香蕉派BPI-M2 Zero单板计算机采用全志H3(可选H2+/H5)芯片设计,板载512M RAM内存
Raspberry Pi
Banana pi BPI-M2 Zero 是一款极小形的开源单板计算机,采用全志H2+芯片方案设计,也可以直接使用全志H3,尺寸大小完全与Raspberry pi Zero W 一样,尺寸大小为60mm *30mm支持板载WIFI与蓝牙,512M 内存,Mini HDMI 接口。
Banana Pi BPI-M2 Zero 支持Android,Debian linux,Ubuntu linux, Raspbian系统 ,可以方便的做物联网,教育应用开发。
硬件接口:
Raspberry Pi
硬件规格:
 香蕉派BPI-P2 Zero , BPI-M2 zero 与 Raspberry Pi Zero W硬件规格比较
Module
Banana Pi BPI-P2 Zero
Raspberry Pi Zero W
CPUH3+ Quad-core Cortex-A7 H265/HEVC 1080PH3+ Quad-core Cortex-A7 H265/HEVC 1080PBroadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
GPUMali400MP2 GPU @600MHz,Supports OpenGL ES 2.0Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0VideoCore IV
Memory (SDRAM)512M DDR3(shared with GPU)512M DDR3(shared with GPU)512 MB DDR2
Onboard StorageTF card (Max. 64GB)TF card (Max. 64GB)TF card (Max. 64GB)
Onboard Network100M LANNOPE (but can extension with PIN define)NOPE
PoE powerPoE function supportNOPENOPE
Onboard flash8G eMMCNOPENOPE
Onboard WIFISDIO AP6212(option AP6181、AP6335)SDIO AP6212(option AP6181、AP6335)802.11n wireless, Bluetooth 4.1
Video decoding1080p@60fps,H.264 Video encoding 1080p@30fps,H.2641080p@60fps,H.264 Video encoding 1080p@30fps,H.2641080p30 H.264/MPEG-4 AVC high-profile decoder and encoder
Video inputA CSI input connector CameraA CSI input connector CameraCSI camera connector
Video Outputsmini HDMI 1.4,1080P@30fps, DHCPmini HDMI 1.4,1080P@30fps, DHCPMini HDMI and USB On-The-Go ports
Audio OutputMini HDMIMini HDMIMini HDMI
Power SourceMicro USB with 5V/2A or PoE powerMicro USB with 5V/2A5V/2A
USB 2.0 Portsone USB 2.0 OTGone USB 2.0 OTGone USB 2.0 OTG
ButtonsPower Button, Reset ButtonPower Button, Reset ButtonComposite video and reset headers
Low-level peripherals40 Pins Header,compatible with Raspberry Pi 340 Pins Header,compatible with Raspberry Pi 340 PIN
uart GPIO(1x3) pinUART, groundUART, groundUART
LEDPower led & Status ledPower led & Status ledPower Status LED
IRN/AN/AN/A
Supported OSandroid linuxandroid linxLinux
Product size65mm X 52.5mm65mm × 30mm65mm x 30mm
Weight30g15g9g
