SystemVerilog中的Protected成员
嵌入式技术
1335人已加入
protected类属性或方法具有local成员的所有特征,除此之外的是,protected类属性或方法对扩展类是可见的。
也就是说,protected类属性或方法可以被类自身和扩展类访问,依然不允许在类的外部访问。
声明一个protected类属性或方法,需要通过关键字“protected”。
class packet;
 protected int addr;
 protected function void disp(input int data);
 $display("From packet");
 $display("	 data = %h", data);
 $display("	 addr = %h", addr);
 endfunction
 endclass
 class eth_packet extends packet;
 function set_addr;
 addr = 'hf;
 //protected property 'addr' visible to extended class
 endfunction
 function void eth_disp;
 super.disp('hf);
 //protected method 'disp' visible to extended class
 endfunction
 //OK to override 'protected' method in extended class
 $display("From eth_packet");
 endfunction
 endclass
 module class_TOP( );
 initial begin
 packet p1;
 eth_packet e1;
 e1 = new( );
 p1 = new( );
 //p1.disp(20); //COMPILE ERROR
 //protected methods 'disp' not visible outside the class
 e1.eth_disp;
 e1.disp('hffff);
 end
 endmodule
仿真log:
From packet
 data = 000000ff
 addr = 00000000
From eth_packet
 data = 0000ffff
 V C S S i m u l a t i o n R e p o r t
在上面的例子中,我们声明了一个类“packet”,其中包含protected成员“addr”和一个protected方法“disp” 。
在扩展类“eth_packet”中,我们直接访问成员“addr”以及调用父类的“disp”方法都不会发生编译错误。
在module中直接调用“p1.disp(20);”就会发生编译错误:
Error-[SV-ICMA] Illegal class method access
testbench.sv, 39
Protected method 'disp' of class 'packet' is not visible to scope
'class_TOP'.
Please make sure that the above method is called only from its own class
properties as it is declared as protected.
  审核编辑:汤梓红
