基于RS-485通信的温度水位远程测控系统
消耗积分:0 | 格式:rar | 大小:613 KB | 2011-04-12
liuxin
分享资料个
  为满足太阳能热水工程远距离测控的需要,设计了一个基于单片机控制的温度和水位远程测控系统。系统的主机和从机均以ATmega16为控制器,二者通过RS-485通信,距离可以超过1 km。用NTC热敏电阻作测温元件,使用单片机内置的10位A/D转换模块实现多路温度的测量。通过非对称式多谐振荡器电路把水位转换为振荡频率,再用计数器测量频率来实现水位的测量。给出了主机和从机的完整电路及功能,较详细地介绍了水位和温度的测量电路以及传感器参数。
  Abstract:
  To satisfy the demand of long-distance control of solar hot water project, a remote measurement and control system of temperature and water level was introduced. ATmega16 was applied as controller in both master and slaver which communicated by RS-485. The communication distance can exceed 1km. With NTC thermistor as temperature sensor, multi-channel water temperature was measured by a 10 bit A/D convertor embedded in ATmega16. An unsymmetrical oscillator was utilized to convert the water level to oscillating frequency which was measured by a counter. In this paper, the circuit diagrams and function of master and salver were given, the measurement circuit of water level and temperature and sensors parameters were also introduced in detail.
评论(0)
发评论
下载排行榜
