Android App环境检测分析
1.检测是否调试APP
这个原理就是APP的AndroidManifest.xml文件中application是否配置了android:debuggable="true",设置true支持动态调试
public static boolean isAppDebuggable(Context context) {
    return (context.getApplicationInfo().flags & 2) != 0;
检测当前APP是否被动态调试中
public static boolean isDebuggerAttached() {
    return Debug.isDebuggerConnected() || Debug.waitingForDebugger();
2.检测是否模拟器
这里获取了Android id,如果Android id是null,就是模拟器?如果包含GOLDFISH字符串也属于模拟器
public static boolean isEmulator(Context context) {
    return Build.PRODUCT.contains(SDK) || Build.HARDWARE.contains(GOLDFISH) || Build.HARDWARE.contains(RANCHU) || Settings.Secure.getString(context.getContentResolver(), "android_id") == null;
3.Root检测
检测系统的tags是不是test-keys。
检测是不是安装了supersu的APP,检测su文件是否存在。
public static boolean isRooted(Context context) {
        boolean isEmulator = isEmulator(context);
        String str = Build.TAGS;
        if ((isEmulator || str == null || !str.contains("test-keys")) && !new File("/system/app/Superuser.apk").exists()) {
            return !isEmulator && new File("/system/xbin/su").exists();
        return true;
判断一些root的APP是否安装
private final boolean a(List list) {
        PackageManager packageManager = this.b.getPackageManager();
        boolean z = false;
        for (String str : list) {
            try {
                packageManager.getPackageInfo(str, 0);
                C0339Io.h.e(str + " ROOT management app detected!");
                z = true;
            } catch (PackageManager.NameNotFoundException unused) {
        return z;
通过which su寻找su文件
public final boolean f() {
            r5 = this;
            r0 = 0
            r1 = 0
            java.lang.Runtime r2 = java.lang.Runtime.getRuntime()     // Catch: java.lang.Throwable -> L2f
            java.lang.String r3 = "which"
            java.lang.String r4 = "su"
            java.lang.String[] r3 = new java.lang.String[]{r3, r4}     // Catch: java.lang.Throwable -> L2f
            java.lang.Process r1 = r2.exec(r3)     // Catch: java.lang.Throwable -> L2f
            java.io.BufferedReader r2 = new java.io.BufferedReader     // Catch: java.lang.Throwable -> L2f
            java.io.InputStreamReader r3 = new java.io.InputStreamReader     // Catch: java.lang.Throwable -> L2f
            java.io.InputStream r4 = r1.getInputStream()     // Catch: java.lang.Throwable -> L2f
            r3.(r4)     // Catch: java.lang.Throwable -> L2f
            java.io.Reader r3 = (java.io.Reader) r3     // Catch: java.lang.Throwable -> L2f
            r2.(r3)     // Catch: java.lang.Throwable -> L2f
            java.lang.String r2 = r2.readLine()     // Catch: java.lang.Throwable -> L2f
            if (r2 == 0) goto L29
            r0 = 1
        L29:
            if (r1 == 0) goto L32
        L2b:
            r1.destroy()
            goto L32
        L2f:
            goto L2b
        L32:
            return r0
        throw new UnsupportedOperationException("Method not decompiled: jmgldvb.C6107cme.f():boolean");
4.分区读写检测
public final boolean k() {
        String str;
        String str2;
        String[] strArr;
        int i;
        boolean z;
        String str3;
        String[] e = e();
        int i2 = 0;
        if (e == null) {
            return false;
        int i3 = Build.VERSION.SDK_INT;
        int length = e.length;
        int i4 = 0;
        boolean z2 = false;
        while (i4 < length) {
            String str4 = e[i4];
            Object[] array = new Regex(StringUtils.SPACE).split(str4, i2).toArray(new String[i2]);
            Intrinsics.checkNotNull(array, "null cannot be cast to non-null type kotlin.Array");
            String[] strArr2 = (String[]) array;
            int i5 = 23;
            if ((i3 > 23 || strArr2.length >= 4) && (i3 <= 23 || strArr2.length >= 6)) {
                boolean z3 = true;
                if (i3 > 23) {
                    str = strArr2[2];
                    str2 = strArr2[5];
                } else {
                    str = strArr2[1];
                    str2 = strArr2[3];
                String[] strArr3 = C4631btu.g;
                int length2 = strArr3.length;
                String str5 = str2;
                int i6 = i2;
                while (i6 < length2) {
                    String str6 = strArr3[i6];
                    if (StringsKt.equals(str, str6, z3)) {
                        if (Build.VERSION.SDK_INT > i5) {
                            str3 = str6;
                            str5 = StringsKt.replace$default(StringsKt.replace$default(str5, "(", "", false, 4, (Object) null), ")", "", false, 4, (Object) null);
                        } else {
                            str3 = str6;
                        strArr = e;
                        Object[] array2 = new Regex(",").split(str5, i2).toArray(new String[i2]);
                        Intrinsics.checkNotNull(array2, "null cannot be cast to non-null type kotlin.Array");
                        String[] strArr4 = (String[]) array2;
                        int length3 = strArr4.length;
                        int i7 = i2;
                        while (true) {
                            if (i7 >= length3) {
                                i = i3;
                                z = true;
                                break;
                            String[] strArr5 = strArr4;
                            i = i3;
                            z = true;
                            if (StringsKt.equals(strArr4[i7], "rw", true)) {
                                C0339Io.b(str3 + " path is mounted with rw permissions! " + str4);
                                z2 = true;
                                break;
                            i7++;
                            strArr4 = strArr5;
                            i3 = i;
                    } else {
                        strArr = e;
                        i = i3;
                        z = z3;
                    i6++;
                    z3 = z;
                    e = strArr;
                    i3 = i;
                    i2 = 0;
                    i5 = 23;
            } else {
                C0339Io.h.e("Error formatting mount line: " + str4);
            i4++;
            e = e;
            i3 = i3;
            i2 = 0;
        return z2;
5.面具检测
通过which命令查找面具可执行文件。
public final boolean m() {
    return a("magisk");
6.APP安装时间检测
通过日志发现每次启动都会检测APP的安装,更新时间。
PackageInfoUtils_generatePackageInfo_1 com.CTION, firstInstallTime: 1701134370160, lastUpdateTime: 1701134626468
7.ROM检测
如果是开发版的ROM,通常tags都是:test-keys
public final boolean q() {
        return str != null && StringsKt.contains$default((CharSequence) str, (CharSequence) "test-keys", false, 2, (Object) null);
8.挂载信息获取
这个mount会把挂载信息返回,可以检测挂载信息中是否有magisk或者zygisk字符串等。
private final String[] e() {
        try {
            InputStream inputStream = Runtime.getRuntime().exec("mount").getInputStream();
            if (inputStream == null) {
                return null;
            String propVal = new Scanner(inputStream).useDelimiter("\A").next();
            Intrinsics.checkNotNullExpressionValue(propVal, "propVal");
            Object[] array = new Regex(StringUtils.LF).split(propVal, 0).toArray(new String[0]);
            return (String[]) array;
        } catch (IOException e) {
            C0339Io.a((Exception) e);
            return null;
        } catch (NoSuchElementException e2) {
            C0339Io.a((Exception) e2);
            return null;
9.读取系统属性
读取了系统的全部属性,应该手机手机型号,厂商等等信息。
private final String[] g() {
        try {
            InputStream inputStream = Runtime.getRuntime().exec("getprop").getInputStream();
                return null;
            return null;
            return null;
判断是不是模拟器:ro.kernel.qemu
获取手机厂商ro.product.manufacturer
品牌:ro.build.product
指纹:ro.build.fingerprint
10.开发者模式adb检测
Settings中获取adb状态。
Settings.Secure
Global getInt : adb_enabled
Secure  getInt : adb_wifi_enabled
11.可疑的二进制文件
这里就是可以传递su,magisk等等参数
public final boolean a(String filename) {
        String[] a;
        Intrinsics.checkNotNullParameter(filename, "filename");
        boolean z = false;
        for (String str : C4631btu.d.a()) {
            String str2 = str + filename;
            if (new File(str, filename).exists()) {
                C0339Io.b(str2 + " binary detected!");
                z = true;
        return z;
12.ro.debuggable检测
ro.debuggable这个系统属性,在user版本的系统中是0,如果发现是1可以判断当前系统是可调试状态和root状态。
public final boolean b() {
        HashMap hashMap = new HashMap();
        hashMap.put("ro.debuggable", "1");
        hashMap.put("ro.secure", "0");
        String[] g = g();
        if (g == null) {
            return false;
        boolean z = false;
        for (String str : g) {
            for (String str2 : hashMap.keySet()) {
                String str3 = str;
                if (StringsKt.contains$default((CharSequence) str3, (CharSequence) str2, false, 2, (Object) null)) {
                    String str4 = "[" + ((String) hashMap.get(str2)) + ']';
                    if (StringsKt.contains$default((CharSequence) str3, (CharSequence) str4, false, 2, (Object) null)) {
                        C0339Io.b(str2 + " = " + str4 + " detected!");
                        z = true;
        return z;
13.无障碍检测
getEnabledAccessibilityServiceList
获取当前无障碍服务的激活的APP信息,这里拿到了激活了无障碍的APP,只有发现有,APP直接崩溃。
private final List getPackageAccessibilityServiceEnabledList(Context context) {
        PackageInfo packageInfo;
        List enabledAccessibilityServiceList = getAccessibilityService(context).getEnabledAccessibilityServiceList(-1);
        Intrinsics.checkNotNullExpressionValue(enabledAccessibilityServiceList, "accessibilityManager.get…ceInfo.FEEDBACK_ALL_MASK)");
        List list = enabledAccessibilityServiceList;
        ArrayList arrayList = new ArrayList(CollectionsKt.collectionSizeOrDefault(list, 10));
        for (AccessibilityServiceInfo accessibilityServiceInfo : list) {
            ServiceInfo serviceInfo = accessibilityServiceInfo.getResolveInfo().serviceInfo;
            try {
                packageInfo = context.getPackageManager().getPackageInfo(serviceInfo.packageName, 0);
                PackageInfo packageInfo2 = new PackageInfo();
                packageInfo2.packageName = serviceInfo.packageName;
                packageInfo2.applicationInfo = serviceInfo.applicationInfo;
                packageInfo = packageInfo2;
            arrayList.add(packageInfo);
        return arrayList;
14.获取APP安装列表
获取了用户安装的所有APP,应该是收集上传,判断是否装了一些root有关的APP。
public List getInstalledApps(PackageManager packageManager) {
        Intrinsics.checkNotNullParameter(packageManager, "packageManager");
        List installedPackages = packageManager.getInstalledPackages(0);
        Intrinsics.checkNotNullExpressionValue(installedPackages, "packageManager.getInstalledPackages(0)");
        return filterNotSystemApp(installedPackages);
‍现在的APP检测环境都挺全
  审核编辑:汤梓红
