路由表的介绍与查看
路由表的介绍
在思科(Cisco)系列路由器上,show ip route 这个命令是一个非常常用并且十分重要的命令。里面可以查看该设备的当前直连的或者学习到的全部路由信息,即路由表:routing table。
R2#show ip route ?
  WORD       Network to display information about or hostname   #显示有关或主机名的信息的网络
  bgp        Border Gateway Protocol (BGP)                      #BGP协议是用于自治系统AS之间的动态路由协议
  connected  Connected   #直连
  eigrp      Enhanced Interior Routing Protocol (EIGRP)   #EIGRP协议是一种综合的路由选择协议
  ospf       Open Shortest Path First (OSPF)              #OSPF是一种链路状态型路由选择协议
  rip        Routing Information Protocol (RIP)           #RIP动态路由选择协议
  static     Static routes         #静态路由
  summary    Summary of all routes #所有路线汇总
  |          Output Modifiers
若需使用该命令,你应当通过命令行进入路由器的执行模式(EXEC mode),其输出结果会按行列出:具体的路由条目,路由类型,管理距离(administrative distance),相邻路由器地址,获得该路由信息的物理端口名等信息。Show ip route可以简化为:sh ip ro,在进行路由配置、排错时,它是一个非常重要、实用的必备工具。
路由表的查看
show ip route
R2#show ip route      #查看路由表
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
O       1.1.1.1/32 [110/2] via 10.0.0.1, 0110, GigabitEthernet0/0
     2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       2.2.2.0/24 is directly connected, Loopback0
L       2.2.2.2/32 is directly connected, Loopback0
     3.0.0.0/32 is subnetted, 1 subnets
O IA    3.3.3.3/32 [110/2] via 20.0.0.2, 0153, GigabitEthernet0/1
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.0.0.0/24 is directly connected, GigabitEthernet0/0
L       10.0.0.2/32 is directly connected, GigabitEthernet0/0
     20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       20.0.0.0/24 is directly connected, GigabitEthernet0/1
L       20.0.0.1/32 is directly connected, GigabitEthernet0/1
O IA 192.168.10.0/24 [110/2] via 10.0.0.1, 0139, GigabitEthernet0/0
O IA 192.168.20.0/24 [110/2] via 20.0.0.2, 0153, GigabitEthernet0/1
在show ip route命令的输出中,会列出关于路由类型的简写代码,包括:I, R, O, C, S, E, B, i等。它们的含义分别为:
I,指从内部网关协议(IGRP)中学到的路由。
R,从RIP协议中学到的路由。
O,从OSPF(开放式最短路径优先)协议学到。
C,直连路由。
S,静态配置的路由,请注意,静态路由的管理距离为 0。
E,从外部网关协议(EGP)学到的路由。
B,指从BGP协议、
I,指IS-IS协议学到的路由信息。
C直接相连connected
C是connected直接相连的意思,10.0.0.0/24是直连的网段,24是255.255.255.0的缩写,要转发数据包到10.0.0.0/24网段,通过GigabitEthernet0/0接口转发。
R2#show ip route connected    #仅查看路由表中的直连
R - RIP协议
R 192.168.3.0/24 [120/1] via 192.168.65.2, 0004, Serial2/0
这条例子中没有。
R是RIP协议,通过动态路由协议RIP学到的路由,
192.168.3.0/24就是学到的路由
[120/1]即[管理距离/度量值(此数为路由跳数)],是度量值和管理距离,也就是优先级的意思。
via 192.168.65.2 via 有“经由”的意思,一般路由表中理解为“下一跳” ,指下一跳的接口IP地址为192.168.65.2,就是你要发送数据包到下个路由器的接口,从Seria2/0口转发。
S-静态路由
静态配置的路由,请注意,静态路由的管理距离为 0。如果要单独显示,用下面的命令
show ip route static
O-OSPF学到的路由
show ip route ospf
  审核编辑:汤梓红
