如何使用Maven命令检测重复的依赖关系
在我们平时的开发过程中,常常会遇到引入各种不同的 jar 包,然后引发的 Maven 依赖冲突,今天我们来学习下如何使用 Maven 命令检测 pom.xml 中的重复依赖项。
为什么要检测重复的依赖关系
pom.xml中, 经常引入各种不同的jar 包, 又会依赖其他的jar。特别是一些常用的工具库,比较容易出现版本冲突,例如,让我们看下这个pom.xml
< project >
  < dependencies >
    < dependency >
      < groupId >org.apache.commons< /groupId >
      < artifactId >commons-lang3< /artifactId >
      < version >3.12.0< /version >
    < /dependency >
    < dependency >
      < version >3.11< /version >
    < /dependency >
  < /dependencies >
< /project >
从上面的代码中,commons-lang3 被引用了两次,而且版本号也不一样。现在我们就来看看如何使用Maven命令来检测这些重复的依赖关系。
依赖树命令
让我们在终端运行 mvn dependency:tree的命令,看看输出结果
$ mvn dependency:tree
[INFO] Scanning for projects...
[WARNING]
[WARNING] Some problems were encountered while building the effective model for com.javanorth:maven-duplicate-dependencies:jar:0
.0.1-SNAPSHOT
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.apache.commons:commons-lang3:jar -
> version 3.12.0 vs 3.11 @ line 14, column 15
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO]
[INFO] -------------< com.javanorth:maven-duplicate-dependencies >--------------
[INFO] Building maven-duplicate-dependencies 0.0.1-SNAPSHOT
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-dependency-plugin:2.8:tree (default-cli) @ maven-duplicate-dependencies ---
[WARNING] The artifact xml-apis:xml-apis:jar:2.0.2 has been relocated to xml-apis:xml-apis:jar:1.0.b2
[INFO] com.javanorth:maven-duplicate-dependencies:jar:0.0.1-SNAPSHOT
[INFO] - org.apache.commons:commons-lang3:jar:3.11:compile
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time:  1.136 s
我们可以看到,commons-lang3 jar的3.11版和 3.12 版同时被引入进来了,出现这种情况是因为Maven选择了pom.xml中后来出现的依赖。
依赖关系analyze-duplicate命令
现在让我们运行 mvn dependency:analyze-duplicate,看看输出输出结果。
$ mvn dependency:analyze-duplicate
[WARNING]
.0.1-SNAPSHOT
[WARNING]
[WARNING]
[WARNING]
[INFO]
[INFO]
[INFO] --- maven-dependency-plugin:2.8:analyze-duplicate (default-cli) @ maven-duplicate-dependencies ---
[INFO] List of duplicate dependencies defined in < dependencies/ > in your pom.xml:
        o org.apache.commons:commons-lang3:jar
[INFO] Total time:  0.835 s
我们注意到,WARNINGINFO日志语句都提到了重复依赖的存在。
如果存在重复的依赖,则构建失败
在上面的例子中,我们看到了如何检测重复的依赖关系,但BUILD仍然是成功的,但这可能导致使用了不正确的 jar 版本。
使用[Maven Enforcer Plugin](https://maven.apache.org/enforcer/maven-enforcer-plugin/index.html),我们可以确保在存在重复依赖的情况下构建不成功。
我们需要在pom.xml中加入这个Maven插件,并加入banDuplicatePomDependencyVersions规则。
< project >
  < build >
    < plugins >
      < plugin >
        < groupId >org.apache.maven.plugins< /groupId >
        < artifactId >maven-enforcer-plugin< /artifactId >
        < version >3.0.0< /version >
        < executions >
          < execution >
            < id >no-duplicate-declared-dependencies< /id >
            < goals >
              < goal >enforce< /goal >
            < /goals >
            < configuration >
              < rules >
                < banDuplicatePomDependencyVersions/ >
              < /rules >
            < /configuration >
          < /execution >
        < /executions >
      < /plugin >
    < /plugins >
  < /build >
< /project >
现在,该规则约束了我们的Maven构建。
$ mvn verify
[WARNING]
.0.1-SNAPSHOT
> version 3.12.0 vs 3.11 @ line 14, column 14
[WARNING]
[INFO]
[INFO] --- maven-enforcer-plugin:3.0.0:enforce (no-duplicate-declared-dependencies) @ maven-duplicate-dependencies ---
[WARNING] Rule 0: org.apache.maven.plugins.enforcer.BanDuplicatePomDependencyVersions failed with message:
Found 1 duplicate dependency declaration in this project:
 - dependencies.dependency[org.apache.commons:commons-lang3:jar] ( 2 times )
[INFO] BUILD FAILURE
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-enforcer-plugin:3.0.0:enforce (no-duplicate-declared-dependencies) on project maven-duplicate-dependencie
s: Some Enforcer rules have failed. Look above for specific messages explaining why the rule failed.
删除重复的依赖关系
只要确定了重复的依赖关系,我们就需要在 pom.xml中删除它们,只保留那些我们项目使用的唯一依赖关系。
总结
本文中,我们学习了如何使用mvn dependency:treemvn dependency:analyze-duplicate命令检测Maven中的重复依赖,还学习了如何使用Maven Enforcer插件,通过应用内置规则使包含重复依赖的构建失败。
