ENSP华为路由器出口NAT实验设计
1:实验需求
公司拥有多个部门且位于不同网段,各部门均有访问Internet的需求。现要求用户通过二层交换机和路由器访问外部网络,且要求路由器作为用户的网关。
我们按照图示的IP地址进行配置,最终的结果是PC1和PC2可以ping通公网地址192.169.1.2.
2:网络拓补图
这里多说一句哈,华为的ENSP模拟器有的路由器NAT配置了不生效,我在这里使用的是AR1220系列。
交换机
3:实验过程
CORE
sy
Enter system view, return user view with Ctrl+Z.
[Huawei]undo info-center enable
Info: Information center is disabled.
[Huawei]sysname CORE
[CORE]vlan batch 2 3 100 //创建vlan 2 3 100备用
Info: This operation may take a few seconds. Please wait for a moment...done.
[CORE]dhcp enable //全局使能DHCP
Info: The operation may take a few seconds. Please wait for a moment.done.
[CORE]interface Vlanif 2 //进入vlanif接口配置IP,DHCP的方式是基于接口
[CORE-Vlanif2]ip address  192.168.2.254 24
[CORE-Vlanif2]dhcp select interface
[CORE-Vlanif2]quit
[CORE]interface Vlanif 3
[CORE-Vlanif3]ip add 192.168.3.254 24
[CORE-Vlanif3]dhcp select interface
[CORE-Vlanif3]quit
[CORE]interface Vlanif 100
[CORE-Vlanif100]ip add 192.168.100.2 24
[CORE-Vlanif100]quit
[CORE]interface GigabitEthernet 0/0/1 //设置终端链路类型access
[CORE-GigabitEthernet0/0/1]port link-type access
[CORE-GigabitEthernet0/0/1]port default vlan 2
[CORE-GigabitEthernet0/0/1]quit
[CORE]interface GigabitEthernet 0/0/2
[CORE-GigabitEthernet0/0/2]port link-type access
[CORE-GigabitEthernet0/0/2]port default vlan 3
[CORE-GigabitEthernet0/0/2]quit
[CORE]interface GigabitEthernet 0/0/3 //设置链路终端类型,设置为access,路由器才能识别,或者trunk端口设置PVID。
[CORE-GigabitEthernet0/0/3]port link-type access
[CORE-GigabitEthernet0/0/3]port default vlan 100
[CORE-GigabitEthernet0/0/3]quit
[CORE]ip route-static 0.0.0.0 0.0.0.0 192.168.100.1 //写一条默认路由,下一跳地址是对端的路由器
ROUTER
sy
system-view
[Huawei]sysname ROUter
[ROUter]interface GigabitEthernet 0/0/1  //我们配置内网的IP接口
[ROUter-GigabitEthernet0/0/1]ip add 192.168.100.1 24
[ROUter-GigabitEthernet0/0/1]quit
[ROUter]ip route-static 192.168.0.0 16 192.168.100.2 //我们配置到内网的回程路由,即192.168.X.X均可以匹配
[ROUter]ip route-static 0.0.0.0 0.0.0.0 192.169.1.2 //设置一条默认路由去公网
[ROUter]interface GigabitEthernet 0/0/0 //配置公网的IP地址
[ROUter-GigabitEthernet0/0/0]ip address 192.169.1.1 24
[ROUter-GigabitEthernet0/0/0]quit
[ROUter]acl 2000 //建基本ACL2000
[ROUter-acl-basic-2000]rule permit source 192.168.0.0 0.0.255.255 //允许192.168.X.X的网段
[ROUter-acl-basic-2000]quit
[ROUter]interface GigabitEthernet 0/0/0 //进入外网接口,调用acl2000
[ROUter-GigabitEthernet0/0/0]nat outbound 2000 //nat引用
[ROUter]display nat session all //这里我们可以看到NAT会话
  NAT Session Table Information:
     Protocol          : ICMP(1)
     SrcAddr   Vpn     : 192.168.2.253
     DestAddr  Vpn     : 192.169.1.2
     Type Code IcmpId  : 0   8   890
     NAT-Info
       New SrcAddr     : 192.169.1.1
       New DestAddr    : ----
       New IcmpId      : 10259
     Protocol          : ICMP(1)
     Type Code IcmpId  : 0   8   888
     NAT-Info
       New DestAddr    : ----
       New IcmpId      : 10257
     Protocol          : ICMP(1)
     Type Code IcmpId  : 0   8   889
     NAT-Info
       New DestAddr    : ----
       New IcmpId      : 10258
     Protocol          : ICMP(1)
     Type Code IcmpId  : 0   8   887
     NAT-Info
       New DestAddr    : ----
       New IcmpId      : 10256
     Protocol          : ICMP(1)
     Type Code IcmpId  : 0   8   886
     NAT-Info
       New DestAddr    : ----
       New IcmpId      : 10255
公网路由器
sy
system-view //我们给它设置一个测试用的IP地址
[Huawei]interface GigabitEthernet 0/0/0
[Huawei-GigabitEthernet0/0/0]ip add 192.169.1.2 24
[Huawei-GigabitEthernet0/0/0]quit
[Huawei]ping 192.169.1.1 //测试和公司公网IP的连通性
  PING 192.169.1.1: 56  data bytes, press CTRL_C to break
    Reply from 192.169.1.1: bytes=56 Sequence=1 ttl=255 time=90 ms
    Reply from 192.169.1.1: bytes=56 Sequence=2 ttl=255 time=20 ms
    Reply from 192.169.1.1: bytes=56 Sequence=3 ttl=255 time=30 ms
    Reply from 192.169.1.1: bytes=56 Sequence=4 ttl=255 time=30 ms
    Reply from 192.169.1.1: bytes=56 Sequence=5 ttl=255 time=20 ms
  --- 192.169.1.1 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 20/38/90 ms
[Huawei]
测试
我们使用PC1和PC2分别ping公网地址,如下图所示
交换机交换机
会话信息
交换机
审核编辑:刘清
