C++之STL算法(二)
1.sort排序算法
sort(const _RanIt _First, const _RanIt _Last, _Pr _Pred)  --默认为升序排序
形参:_First、_Last --容器的起始和结束迭代器
	  _Pred --排序规则,默认为从小到大
示例:
#include < iostream >
#include < vector >
#include < algorithm >
using namespace std;
class Print
public:
	void operator()(int val)
		cout < < val < < " ";
void test()
	vector< int >vtr;
	vtr.push_back(rand()%50);
	vtr.push_back(rand() % 50);
	for_each(vtr.begin(), vtr.end(), Print());
	cout < < endl;
	cout < < "升序排序:" < < endl;
	sort(vtr.begin(), vtr.end());
	cout < < endl;
	cout < < "降序排序:" < < endl;
	sort(vtr.begin(), vtr.end(), greater< int >());
	cout < < endl;
int main()
	test();
	system("pause");
C++
2.random_shuffle打乱顺序(洗牌)
打乱有序数列,重新洗牌:
void random_shuffle(_RanIt _First, _RanIt _Last);
形参:_First、_Last --起始和结束迭代器
#include < vector >
#include < map >
#include < ctime >
class Person
	friend class Print;
public:
	Person() {}
	Person(string name, int age) :name(name), age(age) {
	bool operator< (const Person p)const
		if (age == p.age)
			return name < p.name;
		return age < p.age;
	string name;
	int age;
class Print
public:
	void operator()(Person& p)
		cout < < "姓名:" < < p.name < < "t年龄:" < < p.age < < endl;
void test()
	vector< int >vtr;
	vtr.resize(10);
	for (int i = 0; i < 10; i++)
		vtr[i] = i;
	cout < < endl;
	cout < < "洗牌后:" < < endl;
	random_shuffle(vtr.begin(), vtr.end());
	cout < < endl;
void test02()
	cout < < "t自定义数据:" < < endl;
	vector< Person >vtr;
	vtr.push_back(Person("小王", 1));
	vtr.push_back(Person("小王", 2));
	vtr.push_back(Person("小王", 3));
	vtr.push_back(Person("小李", 1));
	vtr.push_back(Person("小李", 2));
class mapPrint
public:
	void operator()(pair< Person, int >p)
		cout < < "姓名:" < < (p.first).name < < "t年龄:" < < (p.first).age < < "t得分:" < < p.second < < endl;
int main()
	srand(time(NULL));//random_shuffle底层需要随机数种子,否则每次生成结果一样
	test();
	test02();
	system("pause");
C++
3.merge合并容器
容器合并:
	merge()实现吧两个容器合并在一起,存放到第三个容器中。
	注意:merge()合并一定要保证容器元素有序,默认是从小到大的顺序。
	merge(_InIt1 _First1, _InIt1 _Last1, _InIt2 _First2, _InIt2 _Last2, _OutIt _Dest)  -- >默认从小到大
	merge(_InIt1 _First1, _InIt1 _Last1, _InIt2 _First2, _InIt2 _Last2, _OutIt _Dest, _Pr _Pred) -- >重载版本,支持自定义排序规则
	_First1、_Last1 --第一个容器的起始和结束迭代器
	_Last2、_Dest --第二个元素的起始和结束迭代器
	_Dest --要存储的新容器起始迭代器
	_Pred --谓词,设定排序规则
谓词:
	函数对象返回中为bool类;
	函数对象形参只有一个  -- > 一元谓词
	函数对象形参有两个  -- >  二元谓词
示例:
#include < vector >
#include < map >
class Print
public:
void test01()
	vector< int >v1;
	vector< int >v2;
	for (int i = 0; i < 5; i++)
		v1.push_back(i);
	v2.push_back(2);
	v2.push_back(16);
	v2.push_back(12);
	v2.push_back(14);
	sort(v2.begin(), v2.end(), less< int >());
	vector< int >v3;
	v3.resize(v1.size() + v2.size());
	cout < < "从小到大于有序合并:" < < endl;
	merge(v1.begin(), v1.end(), v2.begin(), v2.end(), v3.begin());
	for_each(v3.begin(), v3.end(), Print());
	cout< ());
	sort(v2.begin(), v2.end(), greater< int >());
	merge(v1.begin(), v1.end(), v2.begin(), v2.end(), v3.begin(),greater< int >());
	cout < < endl;
int main()
	test01();
	system("pause");
C++
4.reverse元素反转
函数功能: 元素反转,将容器中的元素前后颠倒
	reverse(const _BidIt _First, const _BidIt _Last)
#include < vector >
class Person
public:
	Person() {}
	Person(const Person& p)
		this- >age = p.age;
		name = p.name;
	bool operator< ( Person p)const
		if (age == p.age)return name < p.name;
		return age < p.age;
	string name;
	int age;
class Print
public:
	void operator()(Person p)
void test()
	vtr.push_back(Person("小王",18));
	vtr.push_back(Person("小刘", 15));
	vtr.push_back(Person("小林", 20));
	cout < < "反转:" < < endl;
	reverse(vtr.begin(), vtr.end());
int main()
	test();
	system("pause");
C++
5.copy元素拷贝
_OutIt copy(_InIt _First, _InIt _Last, _OutIt _Dest)
形参:_First、_Last --原容器的起始和结束位置
      _Dest --目标容器的起始位置
该函数功能类似于重载运算符=功能
#include < vector >
void test()
	std::vector< std::string >vtr, vtr2;
	vtr.push_back("C++");
	vtr.push_back("copy算法");
	vtr.push_back("学习");
	vtr.push_back("案例");
	std::cout < < "copy算法使用示例:" < < std::endl;
	vtr2.resize(vtr.size());
	copy(vtr.begin(), vtr.end(), vtr2.begin());//copy函数类似于赋值操作,vtr2=vtr1
	for (std::vector< std::string >::iterator p = vtr2.begin(); p != vtr2.end(); p++)
		std::cout < < *p < < " ";
	std::cout < < std::endl;
int main()
	test();
	system("pause");
C++
6.replace元素替换
元素替换
void replace(const _FwdIt _First, const _FwdIt _Last, const _Ty& _Oldval, const _Ty& _Newval)
形参:_First、_Last --要替换的数据区间
     _Oldval  --要替换的内容
	 _Newval  --替换后的内容
#include < vector >
class Print
public:
void test()
	vector< int >vtr;
	vtr.push_back(10);
	vtr.push_back(10);
	vtr.push_back(30);
	vtr.push_back(10);
	vtr.push_back(35);
	vtr.push_back(10);
	cout < < "替换前:" < < endl;
	cout < < endl;
	cout < < "将10替换成666" < < endl;
	replace(vtr.begin(), vtr.end(), 10, 666);
	cout < < endl;
int main()
	test();
	system("pause");
C++
7.条件替换replace_if
条件替换
 replace_if(const _FwdIt _First, const _FwdIt _Last, _Pr _Pred, const _Ty& _Val)
 形参:_First、_Last  --要替换的区间
       _Pred  --谓词,替换条件
	   _Val  --替换后的值
示例:
#include < vector >
#include < functional >
class Myreplace
public:
	bool operator()(int val)
		return val >= 30;
void test()
	vector< int >vtr;
	vtr.push_back(10);
	vtr.push_back(10);
	vtr.push_back(30);
	vtr.push_back(10);
	vtr.push_back(50);
	vtr.push_back(10);
	cout < < "将所有的 >=30的值替换为666" < < endl;
	replace_if(vtr.begin(), vtr.end(), Myreplace(), 666);
	for (vector< int >::iterator ptr = vtr.begin();ptr != vtr.end();ptr++)
		cout < < *ptr < < " ";
	cout < < endl;
int main()
	test();
	system("pause");
C++
8.容器互换swap
容器元素互换:
	swap(container v1,container v2);
	将v1和v2的容器元素进行互换,类似于成员函数swap();
#include < vector >
class Print
public:
void test()
	vector< int >vtr1 = { 10,20,30,50 };
	vector< int >vtr2 = { 10,29,88 };
	for_each(vtr1.begin(), vtr1.end(), Print());
	cout < < endl;
	for_each(vtr2.begin(), vtr2.end(), Print());
	cout < < endl;
	swap(vtr1, vtr2);
	cout < < "替换结果:" < < endl;
	cout < < endl;
	cout < < endl;
int main()
	test();
	system("pause");
C++
