【CW32饭盒派开发板试用体验】串口实验
串口选择
示例给出的是串口的,因为今天回老家,带的杜绑线是公对母的,不能接串口1,所以选择串口2,即PA2--TX,PA3--RX。
初始化串口
  1. 初始化UART2的时钟:__RCC_UART2_CLK_ENABLE();
  2. 初始化GPIOA外设时钟:RCC_AHBPeriphClk_Enable( RCC_AHB_PERIPH_GPIOA, ENABLE);
  3. 复用PA2为UART2TX: PA02_AFx_UART2TXD();
  4. 复用PA3为UART2RX:PA03_AFx_UART2RXD();
  5. 初始化PA2为高速输出模式:
GPIO_InitStructure.Pins = GPIO_PIN_2; //PA2
  GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
  GPIO_Init(CW_GPIOA, &GPIO_InitStructure);
  1. 初始化PA3为上拉输入:
GPIO_InitStructure.Pins = GPIO_PIN_3; //PA3
  GPIO_InitStructure.Mode = GPIO_MODE_INPUT_PULLUP;
  1. 初始化UART2配置为9600波特率:
USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_Over = USART_Over_16;
  USART_InitStructure.USART_Source = USART_Source_PCLK;
  USART_InitStructure.USART_UclkFreq = 64000000;
  USART_InitStructure.USART_StartBit = USART_StartBit_FE;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(CW_UART2, &USART_InitStructure);
  1. 使能中断输入
//使能UARTx RC中断
  USART_ITConfig(CW_UART2, USART_IT_RC, ENABLE);
  //优先级,无优先级分组
  NVIC_SetPriority(UART2_IRQn, 0);
  //UARTx中断使能
  NVIC_EnableIRQ(UART2_IRQn);
  1. 中断接收函数,主要功能为判断接收到的第一位是否为0,第二位是否为1,如果总接收长度为4位,测翻转LED4,具体代码如下:
void UART2_IRQHandler(void)
  /* USER CODE BEGIN */
  unsigned char TxRxBuffer;
  if(USART_GetITStatus(CW_UART2, USART_IT_RC) != RESET)
		USART_ClearITPendingBit(CW_UART2, USART_IT_RC);
    TxRxBuffer = USART_ReceiveData_8bit(CW_UART2);
			rec[re_count]=TxRxBuffer;
		 if (re_count == 0&&rec[0]==0x00)
				rev_start=1;
				re_count++;
			else if(rev_start==1)
				if(re_count==1&&rec[1]!=0x01)
					re_count=0;rev_start=0;
				else if(re_count==4)           //计算总个数,0-4
			      {check_flag=1;re_count=0;rev_start=0;}	  //如果对,那么将标志位置1,并清除里面的值从新接收
				else
				   re_count++;
  /* USER CODE END */
实现效果,下载后,串口接收到0x00 0x01 0x02 0x03 ,HEX发送00 01 02 03 可以实现LED4的翻转:
串口
审核编辑:汤梓红
