WLAN三层组网实验还不会?
1、拓扑图
组网
2、组网配置
SW1配置:
[SW1]vlan batch 10 101 102
//放行VLAN
[SW1]interface GigabitEthernet0/0/1
[SW1-GigabitEthernet0/0/1]port link-type trunk
[SW1-GigabitEthernet0/0/1]port trunk pvid vlan 100
[SW1-GigabitEthernet0/0/1]port trunk allow-pass vlan 100 to 101
//放行VLAN
[SW1]interface GigabitEthernet0/0/2
[SW1-GigabitEthernet0/0/2]port link-type trunk
[SW1-GigabitEthernet0/0/2]port trunk allow-pass vlan 10 101
//配置网关
[SW1]interface Vlanif10
[SW1-Vlanif10]ip address 192.168.13.1 255.255.255.0
[SW1]interface Vlanif100
[SW1-Vlanif100]ip address 192.168.100.254 255.255.255.0
[SW1-Vlanif100]dhcp select interface
[SW1-Vlanif100]dhcp server option 43 sub-option 2 ip-address 192.168.13.2
[SW1]interface Vlanif101
[SW1-Vlanif101]ip address 192.168.101.254 255.255.255.0
[SW1-Vlanif101]dhcp select interface
查看SW1中mac地址
00e0-fc4e-5810是AP的mac地址后面有用
[SW1]dis mac-address
MAC address table of slot 0:
MAC Address    VLAN/       PEVLAN CEVLAN Port            Type      LSP/LSR-ID
               VSI/SI                                              MAC-Tunnel
00e0-fc63-1698 10          -      -      GE0/0/2         dynamic   0/-
00e0-fc4e-5810 100         -      -      GE0/0/1         dynamic   0/-
Total matching items on slot 0 displayed = 2
AC1配置
[AC]vlan batch 10 101
//放行VLAN
[AC]interface GigabitEthernet0/0/1
[AC-GigabitEthernet0/0/1]port link-type trunk
[AC-GigabitEthernet0/0/1]port trunk allow-pass vlan 10 101
//配置IP地址
[AC]interface Vlanif10
[AC-Vlanif10]ip address 192.168.13.2 255.255.255.0
[AC]capwap source  ip-address  192.168.13.2
//配置默认路由使AP与AC互通
[AC]ip route-static 192.168.100.0 24 192.168.13.1
//配置AP上线
[AC]wlan
[AC-wlan-view]ap-id 0 ap-mac 00e0-fc63-1698
查看ap是否以及上线
0 00e0-fc4e-5810 00e0-fc4e-5810 default 192.168.100.253 AP2050DN nor
0 14S
这里为nor即为已上线
[AC]dis ap all
Info: This operation may take a few seconds. Please wait for a moment.done.
Total AP information:
nor  : normal          [1]
ID   MAC            Name           Group   IP              Type            State
 STA Uptime
 0   14S
Total: 1
AC模板配置
[AC]wlan
[AC-wlan-view]ssid-profile name ljr     //ljr为自定义名字
[AC-wlan-ssid-prof-ljr]ssid linjianrong //linjianrong可以理解为WiFi的名字
[AC-wlan-ssid-prof-ljr]q
[AC-wlan-view]security-profile name ljr/   /ljr为自定义名字
[AC-wlan-sec-prof-ljr]security  wpa2 psk pass-phrase  2018060301324 tkip
Warning: The current password is too simple. For the sake of security, you are a
dvised to set a password containing at least two of the following: lowercase let
ters a to z, uppercase letters A to Z, digits, and special characters. Continue?
 [Y/N]:y
Warning:  If the wmm disable command, TKIP, WEP, or radio type of 802.11a/b/g is
 configured, the function of denying access of legacy STAs cannot take effect.
 这里的 2018060301324 为密码
[AC-wlan-sec-prof-ljr]q
[AC-wlan-view]vap-profile name ljr
[AC-wlan-vap-prof-ljr]forward-mode  direct-forward  //direct-forward  为直接转发模式
[AC-wlan-vap-prof-ljr]service-vlan  vlan-id 101  //管理的vlan,即ap下面管理的PC
[AC-wlan-vap-prof-ljr]ssid-profile ljr    //ssid模块
[AC-wlan-vap-prof-ljr]security-profile ljr   //安全模块
[AC-wlan-view]ap-group name default
[AC-wlan-ap-group-default]vap-profile  ljr wlan  1 radio all
Info: This operation may take a few seconds, please wait...done.
上面的敲完后会出现下面的情况
组网
双击1、2,输入密码2018060301324,点击确定完成连接
组网
可以看到已经连上了
组网
双击STA1,在命令行输入ipconfig查看是否已经获取IP地址
组网
到此为止,整个实验完成。
3、总结:
(1)在ENSP中观察不到AP上线可能需要重启AP;
(2)AP与192.168.13.2IP地址需要互通,AP才可能上线;
实验文件下载:https://shendukongjian.lanzoux.com/ioPiSia8lah
审核编辑 :李倩
