3. 瑞萨RA系列MCU-UART使用
1.硬件信息
m
2.rasc配置
2.1sci-usart 配置
m
2.2 stack配置
m
m
m
2.3串口属性属性
m
2.4 修改堆得大小
默认堆得大小是0,在使用printf函数时候需要堆得空间所以配置一下堆
m
软件编写
bsp_debug_uart.c
#include "bsp_debug_uart.h"
/* 调试串口 UART4 初始化 */
void bsp_uart_init(void)
	fsp_err_t err = FSP_SUCCESS;
	err = R_SCI_UART_Open (&g_uart0_ctrl, &g_uart0_cfg);
	assert(FSP_SUCCESS == err);
/* 发送完成标志 */
volatile bool uart_send_complete_flag = false;
/* 串口中断回调 */
void uart0_callback (uart_callback_args_t * p_args)
	switch (p_args->event)
		case UART_EVENT_RX_CHAR:
		/* 把串口接收到的数据发送回去 */
		R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)&(p_args->data), 1);
		break;
		case UART_EVENT_TX_COMPLETE:
		uart_send_complete_flag = true;
		break;
		default:
		break;
/* 重定向 printf 输出 */
#if defined __GNUC__ && !defined __clang__
int _write(int fd, char *pBuffer, int size); //防止编译警告
	(void)fd;
	R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)pBuffer, (uint32_t)size);
	while(uart_send_complete_flag == false);
	return size;
#else
int fputc(int ch, FILE *f)
	(void)f;
	R_SCI_UART_Write(&g_uart0_ctrl, (uint8_t *)&ch, 1);
	return ch;
#endif
bsp_debug_uart.h
#ifndef __BSP_UART_H__
#define __BSP_UART_H__
#include "hal_data.h"
#include "stdio.h"
void bsp_uart_init(void);
#endif
hal_entery.c
void hal_entry(void)
    /* TODO: add your own code here */
	//初始化io
	R_IOPORT_Open (&g_ioport_ctrl, g_ioport.p_cfg);
	bsp_uart_init();
	printf("hello RA4\\r\\n");
	while(1)
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
		R_BSP_SoftwareDelay(100, BSP_DELAY_UNITS_MILLISECONDS); //延时 100毫秒
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_HIGH);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_HIGH);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_LOW);
		R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_HIGH);
#if BSP_TZ_SECURE_BUILD
    /* Enter non-secure code */
    R_BSP_NonSecureEnter();
#endif
效果
m
审核编辑 黄昊宇
  • 相关推荐
  • m
