浅析新能源汽车快速换电技术
汽车电子
2307人已加入
近年来,新能源汽车行业迅速发展,电动汽车将成为越来越多人们日常出行的选择,在电动汽车被普遍认可的同时如何快速补电成为人们关注的焦点,快速换电技术是完美解决现阶段新能源汽车快速补电的有效手段之一。为此,中航光电推出适用多种场景的平台性产品,同时也支持客户定制化服务,为新能源汽车行业发展提供助力。 In recent years, the electric vehicle industry has developed rapidly, and electric vehicles will become an increasingly popular choice for people's daily travel. While electric vehicles are widely recognized, fast charging supply has become the focus of attention. Quick battery swap is the effective way to achieve rapid power supply at this stage. Thus, JONHON has launched platform-based products suitable for various scenarios, and also supported customized services, providing assistance for the development of the electric vehicle industry.
快速换电技术
Fast Battery Swap Technology
在新能源汽车使用的任意时段,通过特定的装置短时间内快速更换动力电池,可以满足驾乘者快速、安全地充电需求,真正做到随时随地,想充就充。 At any time when the electric vehicle is used, the power battery can be quickly replaced through a specific device in a short time, meeting the needs for fast and safe charging.
产品规格
Sizes
▼后备箱换电
 Trunk Battery Swap
换电技术
JONHON
▼底盘换电
 Chassis Battery Swap
换电技术
JONHON
▼便携式换电
 Portable Battery Swap
换电技术
JONHON
▼立体车库
 Stereo Garage
换电技术
JONHON
依据电池不同安装位置分为三种换电形式:底盘换电后备箱换电便携换。 According to different installation positions of the battery, there are three types of battery swap: chassis battery swap, trunk battery swap, and portable battery swap.
产品特性
Characteristics
新能源换电车型,适应都市快节奏,全自动换电仅需一首歌的时间。换电连接器作为电池包唯一的电接口,需同时提供高压、低压、通信及接地的混装连接,换电连接器的大浮动补偿能力让整车设计换电结构时尺寸精度更加游刃有余,高寿命可在10000次插拔后仍然保持良好的阻抗水平,高密封防水性让其在使用中更加稳定、省心。
The battery swapmodel of EV, suitable for fast-paced life, takes only the time of one song to achieveautomatic battery swap. As the only electrical interface of the battery pack,the battery swap connector needs to provide mixed connection of high voltage,low voltage, communication and grounding. Floating compensation capability doesnot have such high requirements for the size of the battery swap structure ofthe whole vehicle. Besides, the product can still maintain a good impedancelevel after 10,000 plug-in, and its high sealing and waterproofness make itmore stable and easy in use.
产品创新
Advantages
1
悬浮式浮动更顺畅:浮动结构采用弹簧悬浮式结构设计,角度修正无卡滞,同时减少零件之间的机械磨损;内部设置自润滑垫片保证XY浮动顺畅,凹槽结构保证浮动结构回中可靠,并提供一定的原点保持力。
Smooth suspendedfloating: the floating structure adopts springsuspended design, which can correct the angle without sticking and reduce themechanical wear between parts. Self-lubricating gaskets inside can ensuresmooth XY floating, and the groove design ensures reliable centering of thefloating structure and provides a certain origin holding force.
2
引导顺滑插拔无卡滞:引导结构采用不锈钢金属导套+自润滑非金属衬套结构,在保证插拔耐久的前提下,又减小了插拔异响和插拔力,避免了插拔卡滞。
Smoothguiding, no plug-in stagnation: the guidingstructure adopts stainless steel metal guide sleeve and self-lubricatingnonmetallic bushing structure, which reduces plug-in noise and plug-in force,so as to avoid plug-in stagnation on the premise of ensuring plug-indurability.
3
模块化设计更方便:低压模块化设计,采用后装形式,低压线束单独制作,大大提升装配效率。同时,一旦使用过程中低压线束出现损坏,无需整套更换,仅需更换单独部件。
Convenient modulardesign: the product adopts low-voltage modulardesign and rear mounting. The low-voltage harness is manufactured separately,greatly improving the assembly efficiency. At the same time, once thelow-voltage harness is damaged during use, it is not necessary to replace thewhole set, but only to replace individual components.
编辑:黄飞
