触觉智能RK3568_OpenHarmony开发板适配
1.2w人已加入
开发板
2023-5-24 master openharmony 4.0.7.3
openharmony版本更新代码会变化,请看当前文件夹其他md
准备环境
确保无任何修改能编译RK3568
docker run -it -v $(pwd):/home/openharmony swr.cn-south-1.myhuaweicloud.com/openharmony-docker/openharmony-docker:1.0.0
编译方式
./build.sh --product-name rk3568
如果出现
root@3de51292b422:/home/openharmony# hb build -f
[OHOS INFO] Set cache size limit to 100.0 GB
[OHOS INFO] root_out_dir=//out/rk3568
[OHOS INFO] root_build_dir=//out/rk3568
[OHOS INFO] root_gen_dir=//out/rk3568/gen
[OHOS INFO] current_toolchain=//build/toolchain/ohos:ohos_clang_arm
[OHOS INFO] host_toolchain=//build/toolchain/linux:clang_x64
[OHOS INFO] build configs generation is complete.
[OHOS INFO] ERROR at //build/core/gn/BUILD.gn:59:14: Unable to load "/home/openharmony/out/rk3568/build_configs/BUILD.gn".
[OHOS INFO]     deps = [ "$root_build_dir/build_configs:inner_kits" ]
[OHOS INFO]              ^-----------------------------------------
[OHOS INFO] ---------------------------------------------
[OHOS INFO] ccache summary:
[OHOS INFO] cache hit (direct)  : 0
[OHOS INFO] cache hit (preprocessed)  : 0
[OHOS INFO] cache miss  : 0
[OHOS INFO] hit rate:  0.00%
[OHOS INFO] mis rate: 0.00%
[OHOS INFO] file: /home/openharmony/out/rk3568/.ninja_log not exists
[OHOS INFO] parse file fail
[OHOS ERROR] Please check build log in /home/openharmony/out/rk3568/build.log
请执行下面的命令安装新版本
python -m pip uninstall ohos-build
python -m pip install --user build/hb
适配
复制下面三个文件到device/board/hihope/rk3568/kernel
开发板
开发板
修改build_kernel.sh文件
开发板
开发板
修改make-ohos.sh文件
开发板
文件完整内容
device/board/hihope/rk3568/kernel/build_kernel.sh
#!/bin/bash
# Copyright (c) 2021-2023 HiHope Open Source Organization .
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
#     http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
set -e
pushd ${1}
ROOT_DIR=${5}
export PRODUCT_PATH=${4}
export DEVICE_COMPANY=${6}
export DEVICE_NAME=${7}
export PRODUCT_COMPANY=${8}
KERNEL_FORM=${9}
KERNEL_PROD=${10}
ENABLE_LTO_O0=${11}
KERNEL_SRC_TMP_PATH=${ROOT_DIR}/out/kernel/src_tmp/linux-5.10
KERNEL_OBJ_TMP_PATH=${ROOT_DIR}/out/kernel/OBJ/linux-5.10
KERNEL_SOURCE=${ROOT_DIR}/kernel/linux/linux-5.10
KERNEL_PATCH_PATH=${ROOT_DIR}/kernel/linux/patches/linux-5.10
KERNEL_PATCH=${ROOT_DIR}/kernel/linux/patches/linux-5.10/rk3568_patch/kernel.patch
BUILD_SCRIPT_PATH=${3}
NEWIP_PATCH_FILE=${ROOT_DIR}/kernel/linux/common_modules/newip/apply_newip.sh
XPM_PATCH_FILE=${ROOT_DIR}/kernel/linux/common_modules/xpm/apply_xpm.sh
KERNEL_CONFIG_FILE=${ROOT_DIR}/device/board/hihope/rk3568/kernel/rk3568_standard_defconfig
KERNEL_DTS_FILE=${ROOT_DIR}/device/board/hihope/rk3568/kernel/ido-evb3568-hdmi.dts
KERNEL_DTSI_FILE=${ROOT_DIR}/device/board/hihope/rk3568/kernel/ido-som3568.dtsi
KERNEL_MAKE_OHOS_FILE=${ROOT_DIR}/device/board/hihope/rk3568/kernel/make-ohos.sh
HARMONY_CONFIG_PATH=${ROOT_DIR}/kernel/linux/config/linux-5.10
DEVICE_CONFIG_PATH=${ROOT_DIR}/kernel/linux/config/linux-5.10/${DEVICE_NAME}
DEFCONFIG_BASE_FILE=${HARMONY_CONFIG_PATH}/base_defconfig
DEFCONFIG_TYPE_FILE=${HARMONY_CONFIG_PATH}/type/standard_defconfig
DEFCONFIG_FORM_FILE=${HARMONY_CONFIG_PATH}/form/${KERNEL_FORM}_defconfig
DEFCONFIG_ARCH_FILE=${DEVICE_CONFIG_PATH}/arch/arm64_defconfig
DEFCONFIG_PROC_FILE=${DEVICE_CONFIG_PATH}/product/${KERNEL_PROD}_defconfig
RAMDISK_ARG="disable_ramdisk"
MAKE_OHOS_ENV="GPUDRIVER=mali"
export KBUILD_OUTPUT=${KERNEL_OBJ_TMP_PATH}
source ${BUILD_SCRIPT_PATH}/kernel/kernel_source_checker.sh
for i in "$@"
do
    case $i in
        enable_ramdisk)
            RAMDISK_ARG=enable_ramdisk
        enable_mesa3d)
            MAKE_OHOS_ENV="GPUDRIVER=mesa3d"
    esac
done
function copy_and_patch_kernel_source()
    rm -rf ${KERNEL_SRC_TMP_PATH}
    mkdir -p ${KERNEL_SRC_TMP_PATH}
    rm -rf ${KERNEL_OBJ_TMP_PATH}
    mkdir -p ${KERNEL_OBJ_TMP_PATH}
    cp -arf ${KERNEL_SOURCE}/* ${KERNEL_SRC_TMP_PATH}/
    cd ${KERNEL_SRC_TMP_PATH}
    #HDF patch
    bash ${ROOT_DIR}/drivers/hdf_core/adapter/khdf/linux/patch_hdf.sh ${ROOT_DIR} ${KERNEL_SRC_TMP_PATH} ${KERNEL_PATCH_PATH} ${DEVICE_NAME}
    #kernel patch
    patch -p1 < ${KERNEL_PATCH}
    #newip
    if [ -f $NEWIP_PATCH_FILE ]; then
        bash $NEWIP_PATCH_FILE ${ROOT_DIR} ${KERNEL_SRC_TMP_PATH} ${DEVICE_NAME} linux-5.10
    fi
    #xpm
    if [ -f $XPM_PATCH_FILE ]; then
        bash $XPM_PATCH_FILE ${ROOT_DIR} ${KERNEL_SRC_TMP_PATH} ${DEVICE_NAME} linux-5.10
    fi
    cp -rf ${BUILD_SCRIPT_PATH}/kernel/logo* ${KERNEL_SRC_TMP_PATH}/
    #config
    if [ ! -f "$DEFCONFIG_FORM_FILE" ]; then
        echo "warning no form config file $(DEFCONFIG_FORM_FILE)"
    fi
    if [ ! -f "$DEFCONFIG_PROC_FILE" ]; then
        echo "warning no prod config file $(DEFCONFIG_PROC_FILE)"
    fi
    bash ${ROOT_DIR}/kernel/linux/linux-5.10/scripts/kconfig/merge_config.sh -O ${KERNEL_SRC_TMP_PATH}/arch/arm64/configs/ -m ${DEFCONFIG_TYPE_FILE} ${DEFCONFIG_FORM_FILE} ${DEFCONFIG_ARCH_FILE} ${DEFCONFIG_PROC_FILE} ${DEFCONFIG_BASE_FILE}
    mv ${KERNEL_SRC_TMP_PATH}/arch/arm64/configs/.config ${KERNEL_SRC_TMP_PATH}/arch/arm64/configs/rockchip_linux_defconfig
    # cp -rf ${KERNEL_DTS_FILE} ${KERNEL_SRC_TMP_PATH}/arch/arm64/boot/dts/rockchip/ido-evb3568-hdmi.dts
    # cp -rf ${KERNEL_DTSI_FILE} ${KERNEL_SRC_TMP_PATH}/arch/arm64/boot/dts/rockchip/ido-som3568.dtsi
    # cp -rf ${KERNEL_MAKE_OHOS_FILE} ${KERNEL_SRC_TMP_PATH}/make-ohos.sh
    #selinux config patch
    for arg in "$@"; do
        if [ "$arg" = "is_release" ]; then
            echo "close selinux kernel config CONFIG_SECURITY_SELINUX_DEVELOP in release version"
            ${KERNEL_SOURCE}/scripts/config --file ${KERNEL_SRC_TMP_PATH}/arch/arm64/configs/rockchip_linux_defconfig -d SECURITY_SELINUX_DEVELOP
        fi
    done
    if [ $MAKE_OHOS_ENV == "GPUDRIVER=mesa3d" ]; then
        python ${ROOT_DIR}/third_party/mesa3d/ohos/modifyDtsi.py ${KERNEL_SRC_TMP_PATH}/arch/arm64/boot/dts/rockchip/rk3568.dtsi
    fi
set +e
is_kernel_change ${ROOT_DIR}
KERNEL_SOURCE_CHANGED=$?
set -e
if [ ${KERNEL_SOURCE_CHANGED}  -ne 0 ]; then
    echo "kernel or it's deps changed, start source update."
else
    echo "no changes to kernel, skip source copy."
fi
eval $MAKE_OHOS_ENV ./make-ohos.sh EVB3568 $RAMDISK_ARG ${ENABLE_LTO_O0}
mkdir -p ${2}
if [ "enable_ramdisk" != "${12}" ]; then
    cp ${KERNEL_OBJ_TMP_PATH}/boot_linux.img ${2}/boot_linux.img
fi
cp ${KERNEL_OBJ_TMP_PATH}/resource.img ${2}/resource.img
cp ${3}/loader/MiniLoaderAll.bin ${2}/MiniLoaderAll.bin
cp ${3}/loader/uboot.img ${2}/uboot.img
if [ "enable_absystem" == "${14}" ]; then
    cp ${3}/loader/parameter_ab.txt ${2}/parameter_ab.txt
    cp ${3}/loader/config_ab.cfg ${2}/config_ab.cfg
else
    cp ${3}/loader/parameter.txt ${2}/parameter.txt
    cp ${3}/loader/config.cfg ${2}/config.cfg
fi
popd
../kernel/src_tmp/linux-5.10/make-boot.sh ..
    cp ${ROOT_DIR}/out/kernel/checkpoint/last_build.info ${ROOT_DIR}/out/kernel/checkpoint/last_build.backup
    cp ${ROOT_DIR}/out/kernel/checkpoint/current_build.info ${ROOT_DIR}/out/kernel/checkpoint/last_build.info
    echo "kernel compile finish, save build info."
else
    echo "kernel compile finish."
fi
#!/bin/bash
set -e
SCRIPTPATH=$(dirname $realpath "$0")
export PATH=$(realpath $SCRIPTPATH/../../../../)/prebuilts/clang/ohos/linux-x86_64/llvm/bin/:$(realpath $SCRIPTPATH/../../../../)/prebuilts/develop_tools/pahole/bin/:$PATH
export PRODUCT_PATH=vendor/hihope/rk3568
IMAGE_SIZE=64  # 64M
IMAGE_BLOCKS=4096
ENABLE_LTO_O0=${3}
CPUs=`sed -n "N;/processor/p" /proc/cpuinfo|wc -l`
MAKE="make LLVM=1 LLVM_IAS=1 CROSS_COMPILE=aarch64-linux-gnu-"
[ "${ENABLE_LTO_O0}" == "enable_lto_O0" ] && MAKE="${MAKE} KCFLAGS=-Wl,--lto-O0"
BUILD_PATH=boot_linux
EXTLINUX_PATH=${BUILD_PATH}/extlinux
EXTLINUX_CONF=${EXTLINUX_PATH}/extlinux.conf
TOYBRICK_DTB=toybrick.dtb
if [ ${KBUILD_OUTPUT} ]; then
	OBJ_PATH=${KBUILD_OUTPUT}/
fi
ID_MODEL=1
ID_ARCH=2
ID_UART=3
ID_DTB=4
ID_IMAGE=5
ID_CONF=6
model_list=(
	"EVB3568  arm64 0xfe660000 ido-evb3568-hdmi Image rockchip_linux_defconfig"
	"TB-RK3568X0   arm64 0xfe660000 rk3568-toybrick-x0-linux  Image rockchip_linux_defconfig"
	"TB-RK3568X10  arm64 0xfe660000 rk3568-toybrick-x10-linux Image rockchip_linux_defconfig"
function help()
	echo "Usage: ./make-ohos.sh {BOARD_NAME}"
	echo "e.g."
	for i in "${model_list[@]}"; do
		echo "  ./make-ohos.sh $(echo $i | awk '{print $1}')"
	done
function make_extlinux_conf()
	dtb_path=$1
	uart=$2
	image=$3
	echo "label rockchip-kernel-5.10" > ${EXTLINUX_CONF}
	echo "	kernel /extlinux/${image}" > > ${EXTLINUX_CONF}
	echo "	fdt /extlinux/${TOYBRICK_DTB}" > > ${EXTLINUX_CONF}
	cmdline="append earlycon=uart8250,mmio32,${uart} root=PARTUUID=614e0000-0000-4b53-8000-1d28000054a9 rw rootwait rootfstype=ext4"
	echo "  ${cmdline}" > > ${EXTLINUX_CONF}
function make_kernel_image()
	arch=$1
	conf=$2
	dtb=$3
	if [ "$GPUDRIVER" == "mesa3d" ]; then
		config_base="arch/${arch}/configs/${conf}"
		config_frag="../../../../device/soc/rockchip/panfrost.config"
		ARCH=${arch} ./scripts/kconfig/merge_config.sh ${config_base} ${config_frag}
	else
		${MAKE} ARCH=${arch} ${conf}
	fi
	if [ $? -ne 0 ]; then
		echo "FAIL: ${MAKE} ARCH=${arch} ${conf}"
		return -1
	fi
	${MAKE} ARCH=${arch} ${dtb}.img -j${CPUs}
		echo "FAIL: ${MAKE} ARCH=${arch} ${dtb}.img"
		return -2
	fi
	return 0
function make_ext2_image()
	blocks=${IMAGE_BLOCKS}
	block_size=$((${IMAGE_SIZE} * 1024 * 1024 / ${blocks}))
	if [ "`uname -m`" == "aarch64" ]; then
		echo y | sudo mke2fs -b ${block_size} -d boot_linux -i 8192 -t ext2 boot_linux.img ${blocks}
	else
		genext2fs -B ${blocks} -b ${block_size} -d boot_linux -i 8192 -U boot_linux.img
	fi
	return $?
function make_boot_linux()
	arch=${!ID_ARCH}
	uart=${!ID_UART}
	dtb=${!ID_DTB}
	image=${!ID_IMAGE}
	conf=${!ID_CONF}
	if [ ${arch} == "arm" ]; then
		dtb_path=arch/arm/boot/dts
	else
		dtb_path=arch/arm64/boot/dts/rockchip
	fi
	rm -rf ${BUILD_PATH}
	mkdir -p ${EXTLINUX_PATH}
	make_kernel_image ${arch} ${conf} ${dtb}
		exit 1
	fi
	make_extlinux_conf ${dtb_path} ${uart} ${image}
	cp -f ${OBJ_PATH}arch/${arch}/boot/${image} ${EXTLINUX_PATH}/
	cp -f ${OBJ_PATH}${dtb_path}/${dtb}.dtb ${EXTLINUX_PATH}/${TOYBRICK_DTB}
	cp -f logo*.bmp ${BUILD_PATH}/
	if [ "enable_ramdisk" != "${ramdisk_flag}" ]; then
		make_ext2_image
	fi
ramdisk_flag=$2
found=0
	if [ "$(echo $i | awk '{print $1}')" == "$1" ]; then
		make_boot_linux $i
		found=1
	fi
done
