YOLOv5在OpenCV上的推理程序
测试与发现
YOLOv5官方给出的YOLOv5在OpenCV上推理的程序相对来说是比较通俗易懂的,条理清晰,有基本的封装,直接可用!但是我也发现,模型的推理时间跟前后处理的时间相差无几,特别是当视频流有多个检测到的对象时候,整个帧率会有明显下降!官方推荐的参考示例代码链接为:
https://github.com/doleron/yolov5-opencv-cpp-python/blob/main/python/yolo-tiny.py
最后发现推理时间没有明显变化,主要是前后处理,有两个函数耗时比较高!从输入图像转换到模型输入数据的函数:
cv2.dnn.blobFromImage(input_image , 1/255.0, (640, 640), swapRB=True)
推理之后的重叠目标框非最大抑制函数:
indexes = cv2.dnn.NMSBoxes(boxes, confidences, 0.25, 0.45)
特别是非最大抑制函数,随着图像中目标数目增多,导致帧率成明显下降趋势!
修改输入转换
可以通过下面的代码等价替换:
rgb = cv.cvtColor(image, cv.COLOR_BGR2RGB)
input_image = cv.resize(src=rgb, dsize=(INPUT_WIDTH, INPUT_HEIGHT))
blob_img = np.float32(input_image) / 255.0
input_x = blob_img.transpose((2, 0, 1))
input_blob = np.expand_dims(input_x, 0)
修改之后测试发现该替代降低了执行时间,说明替代有效!
修改非最大抑制
输入的box格式x, y,w,h,我参考了网上的代码,修改实现一个基于并交比最简单的NMS抑制算法,基于矩阵计算,保证不会因为对象变得多了,增加计算耗时,然后把它们封装成一个单独的方法,导入该方法直接替换之前的代码行为:
class_ids, boxes = non_max_suppression_fast(np.asarray(class_ids), np.asarray(boxes), 0.75)
该函数完整的实现代码如下:
import numpy as np
def non_max_suppression_fast(class_ids, boxes, nms_threshold):
    # if there are no boxes, return
    if len(boxes) == 0:
        return [], []
    if boxes.dtype.kind == "i":
        boxes = boxes.astype("float")
    # initialize the list of picked indexes
    pick = []
    # grab the coordinates of the bounding boxes
    x1 = boxes[:,0]
    y1 = boxes[:,1]
    x2 = boxes[:,2]
    y2 = boxes[:,3]
    # compute the area of the bounding boxes and sort the bounding
    # boxes by the bottom-right y-coordinate of the bounding box
    area = (x2 - x1 + 1) * (y2 - y1 + 1)
    idxs = np.argsort(y2)
    # keep looping while some indexes still remain in the indexes
    # list
    while len(idxs) > 0:
        # grab the last index in the indexes list and add the
        # index value to the list of picked indexes
        last = len(idxs) - 1
        i = idxs[last]
        pick.append(i)
        # find the largest (x, y) coordinates for the start of
        # the bounding box and the smallest (x, y) coordinates
        # for the end of the bounding box
        xx1 = np.maximum(x1[i], x1[idxs[:last]])
        yy1 = np.maximum(y1[i], y1[idxs[:last]])
        xx2 = np.minimum(x2[i], x2[idxs[:last]])
        yy2 = np.minimum(y2[i], y2[idxs[:last]])
        # compute the width and height of the bounding box
        w = np.maximum(0, xx2 - xx1 + 1)
        h = np.maximum(0, yy2 - yy1 + 1)
        # compute the ratio of overlap
        overlap = (w * h) / area[idxs[:last]]
        # delete all indexes from the index list that have
        idxs = np.delete(idxs, np.concatenate(([last],
            np.where(overlap > nms_threshold)[0])))
    # return only the bounding boxes that were picked using the
    # integer data type
    return class_ids[pick], boxes[pick].astype("int")
if __name__ == "__main__":
    boxes = []
    boxes.append((163,   0,  27+163,  41))
    boxes.append((164,   0,  28+164,  43))
    boxes.append((165,    0,   29+165,   42))
    res = non_max_suppression_fast(None, np.asarray(boxes), 0.25)
    print(res)
对比测试
两处都修改完成之后,其它输入条件与代码不变,硬件相同条件下对比测试效果如下:修改之前 Python版本OpenCV与OpenVINO上推理速度:
程序
程序
修改之后 Python版本OpenCV与OpenVINO上推理速度:
程序
程序
可以看到FPS较之前有明显的提升!
      审核编辑:彭静
