香蕉派 BPI-P2 Zero物联网全志H3(可选H2+/H5)芯片设计,PoE网络供电,512M RAM ,8GB eMMC
PoE
香蕉派 BPI-P2 Zero 四核开源物联网开发板,采用全志H3芯片设计,也可以直接用在H2+,H5芯片方案。Banana Pi BPI-P2 Zero 是一种小巧的物联网开发板,板子尺寸只有65毫米52.5毫米。它使用四核 H3处理器,有512 MB内存。8 G eMMC,100兆网口,支持PoE功能,wifi无线支持,它支持linux和android操作系统
BPI-P2 Zero开发板,相比较BPI-M2 Zero .仅仅有三个地方有硬件改动,其他设计是一样的.所以最新软件镜像可以通用.
  • 1,增加了板载8G eMMC flash,软件可以烧录在eMMC上,可以直接应用做IoT物联网产品.
  • 2,BPI-P2 Zero 加了100兆有线网口 ,BPI-M2 Zero 有线网口只能用PIN针扩展,但软件使用方法一样.
  • 3,增加了PoE网线供电功能.
硬件接口:
PoE
配件规格:
HardWare Specification of Banana pi BPI-P2 Zero VS BPI-M2 zero VS Raspberry Pi Zero W
型号
Banana Pi BPI-M2 Zero
Raspberry Pi Zero W
CPU主控H3 Quad-core Cortex-A7 H265/HEVC 1080PH3 Quad-core Cortex-A7 H265/HEVC 1080PBroadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
GPUMali400MP2 GPU @600MHz,Supports OpenGL ES 2.0Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0VideoCore IV
Memory (SDRAM)512M DDR3(shared with GPU)512M DDR3(shared with GPU)512 MB DDR2
Onboard StorageTF card (Max. 64GB)TF card (Max. 64GB)TF card (Max. 64GB)
有线网络100M LANNOPE (but can extension with PIN define)NOPE
PoE 网线供电PoE function supportNOPENOPE
Onboard flash8G eMMCNOPENOPE
WIFI无线SDIO AP6212(option AP6181、AP6335)SDIO AP6212(option AP6181、AP6335)802.11n wireless, Bluetooth 4.1
Video decoding1080p@60fps,H.264 Video encoding 1080p@30fps,H.2641080p@60fps,H.264 Video encoding 1080p@30fps,H.2641080p30 H.264/MPEG-4 AVC high-profile decoder and encoder
Video inputA CSI input connector CameraA CSI input connector CameraCSI camera connector
Video Outputsmini HDMI 1.4,1080P@30fps, DHCPmini HDMI 1.4,1080P@30fps, DHCPMini HDMI and USB On-The-Go ports
Audio OutputMini HDMIMini HDMIMini HDMI
供电Micro USB with 5V/2A or PoE powerMicro USB with 5V/2A5V/2A
USB 2.0 Portsone USB 2.0 OTGone USB 2.0 OTGone USB 2.0 OTG
按键Power Button, Reset ButtonPower Button, Reset ButtonComposite video and reset headers
Low-level peripherals40 Pins Header,compatible with Raspberry Pi 340 Pins Header,compatible with Raspberry Pi 340 PIN
uart GPIO(1x3) pinUART, groundUART, groundUART
LED灯Power led & Status ledPower led & Status ledPower Status LED
IR红外控制N/AN/AN/A
支持系统android linuxandroid linxLinux
产品尺寸65mm X 52.5mm65mm × 30mm65mm x 30mm
重量30g15g9g
