盘点一下gcc有哪些常用选项
gcc有哪些常用选项,今天,就来给大家盘点一下。
-E表示预处理,处理所有以井号键开头的代码,常见的比如把头文件展开。
hello.c
#include
int main()
    printf("helloworld
    return 0;
预处理:
gcc -E hello.c -o hello.i
  预处理后的文件:
# 1 "hello.c"
# 1 ""
# 1 ""
# 31 ""
# 1 "/usr/include/stdc-predef.h" 1 3 4
# 32 "" 2
# 1 "hello.c"
# 1 "/usr/include/stdio.h" 1 3 4
# 27 "/usr/include/stdio.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/libc-header-start.h" 1 3 4
# 33 "/usr/include/x86_64-linux-gnu/bits/libc-header-start.h" 3 4
# 1 "/usr/include/features.h" 1 3 4
# 461 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 1 3 4
# 452 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/wordsize.h" 1 3 4
# 453 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 1 "/usr/include/x86_64-linux-gnu/bits/long-double.h" 1 3 4
# 454 "/usr/include/x86_64-linux-gnu/sys/cdefs.h" 2 3 4
# 462 "/usr/include/features.h" 2 3 4
# 485 "/usr/include/features.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 1 3 4
# 10 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 3 4
# 1 "/usr/include/x86_64-linux-gnu/gnu/stubs-64.h" 1 3 4
# 11 "/usr/include/x86_64-linux-gnu/gnu/stubs.h" 2 3 4
# 486 "/usr/include/features.h" 2 3 4
# 34 "/usr/include/x86_64-linux-gnu/bits/libc-header-start.h" 2 3 4
# 28 "/usr/include/stdio.h" 2 3 4
# 1 "hello.c"
# 1 ""
# 1 ""
# 31 ""
# 32 "" 2
# 1 "hello.c"
-S表示编译,把C文件变成汇编文件。
还是使用hello.c源文件。
gcc -S hello.c -o hello.s
  汇编后的文件变成:
    .file   "hello.c"
    .text
    .section    .rodata
.LC0:
    .string "helloworld"
    .text
    .globl  main
    .type   main, @function
main:
.LFB0:
    .cfi_startproc
    endbr64
    pushq   %rbp
    .cfi_def_cfa_offset 16
    .cfi_offset 6, -16
    movq    %rsp, %rbp
    .cfi_def_cfa_register 6
-c表示汇编,把汇编文件变成二进制文件,但是这个二进制文件还不能运行,因为缺少库的信息。
还是使用hello.c源文件:
gcc -c hello.c -o hello.o
汇编后的文件是二进制文件,用vim打开后是这样:
GCC
-l表示链接库的名字,比如我们经常用的多线程,编译的时候加上加上-lpthread 编译器会自动去找 libpthread.so,如果代码里面用到第三方库,一般都要加上。
thread.c
#include
#include
#include
void *my_thread(void *arg)
    printf("this is my thread ...
int main()
    pthread_t tid;
    if (pthread_create(&tid, NULL, my_thread, NULL) != 0)
        perror("pthread_create");
        exit(1);
    void *status;
    pthread_join(tid, &status);
    return 0;
  编译:
gcc thread.c -o thread -lpthread
-L表示库的路径。如果是你自己制作的库文件,并且没有放在系统指定的目录下,比如 /lib,那编译的时候就要加上库的路径,否则,编译器找不到库在哪。
假设有个动态库叫做 libtest.so,存放在当前目录下:
root@Turbo:test# ls
hello.c  libtest.so
如果编译的时候需要链接 libtest.so,则:
gcc main.c -o main -ltest -L .
-I表示头文件路径,常用于自己写的头文件,不在当前目录下,那编译的时候就得指定头文件的路径。
假设 hello.c 源文件包含了 hello.h 头文件:
#include "hello.h"
hello.h存放在上一级目录:
root@Turbo:test# ls
hello.c
root@Turbo:test# ls ..
hello.h  test
  编译的时候,需要指定头文件的路径:
gcc hello.c -o hello -I ..
  -g表示可以调试,比如我们之前讲的gdb、valgrind,如果想要调试的时候显示源码、行号,编译的时候就需要加上-g选项。
gcc hello.c -o hello -g
  -O表示优化,可以是O0到O3,我们之前讲volatile的时候,就用过这个选项,不同的优化等级,对代码的处理略微有些区别。
hello.c
#include
#include
void delay()
    int i, j;
    for (i = 0; i < 100000; i++)
        for (j = 0; j < 10000; j++);
int main()
    printf("%ld
", time(NULL));
    delay();
    printf("%ld
", time(NULL));
    return 0;
  不优化:
运行结果:
root@Turbo:test# ./hello
1683603927
1683603929
root@Turbo:test#
优化:
gcc hello.c -o hello -O3
  运行结果:
1683603941
1683603941
root@Turbo:test#
  当然,还有 -o,表示输出的意思,用来指定编译后生成文件的名字。
  -Wall表示打开所有警告,有时候编译器会认为一些不规范的写法影响不大,并不会提示出来,加上Wall,会把这些不重要的警告也打印出来。
hello.c
#include
int main()
    int i;
    return 0;
  不打开警告编译:
root@Turbo:test# gcc hello.c -o hello
root@Turbo:test#
  打开警告编译:
root@Turbo:test# gcc hello.c -o hello -Wall
hello.c: In function ‘main’:
hello.c:5:6: warning: unused variable ‘i’ [-Wunused-variable]
    5 |  int i;
root@Turbo:test#
  -D表示添加宏定义,调试代码的时候非常有用,可以避免每次都要修改代码。
hello.c
#include
int main()
#ifdef HELLO
    printf("helloworld
#endif
    return 0;
编译不提供宏定义:
  运行结果:
root@Turbo:test#
  编译提供宏定义:
root@Turbo:test# gcc hello.c -o hello -DHELLO
root@Turbo:test#
  运行结果:
helloworld
审核编辑:刘清
