fluxion创建AP卡住(5G)解决方法
1.2w人已加入
1、配置内核信道监管域
WiFi信道根据国家地区的不同,有着严格的频道划分,某些5G信道可以作为雷达探测使用,这意味着 如果有路由器工作在雷达探测保留信道,那么意味着你很可能不能在上边注入,解除认证,以及创建虚假克隆 AP。因此我们需要根据WiFi信道顺从表,修改内核监管域国家代码,以影响无线网卡工作频段,使其 能正常注入、解除认证、创建AP等
WLAN信道顺从表案例:https://www.docin.com/p-2253061296.html
编辑开机启动配置文件
# 编辑配置,使得每次开机将无线网卡工作频率
# 国家代码设置为CN(中国),特别推荐PA(巴拿马)可以避开雷达信道,解除认证5G杠杠的
╰─ vim /etc/rc.local
#!/bin/bash
# THIS FILE IS ADDED FOR COMPATIBILITY PURPOSES
# It is highly advisable to create own systemd services or udev rules
# to run scripts during boot instead of using this file.
# In contrast to previous versions due to parallel execution during boot
# this script will NOT be run after all other services.
# Please note that you must run 'chmod +x /etc/rc.d/rc.local' to ensure
# that this script will be executed during boot.
# set wlan frequency country code to PA/CN
iw reg set PA
exit 0
# 添加执行权限
╰─ chmod +x /etc/rc.local
复制
使配置生效
# 重启服务
╰─ systemctl restart rc-local.service
╰─ systemctl status rc-local.service
# 或者重启机器
╰─ reboot
复制
之后你会发现8812au将能够成功deauth解除认证所有5G信号
#配置完成后验证信道
#你应该能看到如下输出
#信道后边应该没有任何特殊标记
#说明我们可以在上边执行deauth与创建AP
╰─ iw list
Wiphy phy0
        Frequencies:
            * 2412 MHz [1] (20.0 dBm)
            * 2417 MHz [2] (20.0 dBm)
            * 2422 MHz [3] (20.0 dBm)
            * 2427 MHz [4] (20.0 dBm)
            * 2432 MHz [5] (20.0 dBm)
            * 2437 MHz [6] (20.0 dBm)
            * 2442 MHz [7] (20.0 dBm)
            * 2447 MHz [8] (20.0 dBm)
            * 2452 MHz [9] (20.0 dBm)
            * 2457 MHz [10] (20.0 dBm)
            * 2462 MHz [11] (20.0 dBm)
            * 2467 MHz [12] (20.0 dBm)
            * 2472 MHz [13] (20.0 dBm)
            * 2484 MHz [14] (20.0 dBm)
        Frequencies:
            * 5075 MHz [15] (30.0 dBm)
            * 5080 MHz [16] (30.0 dBm)
            * 5085 MHz [17] (30.0 dBm)
            * 5090 MHz [18] (30.0 dBm)
            * 5100 MHz [20] (30.0 dBm)
            * 5120 MHz [24] (30.0 dBm)
            * 5140 MHz [28] (30.0 dBm)
            * 5160 MHz [32] (30.0 dBm)
            * 5180 MHz [36] (30.0 dBm)
            * 5200 MHz [40] (30.0 dBm)
            * 5220 MHz [44] (30.0 dBm)
            * 5240 MHz [48] (30.0 dBm)
            * 5260 MHz [52] (30.0 dBm)
            * 5280 MHz [56] (30.0 dBm)
            * 5300 MHz [60] (30.0 dBm)
            * 5320 MHz [64] (30.0 dBm)
            * 5340 MHz [68] (30.0 dBm)
            * 5360 MHz [72] (30.0 dBm)
            * 5380 MHz [76] (30.0 dBm)
            * 5400 MHz [80] (30.0 dBm)
            * 5420 MHz [84] (30.0 dBm)
            * 5440 MHz [88] (30.0 dBm)
            * 5460 MHz [92] (30.0 dBm)
            * 5480 MHz [96] (30.0 dBm)
            * 5500 MHz [100] (30.0 dBm)
            * 5520 MHz [104] (30.0 dBm)
            * 5540 MHz [108] (30.0 dBm)
            * 5560 MHz [112] (30.0 dBm)
            * 5580 MHz [116] (30.0 dBm)
            * 5600 MHz [120] (30.0 dBm)
            * 5620 MHz [124] (30.0 dBm)
            * 5640 MHz [128] (30.0 dBm)
            * 5660 MHz [132] (30.0 dBm)
            * 5680 MHz [136] (30.0 dBm)
            * 5700 MHz [140] (30.0 dBm)
            * 5720 MHz [144] (30.0 dBm)
            * 5745 MHz [149] (30.0 dBm)
            * 5765 MHz [153] (30.0 dBm)
            * 5785 MHz [157] (30.0 dBm)
            * 5805 MHz [161] (30.0 dBm)
            * 5825 MHz [165] (30.0 dBm)
            * 5845 MHz [169] (30.0 dBm)
            * 5865 MHz [173] (30.0 dBm)
            * 5885 MHz [177] (30.0 dBm)
复制
2、配置fluxion以修复5Ghz创建AP
配置fluxion以支持创建5G频段的AP
#编辑ap脚本文件
╰─ cat 桌面/fluxion-fix-for-5Ghz/lib/ap/hostapd.sh
function ap_service_prep() {
  if [ ${#@} -lt 5 ]; then return 1; fi
  APServiceInterface=$1
  APServiceInterfaceAddress=$2
  APServiceSSID=$3
  APServiceMAC=$4
  APServiceChannel=$5
  ap_service_stop
  # Prepare the hostapd config file.
  country_code="$(iw reg get | awk 'FNR == 2 {print $2}' | cut -f 1 -d ":" 2 > /dev/null)"
  [[ ! ${country_code} =~ ^[A-Z]{2}$ ]] && country_code="00"
  rm -rf "$APServiceConfigDirectory/$APServiceMAC-hostapd.conf" > /dev/null 2 >&1
  echo "
interface=$APServiceInterface
driver=nl80211
ssid=$APServiceSSID
channel=$APServiceChannel"
  > > "$APServiceConfigDirectory/$APServiceMAC-hostapd.conf"
  if [[ ${APServiceChannel} -gt 14 ]];then
      echo -e "hw_mode=a"
      } > > "$APServiceConfigDirectory/$APServiceMAC-hostapd.conf"
  else
      echo -e "hw_mode=g"
  fi
  if [[ "${country_code}" != "00" ]];then
      echo -e "country_code=${country_code}"
  fi
复制
添加如下代码
AP
之后,你会发现fluxion将会正常创建5G频段的AP,不会卡住
AP
