STM32F1两个USB中断入口详解
1 STM32F1两个USB中断入口
STM32中断入口有两个,分别是USB_HP_CAN1_TX_IRQHandler和USB_LP_CAN1_RX0_IRQHandler。
其中USB_Istr函数调用了CTR_LP函数,代码如下。
* Function Name  : USB_HP_CAN1_TX_IRQHandler
* Description    : This function handles USB High Priority or CAN TX interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_HP_CAN1_TX_IRQHandler(void)
  CTR_HP();
* Function Name  : USB_LP_CAN1_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN1_RX0_IRQHandler(void)
  USB_Istr();
2 CTR_LP
CTR_LP为低优先级端点传输正常时的中断服务函数,控制传输只能在CTR_LP里面处理,代码如下。
* Function Name  : CTR_LP.
* Description    : Low priority Endpoint Correct Transfer interrupt's service
*                  routine.
* Input          : None.
* Output         : None.
* Return         : None.
void CTR_LP(void)
  uint32_t wEPVal = 0;
  /* stay in loop while pending ints */
  while (((wIstr = _GetISTR()) & ISTR_CTR) != 0)
    _SetISTR((uint16_t)CLR_CTR); /* clear CTR flag */
    /* extract highest priority endpoint number */
    EPindex = (uint8_t)(wIstr & ISTR_EP_ID);
    if (EPindex == 0)
      /* Decode and service control endpoint interrupt */
      /* calling related service routine */
      /* (Setup0_Process, In0_Process, Out0_Process) */
      /* save RX & TX status */
      /* and set both to NAK */
      SaveRState = _GetEPRxStatus(ENDP0);
      SaveTState = _GetEPTxStatus(ENDP0);
      _SetEPRxStatus(ENDP0, EP_RX_NAK);
      _SetEPTxStatus(ENDP0, EP_TX_NAK);
      /* DIR bit = origin of the interrupt */
      if ((wIstr & ISTR_DIR) == 0)
        /* DIR = 0 */
        /* DIR = 0      = > IN  int */
        /* DIR = 0 implies that (EP_CTR_TX = 1) always  */
        _ClearEP_CTR_TX(ENDP0);
        In0_Process();
           /* before terminate set Tx & Rx status */
          _SetEPRxStatus(ENDP0, SaveRState);
          _SetEPTxStatus(ENDP0, SaveTState);
          return;
      else
        /* DIR = 1 */
        /* DIR = 1 & CTR_RX       = > SETUP or OUT int */
        /* DIR = 1 & (CTR_TX | CTR_RX) = > 2 int pending */
        wEPVal = _GetENDPOINT(ENDP0);
        if ((wEPVal & EP_CTR_TX) != 0)
          In0_Process();
          return;
        else if ((wEPVal &EP_SETUP) != 0)
          _ClearEP_CTR_RX(ENDP0); /* SETUP bit kept frozen while CTR_RX = 1 */
          Setup0_Process();
          return;
        else if ((wEPVal & EP_CTR_RX) != 0)
          Out0_Process();
          return;
    }/* if(EPindex == 0) */
    else
      /* Decode and service non control endpoints interrupt  */
      /* process related endpoint register */
      wEPVal = _GetENDPOINT(EPindex);
        /* clear int flag */
        _ClearEP_CTR_RX(EPindex);
        /* call OUT service function */
        (*pEpInt_OUT[EPindex-1])();
      } /* if((wEPVal & EP_CTR_RX) */
        _ClearEP_CTR_TX(EPindex);
        /* call IN service function */
        (*pEpInt_IN[EPindex-1])();
      } /* if((wEPVal & EP_CTR_TX) != 0) */
    }/* if(EPindex == 0) else */
  }/* while(...) */
3 CTR_HP
CTR_HP为高优先级端点传输正常时的中断服务函数,代码如下。
* Function Name  : CTR_HP.
* Description    : High Priority Endpoint Correct Transfer interrupt's service
*                  routine.
* Input          : None.
* Output         : None.
* Return         : None.
void CTR_HP(void)
    else if ((wEPVal & EP_CTR_TX) != 0)
  }/* while(...) */
4 CTR_LP和CTR_HP各自处理的事务类型
这两个函数定义在usb_int.c中,用法如下。
CTR_LP(低优先级中断Low-priority interrupt),用于控制传输、中断传输、批量传输( 单缓冲模式)。
CTR_HP(高优先级中断 High-priority interrupt),用于快速大数据量传输处理,比如同步传输、批量传输,但是都是处理双缓冲模式。
5 核心注意要点
如果把只初始化了USB_LP_CAN1_RX0_IRQn中断向量,则所有的正确传输中断只会进入USB_LP_CAN1_RX0_IRQHandler->CTR_LP,所以要想进入CTR_HP必须对其中断向量进行初始化,否则会使用默认的CTR_LP路径进行处理。
