HI-8570PSIF 产品详情
HI-8570PSIF  产品资料 HI-8570PSIF 特价HI-8570PSIF
HI-8570PSIF 芯片详细信息
  • Manufacturer Part Number:
HI-8570PSIF
  • Pbfree Code:
Yes
  • Rohs Code:
Yes
  • Part Life Cycle Code:
Active
  • Part Package Code:
SOIC
  • Package Description:
HLSOP, SOP8,.25
  • Pin Count:
8
  • Reach Compliance Code:
compliant
  • ECCN Code:
EAR99
  • HTS Code:
8542.39.00.01
  • Manufacturer:
Holt Integrated Circuits Inc
  • Risk Rank:
5.61
  • Differential Output:
YES
  • Driver Number of Bits:
1
  • High Level Input Current-Max:
1e-7 A
  • Input Characteristics:
STANDARD
  • Interface IC Type:
LINE DRIVER
  • Interface Standard:
ARINC 429
  • JESD-30 Code:
R-PDSO-G8
  • JESD-609 Code:
e3
  • Length:
4.915 mm
  • Moisture Sensitivity Level:
1
  • Negative Supply Voltage-Nom:
-5 V
  • Number of Functions:
2
  • Number of Terminals:
8
  • Operating Temperature-Max:
85 °C
  • Operating Temperature-Min:
-40 °C
  • Out Swing-Min:
9 V
  • Package Body Material:
PLASTIC/EPOXY
  • Package Code:
HLSOP
  • Package Equivalence Code:
SOP8,.25
  • Package Shape:
RECTANGULAR
  • Package Style:
SMALL OUTLINE, HEAT SINK/SLUG, LOW PROFILE
  • Peak Reflow Temperature (Cel):
260
  • Power Supplies:
+-5 V
  • Qualification Status:
Not Qualified
  • Seated Height-Max:
1.626 mm
  • Subcategory:
Line Driver or Receivers
  • Supply Voltage-Max:
5.3 V
  • Supply Voltage-Min:
4.8 V
  • Supply Voltage-Nom:
5 V
  • Surface Mount:
YES
  • Technology:
CMOS
  • Temperature Grade:
INDUSTRIAL
  • Terminal Finish:
Matte Tin (Sn)
  • Terminal Form:
GULL WING
  • Terminal Pitch:
1.27 mm
  • Terminal Position:
DUAL
  • Time@Peak Reflow Temperature-Max (s):
40
  • Width:
3.9 mm
芯片
