关于我自己整理的一份基于Raspberry Pi / 树莓派而设计的工业计算机资料
1.2w人已加入
CM4 Industrial是一款基于 Raspberry Pi / 树莓派 Compute Module 4,由EDATEC面向工业应用设计的嵌入式计算机设计的工业嵌入式计算机。系统可以根据不同的应用配置成1GB/2GB/4GB/8GB 的 RAM 和8GB/16GB/32GB 的 EMMC,支持 SD 卡启动。
工业计算机CM4 Industrial
SPECIFICATIONS
分类 特点
处理器 Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
H.265 (HEVC) (up to 4Kp60 decode), H.264 (up to 1080p60 decode, 1080p30 encode)
OpenGL ES 3.1, Vulkan 1.0
内存 1GB / 2GB / 4GB / 8GB LPDDR4-3200 SDRAM
储存 Onboard 0GB / 8GB / 16GB / 32GB eMMC
1x microSD Card Slot for system boot when choosing 0GB(CM4 Lite) eMMC
Onboard 32Mbits / 4MBytes SPI Flash
显示 1x standard HDMI Out (Type A)
1x FPC HDMI Touch Display
1x FPC DSI Touch Display
摄像头 1x FPC CSI, Support Raspberry Pi Official 5M & 8M Cameras
有线接口 1x Gig-Ethernet (10/100/1000M), Support PoE (with Raspberry Pi PoE HAT)
1x Fast-Ethernet (10/100M)
2x USB 2.0 Type-A
1x USB micro-B for eMMC Flashing (Inside the case)
无线 Optional 2.4 GHz, 5.0 GHz IEEE 802.11 b/g/n/ac wireless and Bluetooth 5.0, BLE with external antenna
Optional 4G LTE with optional GPS support, 1x Standard-SIM card slot, external antenna
工业接口 2x RS485, 6-pin Terminal Block
1x RS232, 3-pin Terminal Block
3x 12-bits ADC Channels, 4-pin Terminal Block
2x isolated DI, Support Dry / Wet Contact
1x SPDT Relay, 6-pin Terminal Block
1x RTC with CR1220 backup
1x adjustable speed fan control, 3-pin wafer connector
1x Buzzer
扩展接口 1x mini-PCIe slot with 1-lane PCIe and 1x USB 2.0, Support 4G Module
1x standard Raspberry Pi 40-PIN GPIO
1x Serial(TTL), 4-pin DIP connector
2x USB 2.0, 4-pin DIP connector
1x non-isolated IO, 2-pin DIP connector
电源输入 8 ~ 36V DC*
DC Jack or optional 2-pin Terminal Block
指示灯 1x Power Indicator with Red LED
1x Status Indicator with Green LED
1x 4G network indicator with Blue LED (Inside the case)
按键 1x System Reset Button
1x User Button
工作温度 -25~ 50°C
操作湿度 10% - 60%
外壳 Metal Case, 2 Antenna Holes
尺寸 147(L) x 119(W) x 28(H) mm
安装方式 DIN-mount
Wall-mount
操作系统 Pre-installed with 32-bit Raspberry Pi OS with Desktop in eMMC(if choosing eMMC variants)
Compatible with Origin Raspberry Pi OS, support 32-bit and 64-bit OS, support Lite and Desktop versions
Support BSP online install / upgrade with APT tool
INFORMATION
  • 它提供多种工业通讯接口和功能如多路 RS232,RS485,多路高精度 ADC,隔离 IO 输入,继电器控制,电池备份的实时时钟,告警蜂鸣器。它也提供了强大的通讯能力,1路带PoE功能的千兆以太网接口,1路10/100M网口,4G/LTE模块,经过认证的 2.4/5.8G 双频 WiFi 和蓝牙,支持外置天线。
  • CM4 Industrial可以支持一路官方 8 百万像素的摄像头,一路DSI 显示接口和一路HDMI的排线接口。其他特征包括板载32Mb串行Flash用于储存系统数据,8~36V*宽范围供电,重要的接口都做了 ESD 保护。
工业计算机PCB
  • 系统提供非常强的扩展能力,Mini-PCIe的座子提供PCIe 1x Gen2接口扩展,除支持标准的40针扩展接口外,还提供 2 路 4 针 USB 接口用于机壳内部扩展,1路TTL电平的RS232 接口等,以充分利用其强大的通信功能来满足工业场景中的各种要求。
工业计算机CM4 Industrial
