74HC595驱动led单色点阵屏程序
控制/MCU
1823人已加入
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define NOP     _nop_()
sbit OE     = P2^0;
sbit A1     = P2^1;
sbit B1     = P2^2;
sbit SHCP=P2^4;    //11脚SHCP    移位时钟
sbit STCP=P2^3;    //12脚STCP    锁存时钟
sbit DATA=P3^7;    //数据输入
uchar code table[10][32]=
{{0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
  0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},
{ 0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
  0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF}};
//数据串行输入
void serial_input(uchar dat)
uint m;
for(m=0;m<8;m++)
if(dat & 0x80)
DATA=1;
else
  DATA=0;
SHCP=0;
SHCP=1;
        NOP;
NOP;
SHCP=0;
NOP;
NOP;
dat=dat<<1;
//并出
void serial_output()
STCP=1;
NOP;
NOP;
STCP=0;
//行显控制
void HC138_scan(uchar temp)
   OE=1;
   A1=0x01 & temp;
   B1=0x01 &(temp>>1);
//整屏显示
void display()
uint i,j,k;
for(k=0;k<4;k++)                  //显示的四行
for(j=0;j<2;j++)          //显示3、4列
for(i=0;i<2;i++)      // 显示1、2列
serial_input(table[j][3*8+2*k+i]);
serial_input(table[j][2*8+2*k+i]);
serial_input(table[j][1*8+2*k+i]);
serial_input(table[j][0*8+2*k+i]);
serial_output();
HC138_scan(k);
void main()
while(1)
display();
评论(0)
发评论
从此以后、 2016-01-04
0 回复 举报
保存来用用,谢谢楼主 收起回复
智能超能 2015-06-01
0 回复 举报
求原理图啊。。。。。。。。。。。。。。。。。。。。 收起回复
全部评论
