一文带你迅速了解常用串行总线之IIC协议3
1.2w人已加入
4. bit控制模块(i2c_bit_ctrl):
`define I2C_CMD_NOP 4'b0000
`define I2C_CMD_START 4'b0001
`define I2C_CMD_STOP 4'b0010
`define I2C_CMD_WRITE 4'b0100
`define I2C_CMD_READ 4'b1000
module i2c_bit_ctrl (
input             clk,      // system clock
input             rst,      // synchronous active high reset
input             nReset,   // asynchronous active low reset
input             ena,      // core enable signal
input      [15:0] clk_cnt,  // clock prescale value
input      [ 3:0] cmd,      // command (from byte controller)
output reg        cmd_ack,  // command complete acknowledge
output reg        busy,     // i2c bus busy
output reg        al,       // i2c bus arbitration lost
input             din,
output reg        dout,
input             scl_i,    // i2c clock line input
output            scl_o,    // i2c clock line output
output reg        scl_oen,  // i2c clock line output enable (active low)
input             sda_i,    // i2c data line input
output            sda_o,    // i2c data line output
output reg        sda_oen   // i2c data line output enable (active low)
// variable declarations
reg [ 1:0] cSCL, cSDA;      // capture SCL and SDA
reg [ 2:0] fSCL, fSDA;      // SCL and SDA filter inputs
reg        sSCL, sSDA;      // filtered and synchronized SCL and SDA inputs
reg        dSCL, dSDA;      // delayed versions of sSCL and sSDA
reg        dscl_oen;        // delayed scl_oen
reg        sda_chk;         // check SDA output (Multi-master arbitration)
reg        clk_en;          // clock generation signals
reg        slave_wait;      // slave inserts wait states
reg [15:0] cnt;             // clock divider counter (synthesis)
reg [13:0] filter_cnt;      // clock divider for filter
// state machine variable
reg [17:0] c_state; // synopsys enum_state
// module body
// whenever the slave is not ready it can delay the cycle by pulling SCL low
// delay scl_oen
always @(posedge clk)
  dscl_oen <= #1 scl_oen;
// slave_wait is asserted when master wants to drive SCL high, but the slave pulls it low
// slave_wait remains asserted until the slave releases SCL
always @(posedge clk or negedge nReset)
  if (!nReset) slave_wait <= 1'b0;
  else         slave_wait <= (scl_oen & ~dscl_oen & ~sSCL) | (slave_wait & ~sSCL);
// master drives SCL high, but another master pulls it low
// master start counting down its low cycle now (clock synchronization)
wire scl_sync   = dSCL & ~sSCL & scl_oen;
// generate clk enable signal
  if (~nReset)
  begin
      cnt    <= #1 16'h0;
      clk_en <= #1 1'b1;
  end
  else if (rst || ~|cnt || !ena || scl_sync)
  begin
      cnt    <= #1 clk_cnt;
      clk_en <= #1 1'b1;
  end
  else if (slave_wait)
  begin
      cnt    <= #1 cnt;
      clk_en <= #1 1'b0;
  end
  else
  begin
      cnt    <= #1 cnt - 16'h1;
      clk_en <= #1 1'b0;
  end
// generate bus status controller
// capture SDA and SCL
// reduce metastability risk
  if (!nReset)
  begin
      cSCL <= #1 2'b00;
      cSDA <= #1 2'b00;
  end
  else if (rst)
  begin
      cSCL <= #1 2'b00;
      cSDA <= #1 2'b00;
  end
  else
  begin
      cSCL <= {cSCL[0],scl_i};
      cSDA <= {cSDA[0],sda_i};
  end
// filter SCL and SDA signals; (attempt to) remove glitches
  if      (!nReset     ) filter_cnt <= 14'h0;
  else if (rst || !ena ) filter_cnt <= 14'h0;
  else if (~|filter_cnt) filter_cnt <= clk_cnt >> 2; //16x I2C bus frequency
  else                   filter_cnt <= filter_cnt -1;
  if (!nReset)
  begin
      fSCL <= 3'b111;
      fSDA <= 3'b111;
  end
  else if (rst)
  begin
      fSCL <= 3'b111;
      fSDA <= 3'b111;
  end
  begin
      fSCL <= {fSCL[1:0],cSCL[1]};
      fSDA <= {fSDA[1:0],cSDA[1]};
  end
// generate filtered SCL and SDA signals
  if (~nReset)
  begin
      sSCL <= #1 1'b1;
      sSDA <= #1 1'b1;
      dSCL <= #1 1'b1;
      dSDA <= #1 1'b1;
  end
  else if (rst)
  begin
      sSCL <= #1 1'b1;
      sSDA <= #1 1'b1;
      dSCL <= #1 1'b1;
      dSDA <= #1 1'b1;
  end
  else
  begin
      sSCL <= #1 &fSCL[2:1] | &fSCL[1:0] | (fSCL[2] & fSCL[0]);
      sSDA <= #1 &fSDA[2:1] | &fSDA[1:0] | (fSDA[2] & fSDA[0]);
      dSCL <= #1 sSCL;
      dSDA <= #1 sSDA;
  end
// detect start condition => detect falling edge on SDA while SCL is high
// detect stop condition => detect rising edge on SDA while SCL is high
reg sta_condition;
reg sto_condition;
  if (~nReset)
  begin
      sta_condition <= #1 1'b0;
      sto_condition <= #1 1'b0;
  end
  else if (rst)
  begin
  end
  else
  begin
      sta_condition <= #1 ~sSDA &  dSDA & sSCL;
      sto_condition <= #1  sSDA & ~dSDA & sSCL;
  end
// generate i2c bus busy signal
  if      (!nReset) busy <= #1 1'b0;
  else if (rst    ) busy <= #1 1'b0;
  else              busy <= #1 (sta_condition | busy) & ~sto_condition;
// generate arbitration lost signal cascatrix carson
// aribitration lost when:
// 1) master drives SDA high, but the i2c bus is low
// 2) stop detected while not requested
reg cmd_stop;
  if (~nReset)
      cmd_stop <= #1 1'b0;
  else if (rst)
  else if (clk_en)
      cmd_stop <= #1 cmd == `I2C_CMD_STOP;
  if (~nReset)
      al <= #1 1'b0;
  else if (rst)
      al <= #1 1'b0;
  else
      al <= #1 (sda_chk & ~sSDA & sda_oen) | (|c_state & sto_condition & ~cmd_stop);
// generate dout signal (store SDA on rising edge of SCL) cascatrix carson
  if (sSCL & ~dSCL) dout <= #1 sSDA;
// generate statemachine cascatrix carson
// nxt_state decoder
parameter [17:0] idle    = 18'b0_0000_0000_0000_0000;
parameter [17:0] start_a = 18'b0_0000_0000_0000_0001;
parameter [17:0] start_b = 18'b0_0000_0000_0000_0010;
parameter [17:0] start_c = 18'b0_0000_0000_0000_0100;
parameter [17:0] start_d = 18'b0_0000_0000_0000_1000;
parameter [17:0] start_e = 18'b0_0000_0000_0001_0000;
parameter [17:0] stop_a  = 18'b0_0000_0000_0010_0000;
parameter [17:0] stop_b  = 18'b0_0000_0000_0100_0000;
parameter [17:0] stop_c  = 18'b0_0000_0000_1000_0000;
parameter [17:0] stop_d  = 18'b0_0000_0001_0000_0000;
parameter [17:0] rd_a    = 18'b0_0000_0010_0000_0000;
parameter [17:0] rd_b    = 18'b0_0000_0100_0000_0000;
parameter [17:0] rd_c    = 18'b0_0000_1000_0000_0000;
parameter [17:0] rd_d    = 18'b0_0001_0000_0000_0000;
parameter [17:0] wr_a    = 18'b0_0010_0000_0000_0000;
parameter [17:0] wr_b    = 18'b0_0100_0000_0000_0000;
parameter [17:0] wr_c    = 18'b0_1000_0000_0000_0000;
parameter [17:0] wr_d    = 18'b1_0000_0000_0000_0000;
  if (!nReset)
  begin
      c_state <= #1 idle;
      cmd_ack <= #1 1'b0;
      scl_oen <= #1 1'b1;
      sda_oen <= #1 1'b1;
      sda_chk <= #1 1'b0;
  end
  else if (rst | al)
  begin
      c_state <= #1 idle;
      cmd_ack <= #1 1'b0;
      scl_oen <= #1 1'b1;
      sda_oen <= #1 1'b1;
      sda_chk <= #1 1'b0;
  end
  else
  begin
// default no command acknowledge + assert cmd_ack only 1clk cycle
cmd_ack   <= #1 1'b0;
      if (clk_en) // synopsys full_case parallel_case
          case (c_state)
                // idle state
                idle:
                begin // synopsys full_case parallel_case
                    case (cmd)
                     `I2C_CMD_START: c_state <= #1 start_a;
                     `I2C_CMD_STOP:  c_state <= #1 stop_a;
                     `I2C_CMD_WRITE: c_state <= #1 wr_a;
                     `I2C_CMD_READ:  c_state <= #1 rd_a;
                      default:        c_state <= #1 idle;
                    endcase
        // keep SCL in same state
         // keep SDA in same state
                    sda_oen <= #1 sda_oen;
        // don't check SDA output
                    sda_chk <= #1 1'b0;
                end
                // start
                start_a:
                begin
                    c_state <= #1 start_b;
                    sda_oen <= #1 1'b1;    // set SDA high
                    sda_chk <= #1 1'b0;
                end
                start_b:
                begin
                    c_state <= #1 start_c;
                    scl_oen <= #1 1'b1; // set SCL high
                    sda_oen <= #1 1'b1; // keep SDA high
                    sda_chk <= #1 1'b0;
                end
                start_c:
                begin
                    c_state <= #1 start_d;
                    scl_oen <= #1 1'b1; // keep SCL high
                    sda_oen <= #1 1'b0; // set SDA low
                    sda_chk <= #1 1'b0;
                end
                start_d:
                begin
                    c_state <= #1 start_e;
                    sda_oen <= #1 1'b0; // keep SDA low
                    sda_chk <= #1 1'b0;
                end
                start_e:
                begin
                    c_state <= #1 idle;
                    cmd_ack <= #1 1'b1;
                    scl_oen <= #1 1'b0; // set SCL low
                    sda_chk <= #1 1'b0;
                end
                // stop
                stop_a:
                begin
                    c_state <= #1 stop_b;
                    scl_oen <= #1 1'b0; // keep SCL low
                    sda_chk <= #1 1'b0;
                end
                stop_b:
                begin
                    c_state <= #1 stop_c;
                    sda_chk <= #1 1'b0;
                end
                stop_c:
                begin
                    c_state <= #1 stop_d;
                    sda_chk <= #1 1'b0;
                end
                stop_d:
                begin
                    c_state <= #1 idle;
                    cmd_ack <= #1 1'b1;
                    sda_chk <= #1 1'b0;
                end
                // read
                rd_a:
                begin
                    c_state <= #1 rd_b;
                    sda_oen <= #1 1'b1; // tri-state SDA
                    sda_chk <= #1 1'b0;
                end
                rd_b:
                begin
                    c_state <= #1 rd_c;
                    sda_oen <= #1 1'b1; // keep SDA tri-stated
                    sda_chk <= #1 1'b0;
                end
                rd_c:
                begin
                    c_state <= #1 rd_d;
                    sda_chk <= #1 1'b0;
                end
                rd_d:
                begin
                    c_state <= #1 idle;
                    cmd_ack <= #1 1'b1;
                    sda_chk <= #1 1'b0;
                end
                // write
                wr_a:
                begin
                    c_state <= #1 wr_b;
                    sda_oen <= #1 din;  // set SDA
        // don't check SDA output (SCL low)
                    sda_chk <= #1 1'b0;
                end
                wr_b:
                begin
                    c_state <= #1 wr_c;
                    sda_oen <= #1 din;  // keep SDA
        // don't check SDA output yet
                    sda_chk <= #1 1'b0;
        // allow some time for SDA and SCL to settle
                end
                wr_c:
                begin
                    c_state <= #1 wr_d;
                    sda_oen <= #1 din;
                    sda_chk <= #1 1'b1; // check SDA output
                end
                wr_d:
                begin
                    c_state <= #1 idle;
                    cmd_ack <= #1 1'b1;
                    sda_oen <= #1 din;
                    sda_chk <= #1 1'b0; // don't check SDA output (SCL low)
                end
          endcase
  end
// assign scl and sda output (always gnd)
assign scl_o = 1'b0;
assign sda_o = 1'b0;
endmodule
04
IIC的优缺点
4.1 IIC协议优点
  1. 通信只需要两条信号线;
  2. 多主设备结构下,总线系统无需额外的逻辑与线路;
  3. 应答机制完善,通信传输稳定。
4.2 IIC协议缺点
  1. 硬件结构复杂;
  2. 支持传输距离较短;
  3. 半双工速率慢于全双工,SPI全双工一般可实现10Mbps以上的传输速率,IIC最高速度仅能达到3.4Mbps。
