Java中Get和Post的使用
1.2w人已加入
1 Get请求数据
项目地址:https://github.com/Snowstorm0/learn-get-post
1.1 Controller
文件名MyController,内容为:
@RestController
@RequestMapping("/homepage")
public class MyController {
    @Autowired
    MyService myService;
    @GetMapping("/learnGet")
    public String learnGet(){
        return myService.learnGet();
1.2 Service
文件名MyService,内容为:
@Service
@EnableScheduling
public class MyService {
        Long timeLong = System.currentTimeMillis();
        SimpleDateFormat timeFormat = new SimpleDateFormat("yyyy-MM-dd HH:mm:ss"); //设置格式
        String timeString = timeFormat.format(timeLong);
        return timeString;
1.3 Application
在application.properties配置:
# 设置端口号
server.port=8888
1.4 Postman
配置Get,地址为: http://localhost:8888/homepage/returnTime 。
即可获得当前时间戳。
Controller
2 Post接收数据
2.1 Controller
@RestController
    @Autowired
    @PostMapping("/postReceive")
    public Map postReceive(@RequestParam("number") int number, @RequestParam("name") String name) {
        return myService.postReceive(number, name);
    @PostMapping("/postReceiveByMap")
    public Map postReceiveByMap(@RequestParam Map map) {
        System.out.println("map:" + map + "\\n");
        return myService.postReceiveByMap(map);
2.2 Service
文件名MyService,内容为:
@Service
@EnableScheduling
    public Map postReceive(int number, String name){
        Map res = new HashMap<>();
        res.put("number", number);
        res.put("name", name);
        return res;
    public Map postReceiveByMap(Map map){
        int number = map.get("number") == null ? 0 : Integer.parseInt((String) map.get("number"));
        String name = map.get("name") == null ? "" : (String)map.get("name");
        System.out.println("res:" + res + "\\n");
        return res;
2.3 Application
# 设置端口号
server.port=8888
2.4 Postman
即可获得输出。
Controller
3 Post发送数据
项目地址:https://github.com/Snowstorm0/learn-post-send
需要注意,RestTemplate在postForObject时,用MultiValueMap,不可使用HashMap。
3.1 Controller
@RestController
    @Autowired
    @PostMapping("/postSend")
    public Map postSend() {
        return myService.postSend();
3.2 Service
文件名MyService,内容为:
@Service
@EnableScheduling
    @Resource
    private RestTemplate restTemplate;
    String URL = "http://localhost:8888/homepage/postReceiveByMap";
    public Map postSend(){
        Map sendData = new HashMap<>();
        sendData.put("number", 3);
        sendData.put("name", "张三");
        ResponseEntity responseData = restTemplate.postForEntity(URL, sendData, ResponseResult.class);
        Map returnData = new HashMap<>();
        returnData.put("StatusCode:", responseData.getStatusCode());
        returnData.put("Body:", responseData.getBody());
        return returnData;
3.3 ResponseResult
public class ResponseResult {
    private int number;
    private String name;
    public ResponseResult(){
    public int getNumber() {
        return number;
    public void setNumber(int number) {
        this.number = number;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
    @Override
    public String toString() {
        return "ResponseResult [number=" + number + ",name=" + name + "]";
3.4 Config
@Configuration
public class Config {
    @Bean
    public RestTemplate restTemplate(RestTemplateBuilder builder){
        return builder.build();
3.5 Application
# 设置端口号
server.port=8889
3.6 Postman
配置Post,地址为: http://localhost:8889/homepage/postSend
即可获得输出。
Controller
  审核编辑:汤梓红
