【英飞凌PSoC 6 RTT开发板试用】语音识别之二:音频采集
一. 音频采集
原理图
从原理图看到有6路模拟输入,分别对应
P10.0~P10.5, VREF为模拟参考电压。
PSoC
PSoC
使用的是MAX4466的MIC,接到ADC0,如下图所示
PSoC
PSoC
PSoC
配置模拟采集引脚
PSoC
代码
Adc.c
#include "cy_pdl.h"
#include "cyhal.h"
#include "cybsp.h"
#include "cy_retarget_io.h"
#define VPLUS_CHANNEL_0  (P10_0)
/* Conversion factor */
#define MICRO_TO_MILLI_CONV_RATIO        (1000u)
/* Acquistion time in nanosecond */
#define ACQUISITION_TIME_NS              (116680u)
/* ADC Scan delay in millisecond */
#define ADC_SCAN_DELAY_MS                (200u)
*       Enumerated Types
/* ADC Channel constants*/
enum ADC_CHANNELS
  CHANNEL_0 = 0,
  NUM_CHANNELS
} adc_channel;
* Global Variables
/* ADC Object */
cyhal_adc_t adc_obj;
/* ADC Channel 0 Object */
cyhal_adc_channel_t adc_chan_0_obj;
/* Default ADC configuration */
const cyhal_adc_config_t adc_config = {
        .continuous_scanning=false, // Continuous Scanning is disabled
        .average_count=1,           // Average count disabled
        .vref=CYHAL_ADC_REF_VDDA,   // VREF for Single ended channel set to VDDA
        .vneg=CYHAL_ADC_VNEG_VSSA,  // VNEG for Single ended channel set to VSSA
        .resolution = 12u,          // 12-bit resolution
        .ext_vref = NC,             // No connection
        .bypass_pin = NC };       // No connection
/* Asynchronous read complete flag, used in Event Handler */
static bool async_read_complete = true;
#define NUM_SCAN                    (1000)
#define NUM_CHANNELS                (1)
/* Variable to store results from multiple channels during asynchronous read*/
int32_t result_arr[NUM_CHANNELS * NUM_SCAN] = {0};
static void adc_event_handler(void* arg, cyhal_adc_event_t event)
    if(0u != (event & CYHAL_ADC_ASYNC_READ_COMPLETE))
        /* Set async read complete flag to true */
int adc_init(void)
    /* Variable to capture return value of functions */
    cy_rslt_t result;
    /* Initialize ADC. The ADC block which can connect to the channel 0 input pin is selected */
    result = cyhal_adc_init(&adc_obj, VPLUS_CHANNEL_0, NULL);
    if(result != CY_RSLT_SUCCESS)
        printf("ADC initialization failed. Error: %ld\\n", (long unsigned int)result);
        CY_ASSERT(0);
    /* ADC channel configuration */
    const cyhal_adc_channel_config_t channel_config = {
            .enable_averaging = false,  // Disable averaging for channel
            .min_acquisition_ns = ACQUISITION_TIME_NS, // Minimum acquisition time set to 1us
            .enabled = true };          // Sample this channel when ADC performs a scan
    /* Initialize a channel 0 and configure it to scan the channel 0 input pin in single ended mode. */
    result  = cyhal_adc_channel_init_diff(&adc_chan_0_obj, &adc_obj, VPLUS_CHANNEL_0,
                                          CYHAL_ADC_VNEG, &channel_config);
        printf("ADC first channel initialization failed. Error: %ld\\n", (long unsigned int)result);
        CY_ASSERT(0);
    /* Register a callback to handle asynchronous read completion */
     cyhal_adc_register_callback(&adc_obj, &adc_event_handler, result_arr);
     /* Subscribe to the async read complete event to process the results */
     cyhal_adc_enable_event(&adc_obj, CYHAL_ADC_ASYNC_READ_COMPLETE, CYHAL_ISR_PRIORITY_DEFAULT, true);
     printf("ADC is configured in multichannel configuration.\\r\\n\\n");
     printf("Channel 0 is configured in single ended mode, connected to the \\r\\n");
     printf("channel 0 input pin. Provide input voltage at the channel 0 input pin \\r\\n");
     return 0;
int adc_samp(void)
    cy_rslt_t result;
    /* Variable to store ADC conversion result from channel 0 */
    int32_t adc_result_0 = 0;
        /* Clear async read complete flag */
        async_read_complete = false;
        /* Initiate an asynchronous read operation. The event handler will be called
         * when it is complete. */
        memset(result_arr,0,sizeof(result_arr));
        cyhal_gpio_write_internal(CYBSP_USER_LED,true);
        result = cyhal_adc_read_async_uv(&adc_obj, NUM_SCAN, result_arr);
            printf("ADC async read failed. Error: %ld\\n", (long unsigned int)result);
            CY_ASSERT(0);
        while(async_read_complete == false);
        cyhal_gpio_write_internal(CYBSP_USER_LED,false);
         * Read data from result list, input voltage in the result list is in
         * microvolts. Convert it millivolts and print input voltage
        for(int i=0; i< NUM_SCAN; i++)
            adc_result_0 = result_arr[i] / MICRO_TO_MILLI_CONV_RATIO;
            printf("/*%4ld*/\\r\\n", (long int)adc_result_0);
    return 0;
Adc.h
#ifndef ADC_H
#define ADC_H
int adc_init(void);
int adc_samp(void);
#endif
Main.c调用
adc_init();
adc_samp();
时钟源
时钟源是100Mhz,12分频=8.33M,满足1.8MHz~18MHz之间的要求
默认是按照8M配置
PSoC
PSoC
采样时间
采样前后翻转LED用示波器测量时间
int adc_samp(void)
    cy_rslt_t result;
            CY_ASSERT(0);
    return 0;
采样1000次,分别设置采样时间为2uS和1uS对比。
#define ACQUISITION_TIME_NS (2000u)
10.28mS
PSoC
#define ACQUISITION_TIME_NS (1000u)
9.32mS
PSoC
10.28-9.32=0.96mS 1000次约1mS,1次刚好是1uS。
而1000次除去采样时间其他时间为8.32mS,即一次8.32uS。
因为前面设置了时钟为8.33MHz, 从前面时序一节可以看到,除去采样时间,其他转换时间等需要14个CLK,所以需要14/8.33uS=1.7uS. 剩余的8.32-1.7为数据搬运,软件处理等时间。
采样值正确性
1.545V和示波器采集为1.54V差不多是正确的,这里没有高精度的万用表就不对测试精度了,只测试了正确性。
PSoC
PSoC
音频采集
一次采集1000次然后串口打印,使用SerialStudio可视化显示
int adc_samp(void)
    cy_rslt_t result;
            CY_ASSERT(0);
    return 0;
串口打印到PC,可视化显示如下
PSoC
  审核编辑:汤梓红
