DDR3缓存模块仿真平台构建步骤
1. 复制Vivado工程路径vivado_prjat7.srcssources_1ipmig_7series_0下的mig_7series_0文件夹。粘贴到仿真路径testbench b_ddr3_cache(新建用于DDR3仿真的文件夹)下。
2. 拷贝一个glbl.v文件到testbench b_ddr3_cachemig_7series_0example_designsim文件夹下。
3. 打开testbench b_ddr3_cachemig_7series_0example_designsim文件夹下的sim.do文件中。进行编译的文件路径需要做移植修改。
将vlib work以及后面的内容删除
复制下面的脚本到sim.do中。
vlib work
vmap work work
vlog  -work workglbl.v
#Compile all modules#
vlog ../../../../../design/m_ddr3_cache.v
vlog ../../../../../vivado_prj/at7.srcs/sources_1/ip/fifo_ddr3_write/fifo_ddr3_write_sim_netlist.v
vlog ../rtl/traffic_gen/mig_7series*.v
vlog ../rtl/example_top.v
vlog  ../../user_design/rtl/mig_7series_0.v
vlog ../../user_design/rtl/mig_7series_0_mig_sim.v
vlog  -incr../../user_design/rtl/clocking/*.v
vlog  -incr../../user_design/rtl/controller/*.v
vlog  -incr../../user_design/rtl/ecc/*.v
vlog  -incr../../user_design/rtl/ip_top/*.v
vlog  -incr../../user_design/rtl/phy/*.v
vlog  -incr../../user_design/rtl/ui/*.v
#Compile files in sim folder (excluding model parameterfile)#
vlog *.vh
vlog *.sv
vlog *.v
#Pass the parametersfor memory model parameter file#
vlog -sv +define+x2Gb+define+sg15E +define+x16 ddr3_model.sv
#Load the design. Userequired libraries.#
vsim -voptargs=+acc-L unisims_ver -L unisim -L work -Lfunisims_ver +notimingchecks -Lsecureipwork.glblwork.sim_tb_top
add wavesim:/sim_tb_top/uut_m_ddr3_cache/*
4. 打开testbench b_ddr3_cachemig_7series_0example_designsim文件夹下的sim_tb_top.v文件(测试脚本),进行必要的修改,将用户设计移植到这个测试脚本中。
example_top模块的例化可以用用户设计模块替代,接口一一映射即可。
5. 打开modelsim,点击菜单Compile--> Compile options,修改Verilog &SystemVerilog下,勾选Use SystemVerilog选项。
6. 打开run_simulation.bat文件,增加新的仿真自动运行项。
@echo off
@cls
title FPGA Auto Simulation batch script
echo ModelSim simulation
echo.
echo Press '1' to start tb_pll simulation
echo.
echo Press '2' to start tb_fifo_img simulation
echo.
echo Press '3' to start tb_image_capture simulation
echo.
echo Press '4' to start tb_fifo_ddr3_write simulation
echo.
echo Press'5' to start tb_ddr3_cache simulation
echo.
:input
set INPUT=
set /P INPUT=Type test number: %=%
if "%INPUT%"=="1" goto run1
if "%INPUT%"=="2" goto run2
if "%INPUT%"=="3" goto run3
if "%INPUT%"=="4" goto run4
if"%INPUT%"=="5" goto run5
goto end
:run1
@cls
echo Start tb_pll Simulation;
echo.
echo.
cd testbench/tb_pll
vsim -do "do compile.do"
gotoclean_workspace
:run2
@cls
echo Start tb_fifo_img Simulation;
echo.
echo.
cd testbench/tb_fifo_img
gotoclean_workspace
:run3
@cls
echo Start tb_image_capture Simulation;
echo.
echo.
cd testbench/tb_image_capture
gotoclean_workspace
:run4
@cls
echo Start tb_fifo_ddr3_write Simulation;
echo.
echo.
cd testbench/tb_fifo_ddr3_write
gotoclean_workspace
:run5
@cls
echo Starttb_ddr3_cache Simulation;
echo.
echo.
cdtestbench/tb_ddr3_cache/mig_7series_0/example_design/sim
vsim -do"do sim.do"
gotoclean_workspace
:clean_workspace
rmdir /S /Q work
del vsim.wlf
del transcript.
:end
审核编辑:刘清
