【米尔瑞萨RZ/G2L开发板-试用体验】创建TCP服务器
创建tcp服务
在虚拟机上新建tcp_server.c:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define SERVER_PORT 3861
#define LISENT_NUM 10
int main(int argc, char * argv[])
    int sfd, cfd;
    struct sockaddr_in clientaddr;
    struct sockaddr_in serverAddr;
    char buff[1024];
    int size = sizeof(struct sockaddr);
    pthread_t client_thread[LISENT_NUM];
    if((sfd = socket(AF_INET, SOCK_STREAM, 0)) == -1)
        perror("socket");
        exit(-1);
    memset(&serverAddr, 0, sizeof(struct sockaddr));
    serverAddr.sin_family = AF_INET;
    serverAddr.sin_addr.s_addr = INADDR_ANY;
    serverAddr.sin_port = htons(SERVER_PORT);
    if (bind(sfd, (struct sockaddr*)&serverAddr, sizeof(struct sockaddr)) == -1)
		perror("bind");
		close(sfd);
		exit(-1);
    if(listen(sfd, LISENT_NUM) == -1)
        perror("listen");
        close(sfd);
        exit(-1);
    printf("#@ listen SERVER_PORT %d\\n", SERVER_PORT);
    printf("main: server waiting connect...\\n");
    if ((cfd = accept(sfd, (struct sockaddr *)&clientaddr, (socklen_t*)&size)) == -1)
		perror("accept");
		close(sfd);
		return0;
    printf("client (ip = %s : SERVER_PORT = %d) connect success\\n", inet_ntoa(clientaddr.sin_addr), ntohs(clientaddr.sin_port));
    while (1)
        usleep(1000*10);
        if (send(cfd, "hello MYD/YG2L", 6, MSG_NOSIGNAL) == -1)
            perror("send");
            exit(-1);
        printf("send: hello MYD/YG2L\\n");
        usleep(1000*10);
        if(recv(cfd, buff, sizeof(buff), 0) == -1)
            perror("recv");
            exit(-1);
        printf("receive: %s\\n", buff);
    return0;
  1. 加载sdk:source /opt/yg2lx/environment-setup-aarch64-poky-linux
  2. 编译:
lugl@lugl-virtual-machine:~/MYDG2L$ source /opt/yg2lx/environment-setup-aarch64-poky-linux
lugl@lugl-virtual-machine:~/MYDG2L$ $CC tcp_server.c -o tcp_server
In file included from /opt/yg2lx/sysroots/aarch64-poky-linux/usr/include/bits/libc-header-start.h:33,
                 from /opt/yg2lx/sysroots/aarch64-poky-linux/usr/include/stdio.h:27,
                 from tcp_server.c:1:
/opt/yg2lx/sysroots/aarch64-poky-linux/usr/include/features.h:397:4: warning: #warning _FORTIFY_SOURCE requires compiling with optimization (-O) [-Wcpp]
 #  warning _FORTIFY_SOURCE requires compiling with optimization (-O)
lugl@lugl-virtual-machine:~/MYDG2L$ ls
tcp_server  tcp_server.c
lugl@lugl-virtual-machine:~/MYDG2L$ file tcp_server
tcp_server: ELF 64-bit LSB shared object, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-aarch64.so.1, for GNU/Linux 3.14.0, BuildID[sha1]=c81069580d81fc0f4ac9bb00ecdd7ddf822e251f, with debug_info, not stripped
  1. 上传开发板,修改执行权限后运行:
root@myir-yg2lx:~# chmod 777 tcp_server
root@myir-yg2lx:~# ./tcp_server
#@ listen SERVER_PORT 3861
client (ip = 192.168.3.166 : SERVER_PORT = 53634) connect success
receive: hello
receive: hello
receive: hello MYD
  1. 打开TCP调试工具,连上服务器:
    TCP
发送数据后,服务器打印出接收到的数据,客户端也接收到数据。
  • 相关推荐
  • TCP
