内核中的psci架构cpu_ops接口
cpu_ops接口
驱动初始化完成后,cpu的cpu_ops就可以调用这些回调实现psci功能的调用。如下所示,当devicetree中cpu的enable-method设置为psci时,该cpu的cpu_ops将指向cpu_psci_ops。
cpu0: cpu@0 {
	enable-method = "psci";
其中cpu_psci_ops的定义如下:
const struct cpu_operations cpu_psci_ops = {
	.name		= "psci",
	.cpu_init	= cpu_psci_cpu_init,
	.cpu_prepare	= cpu_psci_cpu_prepare,
	.cpu_boot	= cpu_psci_cpu_boot,
#ifdef CONFIG_HOTPLUG_CPU
	.cpu_can_disable = cpu_psci_cpu_can_disable,
	.cpu_disable	= cpu_psci_cpu_disable,
	.cpu_die	= cpu_psci_cpu_die,
	.cpu_kill	= cpu_psci_cpu_kill,
#endif
如启动cpu的接口为cpu_psci_cpu_boot,它会通过以下流程最终调用psci驱动中的psci_ops函数:
static int cpu_psci_cpu_boot(unsigned int cpu)
	phys_addr_t pa_secondary_entry = __pa_symbol(function_nocfi(secondary_entry));
	int err = psci_ops.cpu_on(cpu_logical_map(cpu), pa_secondary_entry);
	if (err)
		pr_err("failed to boot CPU%d (%d)n", cpu, err);
	return err;
