【NuMaker-M2354试用】microSD实验
1.测评任务
​ 测试M2354的硬件RTC,开启RTC功能,运用RT-Thread提供的bsp及库函数,实现一个RTC功能。
​ 实现功能:初始化RTC时间,通过控制台每秒打印一次时间。
2.测评硬件
​ 本次使用的硬件是Nuvoton官方的NuMaker-M2354开发板
​ mcu型号:M2354KJFAE
​ 内核:cortex-M23
3.环境搭建及工程创建
在bsp->nuvoton->numaker-m2354 下应用env工具进行配置
microSD卡
​ 配置完成后,保存退出使用命令 scons --target=mdk5 生成 keil 工程,打开工程编译下载。
4.下载运行
​ 插入sd卡,复位后,控制台打印如下:
RT - Thread Operating System
/ | 4.0.4 build Dec 19 2021 23:03:10
2006 - 2021 Copyright by rt-thread team
[I/I2C] I2C bus [i2c1] registered
[I/slcd] Working frame rate is 64Hz on Type-A.
[I/sal.skt] Socket Abstraction Layer initialize success.
[I/utest] utest is initialize success.
[I/utest] total utest testcase num: (0)
[I/at.clnt] AT client(V1.3.1) on device uart4 initialize success.
[D/FAL] (fal_flash_init:63) Flash device | OnChip_APROM | addr: 0x00000000 | len: 0x00100000 | blk_size: 0x00000800 |initialized finish.
[D/FAL] (fal_flash_init:63) Flash device | OnChip_LDROM | addr: 0x00100000 | len: 0x00104000 | blk_size: 0x00000800 |initialized finish.
[I/FAL] ==================== FAL partition table ====================
[I/FAL] | name | flash_dev | offset | length |
[I/FAL] -------------------------------------------------------------
[I/FAL] | ldrom | OnChip_LDROM | 0x00000000 | 0x00001000 |
[I/FAL] | aprom | OnChip_APROM | 0x000f0000 | 0x00010000 |
[I/FAL] =============================================================
[I/FAL] RT-Thread Flash Abstraction Layer (V0.5.0) initialize success.
[I/dancemouse] Ready.
msh />Failed to mount sdh0 on /
[I/at.dev.esp] esp0 device wifi is disconnect.
[E/at.clnt] execute command (AT+CWJAP="NT_ZY_BUFFALO","12345678") failed!
[W/at.dev.esp] esp0 device wifi connect failed, check ssid(NT_ZY_BUFFALO) and password(12345678).
[I/at.dev.esp] esp0 device network initialize successfully.
5.实验现象
microSD挂载失败,不知所以然,试了好多配置,留着之后再做研究,另外使用nuvoton的bsp里的例程,可以正确读取扇区,说明硬件没有问题的,另外看了论坛上有一个相同microSD任务的配置了就可以。看他git的工程没有上传成功。很诧异。
