一览pipeline中所出现的五个基本要素
》Stageable、StageableKey     stageable、StageableKey是最整个pipeline中的基本数据类型元素:
object Stageable{
  def apply[T <: Data](gen : => T) = new Stageable(gen)
  def apply[T <: Data](gen : HardType[T]) = new Stageable(gen.craft())
class Stageable[T <: Data](gen : => T) extends HardType(gen) with Nameable {
case class StageableOffset(val value : Any)
object StageableOffsetNone extends StageableOffset(null)
case class StageableKey(stageable: Stageable[Data], key : Any){
  override def toString = {
    var name = stageable.getName()
    if(key != null) name = name + "_" + key
    name
    对于Stageabel,我们可以传入任何SpinalHDL下面定义的隶属于Data的类型,不同于我们在电路里生命一个电路对象:
val a=UInt(8 bits)
    此时,电路对象是立即生命存在的,如果我们不对他进行赋值会报错。而:
val b=Stageable(UInt(8 bits))
    此时b并未真正生成电路对象,即使不对他进行赋值也并不会报错。
    对于StageableKey,字如其名,其主要用作Key使用,用于建立Stageable映射时的key使用。
》Stage
    借用上一篇文章中的图:
VaR
    Stage主要用于实现pipeline的功能实现。那么Stage则定义了这些功能的输入、输出:
val input = new {
      val valid = Bool()
      var ready : Bool = null
val output = new Area {
      val valid = Bool()
    以及一些列的内部保存变量:
val arbitration = new {
      var isRemoved : Bool = null
      var isFlushed : Bool = null
      var isThrown : Bool = null
      var isForked : Bool = null
      var isFlushingNext : Bool = null
      var isFlushingRoot : Bool = null
      var isHalted : Bool = null
      var isHaltedByOthers : Bool = null
      var propagateReady = false
    val request = new {
      val halts = ArrayBuffer[Bool]()
      val throws = ArrayBuffer[Bool]()
      val throwsRoot = ArrayBuffer[Bool]()
      val forks = ArrayBuffer[Bool]()
      val spawns = ArrayBuffer[Bool]()
      val flush = ArrayBuffer[Bool]()
      val flushRoot = ArrayBuffer[Bool]()
      val flushNext = ArrayBuffer[Bool]()
    val stageableToData = mutable.LinkedHashMap[StageableKey, Data]()
    val stageableOverloadedToData = mutable.LinkedHashMap[StageableKey, Data]()
    val stageableResultingToData = mutable.LinkedHashMap[StageableKey, Data]()
    val stageableTerminal = mutable.LinkedHashSet[StageableKey]()
    这些变量暂时看不懂也没关系,后续会通过例子逐一进行讲解。通过这些内部变量,pipeline在构建电路时处理Stage之间的依赖关系。
》Connection
    顾名思义,Connection用于负责Stage之间的连接关系,即其负责处理上一级Stage的output与下一级Stage的input之间的连接。在Lib中,Connection定义了四种连接关系:
DIRECT:类似一两个Stream直接相连
M2S:类似于Stream中的M2SPipe,对valid、payload进行打拍输出
S2M:类似于Stream中的S2MPipe,对于ready进行打拍输出
    乍看其实现你会发现其中有好多参数一时不知用途,无妨,先放一放,回头逐一讲解。
》pipeline
    Pipeline中核心是一个build函数。当我们描述完各Stage的功能之后,通过调用Pipeline的build函数即可构建整个的流水线电路,其也是整个pipelines构建的核心,直接上来看可能会略觉麻烦,后面通过例子一点点来理解。
》第一个例子
    先有个概念之后,我们再来一个pipeline的第一个例子:
case class demo() extends Component{
  val io=new Bundle{
    val data_in=slave Flow(UInt(8 bits))
    val data_out=master Flow(UInt(8 bits))
  noIoPrefix()
  val pip=new Pipeline{
    val paylaod=Stageable(UInt(8 bits))
    val stage0=new Stage{
      import internals._
      input.valid:=io.data_in.valid
      this(paylaod):=io.data_in.payload
    val stage1=new Stage(Connection.M2S())
    val stage2=new Stage(Connection.M2S()){
      io.data_out.valid:=internals.output.valid
      io.data_out.payload:=this(paylaod)
  pip.build()
    这个例子的功能是将Flow data_in打两拍输出给data_out,一个最简单的流水线结构,不牵涉到任何halt、flush等相关操作。如果你看不懂,可以先看它生成的RTL代码:
module demo (
  input data_in_valid,
  input [7:0] data_in_payload,
  output data_out_valid,
  output [7:0] data_out_payload,
  input clk,
  input reset
  reg        [7:0] pip_stage1_paylaod;
  reg        [7:0] pip_stage2_paylaod;
  wire       [7:0] pip_stage0_paylaod;
  wire                pip_stage0_valid;
  reg                 pip_stage1_valid;
  reg                 pip_stage2_valid;
  assign pip_stage0_valid = data_in_valid;
  assign pip_stage0_paylaod = data_in_payload;
  assign data_out_valid = pip_stage2_valid;
  assign data_out_payload = pip_stage2_paylaod;
  always @(posedge clk or posedge reset) begin
    if(reset) begin
      pip_stage1_valid <= 1'b0;
      pip_stage2_valid <= 1'b0;
    end else begin
      pip_stage1_valid <= pip_stage0_valid;
      pip_stage2_valid <= pip_stage1_valid;
    end
  end
  always @(posedge clk) begin
    pip_stage1_paylaod <= pip_stage0_paylaod;
    pip_stage2_paylaod <= pip_stage1_paylaod;
  end
endmodule
    一眼看去,可能觉得很怪,有很多疑问。比如说data_in的valid信号是如何从stage0传输到stage1的等等。
审核编辑:刘清
