Java 8新增的 StringJoiner用法
概述
StringJoiner is used to construct a sequence of characters separated by a delimiter and optionally starting with a supplied prefix and ending with a supplied suffix.
Prior to adding something to the StringJoiner, its sj.toString() method will, by default, return prefix + suffix. However, if the setEmptyValue method is called, the emptyValue supplied will be returned instead. This can be used, for example, when creating a string using set notation to indicate an empty set, i.e. "{}", where the prefix is "{", the suffix is "}" and nothing has been added to the StringJoiner.
StringJoiner 源码的定义可以看出,它是 java.util 包中的一个类,被用来构造一个由分隔符分隔的字符串,并且可以从提供的前缀字符串开头,以提供的后缀字符串结尾。
通常我们拼接字符串都是使用 StringBuilder 或者 StringBuffer 来实现的。这个时候,我们可能就会有一个疑问了, StringJoiner 的价值是什么?到底为什么要到这个时候创造它。
源码解析
好,我们先看一下 StringJoiner 的构造函数, StringJoiner 一共有 2 个构造函数。构造函数很简单,没有什么可以多讲的,就是对 分隔符、前缀和后缀字符串的初始化。
public StringJoiner(CharSequence delimiter) {
        this(delimiter, "", "");
    public StringJoiner(CharSequence delimiter,
                        CharSequence prefix,
                        CharSequence suffix) {
        Objects.requireNonNull(prefix, "The prefix must not be null");
        Objects.requireNonNull(delimiter, "The delimiter must not be null");
        Objects.requireNonNull(suffix, "The suffix must not be null");
        // make defensive copies of arguments
        this.prefix = prefix.toString();
        this.delimiter = delimiter.toString();
        this.suffix = suffix.toString();
另外 StringJoiner 有 5 个公有方法,其中比较常用的就是 addtoString 。我们也来看看这两个常用方法。
public final class StringJoiner {
    private String[] elts;
    @Override
    public String toString() {
        final String[] elts = this.elts;
        if (elts == null && emptyValue != null) {
            return emptyValue;
        final int size = this.size;
        final int addLen = prefix.length() + suffix.length();
        if (addLen == 0) {
            compactElts();
            return size == 0 ? "" : elts[0];
        final String delimiter = this.delimiter;
        final char[] chars = new char[len + addLen];
        int k = getChars(prefix, chars, 0);
        if (size > 0) {
            k += getChars(elts[0], chars, k);
            for (int i = 1; i < size; i++) {
                k += getChars(delimiter, chars, k);
                k += getChars(elts[i], chars, k);
        k += getChars(suffix, chars, k);
        return new String(chars);
    public StringJoiner add(CharSequence newElement) {
        final String elt = String.valueOf(newElement);
        if (elts == null) {
            elts = new String[8];
        } else {
            if (size == elts.length)
                elts = Arrays.copyOf(elts, 2 * size);
            len += delimiter.length();
        len += elt.length();
        elts[size++] = elt;
        return this;
我们来看下 add 方法的实现,看起来也挺简单的,就是把待拼接的字符串,放到一个字符串数组里面。toString() 方法的时候,才是真正做字符串拼接的过程。我例子中的代码是 JDK 11, 相比 JDK 8 中,StringJoiner 是通过 StringBuilder 来实现的。
既然 JDK 8 的时候,已经使用了StringBuilder 来实现,那么为什么还要改成 String[] 来缓存所有的待拼接的字符串。这个就要涉及到JVM底层的优化,我们这里暂时不展开讲这个问题了。
前面已经提过既然已经有了 StringBuilder,为什么还要造一个StringJoiner,它的优势到底在哪里,我们接着来找找原因。很快我们在代码类的注释中找到了猫腻,在注释中标记了Collectors#joining
A StringJoiner may be employed to create formatted output from a java.util.stream.Stream using java.util.stream.Collectors.joining(CharSequence).
* @see java.util.stream.Collectors#joining(CharSequence)
 * @see java.util.stream.Collectors#joining(CharSequence, CharSequence, CharSequence)
那我们就顺藤摸瓜,看看 Collectors#joining 有什么跟 StringJoiner 有关联的呢?
public static Collector< CharSequence, ?, String > joining() {
        return new CollectorImpl< CharSequence, StringBuilder, String >(
                StringBuilder::new, StringBuilder::append,
                (r1, r2) - > { r1.append(r2); return r1; },
                StringBuilder::toString, CH_NOID);
    public static Collector< CharSequence, ?, String > joining(CharSequence delimiter) {
        return joining(delimiter, "", "");
    public static Collector< CharSequence, ?, String > joining(CharSequence delimiter,
        return new CollectorImpl<  >(
                () - > new StringJoiner(delimiter, prefix, suffix),
                StringJoiner::add, StringJoiner::merge,
                StringJoiner::toString, CH_NOID);
原来啊,Java 8Stream 是借助了 StringJoiner 来实现的。这个时候,我们可能会想,为什么不使用 StringBuilder 来实现呢?我们可以从上面的代码里看出,如果 使用 StringBuilder 来构造拼接的话,在没有前后缀的情况下,应该还是简单的,事实上JDK 官方组织也选择了 StringBuilder 。但是一旦涉及到拼接之类的操作,那如果还是使用 StringBuilder 的话,那就真的是太复杂了。
所以 StringJoinerJava 8 的地位是 StringBuilder 所不能代替的。
总结
本文介绍了 Java 8 开始提供的字符串拼接类 StringJoinerJDK 8StringJoiner 是通过 StringBuilder 实现的, 所以它的性能和 StringBuilder 差不多,它也是非线程安全的。JDK 11 中已经对其进行了优化,通过 String[] 来代理 StringBuilder
在日常的开发过程中,我们怎么选择字符串拼接类呢?
  1. 简单的字符串拼接,直接使用 + 即可。
  2. 在 for 循环之类的场景下需要字符串拼接,可以优先考虑使用 StringBuilder 。
  3. 在使用 Java Stream 的场景下需要字符串拼接,可以优先考虑使用 StringJoiner。
