Milk-V Duo开发板免费体验 编译环境搭建
1.2w人已加入
整体来说环境搭建还是比较简单的,我用的是wsl的ubuntu 18.04,直接下载了duo-buildroot-sdk-20230616.zip这个基于buildroot的SDK,然后确保安装了cmake、device-tree-compiler、ninja、mtools、genext2fs等工具,原则上就是报错缺什么就装什么。
通过命令unzip duo-buildroot-sdk-20230616.zip -d ~/work/milkv/duo解压duo-buildroot-sdk-20230616.zip到~/work/milkv/duo文件夹里面。
硬件设计
然后通过运行build_milkv.sh进行编译和构建镜像,build_milv.sh脚本的内容如下:
#!/bin/bash
MILKV_BOARD_ARRAY=
MILKV_BOARD_ARRAY_LEN=
MILKV_BOARD=
MILKV_BOARD_CONFIG=
MILKV_BOARD_DIR=milkv
function print_info()
  printf "e[1;32m%se[0mn" "$1"
function print_err()
  printf "e[1;31mError: %se[0mn" "$1"
# 自动检测并下载工具集
function get_toolchain()
  if [ ! -d host-tools ]; then
    print_info "Toolchain does not exist, download it now..."
    toolchain_url="https://sophon-file.sophon.cn/sophon-prod-s3/drive/23/03/07/16/host-tools.tar.gz"
    echo "toolchain_url: ${toolchain_url}"
    toolchain_file=${toolchain_url##*/}
    echo "toolchain_file: ${toolchain_file}"
    wget ${toolchain_url} -O ${toolchain_file}
    if [ $? -ne 0 ]; then
      print_err "Failed to download ${toolchain_url} !"
      exit 1
    fi
    if [ ! -f ${toolchain_file} ]; then
      print_err "${toolchain_file} not found!"
      exit 1
    fi
    print_info "Extracting ${toolchain_file}..."
    tar -xf ${toolchain_file}
      print_err "Extract ${toolchain_file} failed!"
      exit 1
    fi
    [ -f ${toolchain_file} ] && rm -rf ${toolchain_file}
  fi
# 这里得到了支持的板子MILKV_BOARD_ARRAY=milkv-duo
function get_available_board()
  MILKV_BOARD_ARRAY=( $(cd ${MILKV_BOARD_DIR}/; ls boardconfig*.sh | sort | awk -F"[-.]" -v OFS='-' '{print $2, $3}') )
  #echo ${MILKV_BOARD_ARRAY[@]}
  MILKV_BOARD_ARRAY_LEN=${#MILKV_BOARD_ARRAY[@]}
  if [ $MILKV_BOARD_ARRAY_LEN -eq 0 ]; then
    echo "No available board config"
    exit 1
  fi
  #echo ${MILKV_BOARD_ARRAY[@]} | xargs -n 1 | sed "=" | sed "N;s/n/. /"
function choose_milkv_board()
  # TODO
  echo "choose"
function prepare_env()
  source ${MILKV_BOARD_CONFIG}
  source build/${MV_BUILD_ENV} > /dev/null 2 >&1
  defconfig ${MV_BOARD_LINK} > /dev/null 2 >&1
  echo "OUTPUT_DIR: ${OUTPUT_DIR}"  # @build/milkvsetup.sh
# 执行编译
function milkv_duo_build()
  # clean old img
  old_image_count=`ls ${OUTPUT_DIR}/*.img* | wc -l`
  if [ ${old_image_count} -ge 0 ]; then
    pushd ${OUTPUT_DIR}
    rm -rf *.img*
    popd
  fi
# 不需要重新编译的时候可以把clean_all注释掉,否则每次都会重新编译
  clean_all
  build_all
  if [ $? -eq 0 ]; then
    print_info "Build board ${MILKV_BOARD} success!"
  else
    print_err "Build board ${MILKV_BOARD} failed!"
    exit 1
  fi
# 打包镜像
function milkv_duo_pack()
  pack_sd_image
  [ ! -d out ] && mkdir out
  image_count=`ls ${OUTPUT_DIR}/*.img | wc -l`
  if [ ${image_count} -ge 0 ]; then
    mv ${OUTPUT_DIR}/*.img out/
    # rename milkv-duo.img file with time
    pushd out
    for img in *.img
    do
      if [ "${img}" == "${MILKV_BOARD}.img" ]; then
        mv $img ${MILKV_BOARD}-`date +%Y%m%d-%H%M`.img
      fi
    done
    popd
    # show latest img
    latest_img=`ls -t out/*.img | head -n1`
    if [ -z "${latest_img// }" ]; then
      print_err "Gen image failed!"
    else
      print_info "Gen image successful: ${latest_img}"
    fi
  else
    print_err "Create sd img failed!"
    exit 1
  fi
get_toolchain
get_available_board
if [ $MILKV_BOARD_ARRAY_LEN -eq 1 ]; then
  # Only one board
  print_info "Ready to build: ${MILKV_BOARD_ARRAY[0]}"
  MILKV_BOARD=${MILKV_BOARD_ARRAY[0]}
else
  # no arg
  if [ $# -lt 1 ]; then
    choose_milkv_board || exit 0
  fi
  # with board name
  if [ $# -ge 1 ]; then
    if [[ ${MILKV_BOARD_ARRAY[@]} =~ (^|[[:space:]])"${1}"($|[[:space:]]) ]]; then
      MILKV_BOARD=${1}
      echo "$MILKV_BOARD"
    else
      print_err "${1} not supported!"
      echo "Available boards: [ ${MILKV_BOARD_ARRAY[@]} ]"
      exit 1
    fi
  fi
fi
if [ -z "${MILKV_BOARD// }" ]; then
  print_err "No board specified!"
  exit 1
fi
export MILKV_BOARD="${MILKV_BOARD}"
MILKV_BOARD_CONFIG=${MILKV_BOARD_DIR}/boardconfig-${MILKV_BOARD}.sh
if [ ! -f ${MILKV_BOARD_CONFIG} ]; then
  print_err "${MILKV_BOARD_CONFIG} not found!"
  exit 1
fi
prepare_env
milkv_duo_build
milkv_duo_pack
脚本加了一些简单的注释,大体逻辑就是
  1. 检测并下载工具集;
  2. 选择板子;
  3. 根据板子到处环境;
  4. 执行编译;
  5. 构建镜像;
最后脚本执行完成会输出一个构建img成功的信息,如下图绿色的内容,时间戳会根据构建时间而不一样。
硬件设计
内核开发环境可以用了,可以学习内核代码了,可以通过Windows下的vscode进行编辑然后在vscode终端里面进行编译。
如果编译过程遇到类似'Your PATH contains spaces, TABs, and/or newline (n) characters.'的错误,是因为WSL默认会自动添加Windows环境变量到wsl中,可以通过关闭自动添加,或是重新设置PATH来解决。我是选择重新设置环境变量,即将带空格的windows环境变量删除,因为我需要使用windows下的vscode,如果关闭自动添加,就用不了windows下的软件了。
  审核编辑:汤梓红
