香蕉派 BPI-M4 单板计算机采用 Realtek RT1395芯片方案设计,1G/2G RAM ,8GB eMMC
Banana Pi BPI-M4 4核64位开发板,采用RTD1395芯片设计 ,为banana pi 团队最新的Banana Pi BPI-M4具有与Raspberry Pi Model B 一样的尺寸,但搭载更强悍的Realtek RTD1395 SoC,并支援PoE网路线供电与M.2插槽等功能,使用上更具弹性。
关键特性:
1,Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
2,Mali 470 MP4 GPU OpenGL ES 1.1/2.0 H.264 H.265,2K4K
3,Onboard1 GB DDR4 (option 2 GB)
4,8G eMMC flash (max 64 GB)
5,10/100 Mbit/s Ethernet and RTL8821 module support Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
6,USB 2.0 TYPE C
7,M.2 Key E slot PCIE 2.0 and USB 2.0
8,PoE 网络供电功能支持
硬件接口:
banana pi
硬件规格:
Banana pi BPI-M4 硬件规格列表
主控芯片Realtek RTD1395 ARM Cortex-A53 Quad-Core 64 Bit
GPU图形Mali 470 MP4 GPU OpenGL ES 1.1/2.0
内存1 GB DDR4 (option 2 GB)
StorageMicroSD slot with support for up to 256GB expansion and 8G eMMC flash with support for up to 64GB
网络10/100 Mbit/s Ethernet + Wi-Fi 802.11 b/g/n/AC + Bluetooth 4.2
Video Output(s)HDMI port and multi-channel audio output support 1080P H.264 H.265 2K/4K
Audio Output(s)3.5mm jack and HDMI
PCIEM.2 Key E slot PCIE 2.0 and USB 2.0
USB portsUSB 2.0 PORT (x4), USB 2.0 TYPE C(x1)
GPIO40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
SwitchesReset, Power and U-boot
LEDPower Status and Activity status
Power Source5 volt @2A via Micro USB (TYPE C) or PoE support
Size & Weight92x60mm, 48g
OSAndroid and Linux
