分享一个常用的终端菜单系统
1.2w人已加入
在嵌入式开发中,因为只有黑框框的终端,所以在终端输入指令是比较麻烦的,每次都需要重新实现解析字符串。
本篇文章分享一个自己常用的一套终端菜单系统。
代码如下:
#include
#include
#include
typedef enum CmdType
    CMD1, CMD2, CMD3, CMD4, CMD5, QUIT
}CmdType;
typedef struct CmdList
    CmdType type;
    unsigned char info[50];
}CmdList;
CmdList g_cmd_list[] =
    {CMD1, "run cmd1"},
    {CMD2, "run cmd2"},
    {CMD3, "run cmd3"},
    {CMD4, "run cmd4"},
    {CMD5, "run cmd5"},
    {QUIT, "to quit"},
void printf_cmd_str()
    int size = sizeof(g_cmd_list) / sizeof(g_cmd_list[0]);
    printf("support cmd:\\n");
    for (int i = 0; i < size; i++) {
        printf("    .%d-->%s\\n", i, g_cmd_list[i].info);
    printf("eg. you can input \\".0\\" to run this cmd.\\n");
int main(int argc, char *argv[])
    int cmd_size = sizeof(g_cmd_list) / sizeof(g_cmd_list[0]);
    while (1) {
        printf_cmd_str();
        char data[20] = {0};
        if (fgets(data, 20, stdin) < 0) {
            printf("fgets error\\n");
            continue;
        if (data[0] == '.') {
            int id = atoi(&data[1]);
            if (id >= cmd_size || id < 0) {
                printf("input err\\n");
                continue;
            int cmd = g_cmd_list[id].type;
            if (cmd == CMD1) {
                printf("run cmd1\\n");
            else if (cmd == CMD2) {
                printf("run cmd2\\n");
            else if (cmd == CMD3) {
                printf("run cmd3\\n");
            else if (cmd == CMD4) {
                printf("run cmd4\\n");
            else if (cmd == CMD5) {
                printf("run cmd5\\n");
            else if (cmd == QUIT) {
                printf("to quit\\n");
                break;
            else {
                printf("this cmd is not supported\\n");
        else {
            printf("input invalid\\n");
    return 0;
运行结果如下:
****@****:~/zcl$ ./a.out
support cmd:
    .0-->run cmd1
    .1-->run cmd2
    .2-->run cmd3
    .3-->run cmd4
    .4-->run cmd5
    .5-->to quit
eg. you can input ".0" to run this cmd.
.0
run cmd1
support cmd:
    .0-->run cmd1
    .1-->run cmd2
    .2-->run cmd3
    .3-->run cmd4
    .4-->run cmd5
    .5-->to quit
.5
to quit
****@****:~/zcl$
审核编辑:刘清
