是如果想要在gpu上训练模型,在cpu上做inference,一定要在模型save之前转化,再就是记得调用model.eval(),形如
gpu_model.eval() cpu_model = gpu_model.cpu() sample_input_cpu = sample_input_gpu.cpu() traced_cpu = torch.jit.trace(traced_cpu, sample_input_cpu) torch.jit.save(traced_cpu, "cpu.pth") traced_gpu = torch.jit.trace(traced_gpu, sample_input_gpu) torch.jit.save(traced_gpu, "gpu.pth")
3.C++ load训练好的模型
要在C ++中加载序列化的PyTorch模型,必须依赖于PyTorch C ++ API(也称为LibTorch)。libtorch的安装非常简单,只需要在pytorch官网下载对应版本,解压即可。会得到一个结构如下的文件夹。
libtorch/ bin/ include/ lib/ share/ 然后就可以构建应用程序了,一个简单的示例目录结构如下:
example-app/ CMakeLists.txt example-app.cpp example-app.cpp和CMakeLists.txt的示例代码分别如下:
#include  // One-stop header. #include  #include  int main(int argc, const char* argv[]) {   if (argc != 2) {     std::cerr << "usage: example-app  ";     return -1;   }   torch::Module module;   try {     // Deserialize the ScriptModule from a file using torch::load().     module = torch::load(argv[1]);   }   catch (const c10::Error& e) {     std::cerr << "error loading the model ";     return -1;   }   std::cout << "ok "; }
cmake_minimum_required(VERSION 3.0 FATAL_ERROR) project(custom_ops) find_package(Torch REQUIRED) add_executable(example-app example-app.cpp) target_link_libraries(example-app "${TORCH_LIBRARIES}") set_property(TARGET example-app PROPERTY CXX_STANDARD 14) 至此,就可以运行以下命令从example-app/文件夹中构建应用程序啦:
mkdir build cd build cmake -DCMAKE_PREFIX_PATH=/path/to/libtorch .. cmake --build . --config Release 其中/path/to/libtorch是之前下载后的libtorch文件夹所在的路径。这一步如果顺利能够看到编译完成100%的提示,下一步运行编译生成的可执行文件,会看到“ok”的输出,可喜可贺!
4. 执行Script Module
终于到最后一步啦!下面只需要按照构建输入传给模型,执行forward就可以得到输出啦。一个简单的示例如下:
// Create a vector of inputs. std::vector inputs; inputs.push_back(torch::ones({1, 3, 224, 224})); // Execute the model and turn its output into a tensor. at::Tensor output = module.forward(inputs).toTensor(); std::cout << output.slice(/*dim=*/1, /*start=*/0, /*end=*/5) << ' '; 前两行创建一个torch::IValue的向量,并添加单个输入. 使用torch::ones()创建输入张量,等效于C ++ API中的torch.ones。然后,运行script::Module的forward方法,通过调用toTensor()将返回的IValue值转换为张量。C++对torch的各种操作还是比较友好的,通过torch::或者后加_的方法都可以找到对应实现,例如
torch::tensor(input_list[j]).to(at::kLong).resize_({batch, 128}).clone() //torch::tensor对应pytorch的torch.tensor; at::kLong对应torch.int64;resize_对应resize 最后check一下确保c++端的输出和pytorch是一致的就大功告成啦~ 踩了无数坑,薅掉了无数头发,很多东西也是自己一点点摸索的,如果有错误欢迎指正!
      审核编辑:彭静
