Helm部署MinIO集群
添加Helm仓库
[root@node1 ~]
[root@node1 ~]
[root@node1 minio]
"minio" has been added to your repositories
[root@node1 minio]
搜索并下载MinIO Chart
[root@node1 minio]
NAME            CHART VERSION   APP VERSION     DESCRIPTION
bitnami/minio   12.8.6          2023.9.16       MinIO(R) is an object storage server, compatibl...
minio/minio     8.0.10          master          High Performance, Kubernetes Native Object Storage
stable/minio    0.5.5                           Distributed object storage server built for clo...
[root@node1 minio]
[root@node1 minio]
minio-8.0.10.tgz
[root@node1 minio]
[root@node1 minio]
minio  minio-8.0.10.tgz
[root@node1 minio]
查看目录结构
[root@node1 minio]
[root@node1 minio]
Chart.yaml  ci  README.md  templates  values.yaml
创建名称空间
后面将MinIO集群部署到该名称空间下
[root@node1 ~]
namespace/minio created
创建一个Secret
[root@node1 cert]
secret/tls-ssl-minio created
[root@node1 cert]
NAME            TYPE     DATA   AGE
tls-ssl-minio   Opaque   2      10s
修改value.yaml中的一些变量值
nameOverride: ""
fullnameOverride: ""
clusterDomain: cluster.local
image:
  repository: minio/minio
  tag: RELEASE.2021-02-14T04-01-33Z
  pullPolicy: IfNotPresent
mcImage:
  repository: minio/mc
  tag: RELEASE.2021-02-14T04-28-06Z
helmKubectlJqImage:
  repository: bskim45/helm-kubectl-jq
  tag: 3.1.0
mode: distributed
additionalLabels: []
additionalAnnotations: []
extraArgs: []
DeploymentUpdate:
  type: RollingUpdate
  maxUnavailable: 0
  maxSurge: 100%
StatefulSetUpdate:
  updateStrategy: RollingUpdate
priorityClassName: ""
accessKey: "admin"
secretKey: "minio123456"
certsPath: "/etc/minio/certs/"
configPathmc: "/etc/minio/mc/"
mountPath: "/export"
existingSecret: ""
bucketRoot: ""
drivesPerNode: 1
replicas: 4
zones: 1
tls:
  enabled: false
  certSecret: ""
  publicCrt: public.crt
  privateKey: private.key
trustedCertsSecret: ""
persistence:
  enabled: true
  existingClaim: ""
  storageClass: "rook-ceph-block"
  VolumeName: ""
  accessMode: ReadWriteOnce
  subPath: ""
service:
  type: NodePort
  clusterIP: ~
  port: 9000
  nodePort: 32100
  externalIPs: []
  annotations: {}
imagePullSecrets: []
ingress:
  enabled: false
  labels: {}
  annotations: {}
  path: /
  hosts:
    - chart-example.local
  tls: []
nodeSelector: {}
tolerations: []
affinity: {}
securityContext:
  enabled: true
  runAsUser: 1000
  runAsGroup: 1000
  fsGroup: 1000
podAnnotations: {}
podLabels: {}
resources:
  requests:
    memory: 4Gi
defaultBucket:
  enabled: false
  policy: none
  purge: false
buckets: []
makeBucketJob:
  podAnnotations:
  annotations:
  securityContext:
    enabled: false
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
  resources:
    requests:
      memory: 128Mi
updatePrometheusJob:
  podAnnotations:
  annotations:
  securityContext:
    enabled: false
    runAsUser: 1000
    runAsGroup: 1000
    fsGroup: 1000
s3gateway:
  enabled: false
  replicas: 4
  serviceEndpoint: ""
  accessKey: ""
  secretKey: ""
azuregateway:
  enabled: false
  replicas: 4
gcsgateway:
  enabled: false
  replicas: 4
  gcsKeyJson: ""
  projectId: ""
nasgateway:
  enabled: false
  replicas: 4
  pv: ~
environment: {}
networkPolicy:
  enabled: false
  allowExternal: true
podDisruptionBudget:
  enabled: false
  maxUnavailable: 1
serviceAccount:
  create: true
  name:
metrics:
  serviceMonitor:
    enabled: false
    additionalLabels: {}
    relabelConfigs: {}
etcd:
  endpoints: []
  pathPrefix: ""
  corednsPathPrefix: ""
  clientCert: ""
  clientCertKey: ""
使用Helm安装
[root@node1 minio]
[root@node1 minio]
LAST DEPLOYED: Fri Sep 22 13:03:56 2023
NAMESPACE: minio
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
Minio can be accessed via port 9000 on the following DNS name from within your cluster:
minio.minio.svc.cluster.local
To access Minio from localhost, run the below commands:
  1. export POD_NAME=$(kubectl get pods --namespace minio -l "release=minio" -o jsonpath="{.items[0].metadata.name}")
  2. kubectl port-forward $POD_NAME 9000 --namespace minio
Read more about port forwarding here: http://kubernetes.io/docs/user-guide/kubectl/kubectl_port-forward/
You can now access Minio server on http://localhost:9000. Follow the below steps to connect to Minio server with mc client:
  1. Download the Minio mc client - https://docs.minio.io/docs/minio-client-quickstart-guide
  2. Get the ACCESS_KEY=$(kubectl get secret minio -o jsonpath="{.data.accesskey}" | base64 --decode) and the SECRET_KEY=$(kubectl get secret minio -o jsonpath="{.data.secretkey}" | base64 --decode)
  3. mc alias set minio-local http://localhost:9000 "$ACCESS_KEY" "$SECRET_KEY" --api s3v4
  4. mc ls minio-local
Alternately, you can use your browser or the Minio SDK to access the server - https://docs.minio.io/categories/17
查看pod运行情况
[root@node1 ~]
NAME      READY   STATUS    RESTARTS   AGE
minio-0   1/1     Running   0          3m50s
minio-1   1/1     Running   0          3m50s
minio-2   1/1     Running   0          3m50s
minio-3   1/1     Running   0          3m49s
[root@node1 minio]
NAME             STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS      AGE
export-minio-0   Bound    pvc-a70a5caa-2bad-40ab-bf19-dbbfccd3d151   10Gi       RWO            rook-ceph-block   28s
export-minio-1   Bound    pvc-c3c1a8c5-d429-47e4-acf6-a57da3bacd5a   10Gi       RWO            rook-ceph-block   28s
export-minio-2   Bound    pvc-15ed67b3-7ea0-4f06-ba46-93137480066c   10Gi       RWO            rook-ceph-block   28s
export-minio-3   Bound    pvc-a58ceb7f-dac0-4ee7-9a34-473c8f336d28   10Gi       RWO            rook-ceph-block   2
8s
查看Service地址
[root@node1 ~]
NAME        TYPE        CLUSTER-IP   EXTERNAL-IP   PORT(S)          AGE
minio       NodePort    10.98.63.2           9000:32100/TCP   8m25s
minio-svc   ClusterIP   None                 9000/TCP         8m25s
登陆网页端上传文件验证
文件
命令行方式访问测试
curl https://dl.min.io/client/mc/release/linux-amd64/mc
  --create-dirs
  -o $HOME/minio-binaries/mc
chmod +x $HOME/minio-binaries/mc
export PATH=$PATH:$HOME/minio-binaries/
[root@node1 minio]
NAME:
  mc - MinIO Client for object storage and filesystems.
USAGE:
  mc [FLAGS] COMMAND [COMMAND FLAGS | -h] [ARGUMENTS...]
COMMANDS:
  alias      manage server credentials in configuration file
  ls         list buckets and objects
  mb         make a bucket
  rb         remove a bucket
  cp         copy objects
  mv         move objects
  rm         remove object(s)
  mirror     synchronize object(s) to a remote site
  cat        display object contents
  head       display first 'n' lines of an object
  pipe       stream STDIN to an object
  find       search for objects
  sql        run sql queries on objects
  stat       show object metadata
  tree       list buckets and objects in a tree format
  du         summarize disk usage recursively
  retention  set retention for object(s)
  legalhold  manage legal hold for object(s)
  support    support related commands
  license    license related commands
  share      generate URL for temporary access to an object
  version    manage bucket versioning
  ilm        manage bucket lifecycle
  quota      manage bucket quota
  encrypt    manage bucket encryption config
  event      manage object notifications
访问MinIO中存储的文件
[root@node1 minio]
[root@node1 minio]
admin
[root@node1 minio]
[root@node1 minio]
minio123456
[root@node1 minio]
Added `my-minio` successfully.
[root@node1 minio]
[2023-09-22 1956 CST]     0B books/
[root@node1 minio]
遇到的问题
问题一
[root@node1 minio]
Error: INSTALLATION FAILED: create: failed to create: Secret "sh.helm.release.v1.minio.v1" is invalid: data: Too long: must have at most 1048576 bytes
由于我在minio chart的解压目录新创建了一个cert文件夹,并生成了一些证书文件,导致了该错误的产生
解决办法:删除除了minio Chart 包中以外的文件包括文件夹,重新执行安装。
  审核编辑:汤梓红
