【JAVA UI】【HarmonyOS】【Demo】 鸿蒙如何进行 xml 解析
1.2w人已加入
【鸿蒙】鸿蒙如何进行数据解析
【问题描述】有时候我们从服务器获取是 xml 格式数据,我们需要将 xml 转化成 model 对象,该如何使用呢?下面举个例子说明一下,将分以下几步进行
1.准备条件 创建xml文件,创建model对象,构建界面
2.数据进行解析操作(重点)
3.运行效果
第一步准备条件 创建 xml 文件,创建 model 对象,构建界面
1.1 在 rawfile 新建 xml 文件,代码如下
< ?xml version="1.0" encoding="utf-8"? >
< note >
    < to >George< /to >
    < from >John< /from >
    < heading >Reminder< /heading >
Don't forget the meeting!< /body > < /note > HarmonyOS
1.2 新建 class model 代码如下
package com.harmony.alliance.mydemo.model;
public class note {
    private  String from;
    private  String heading;
    private String body;
    private  String to;
    public String getFrom() {
        return from;
    public void setFrom(String from) {
        this.from = from;
    public String getBody() {
        return body;
    public void setBody(String body) {
        this.body = body;
    public String getTo() {
        return to;
    public void setTo(String to) {
        this.to = to;
    public String getHeading() {
        return heading;
    public void setHeading(String heading) {
        this.heading = heading;
    @Override
    public String toString() {
        return "note{" +
                "from='" + from + ''' +
                ", heading='" + heading + ''' +
                ", body='" + body + ''' +
                ", to='" + to + ''' +
1.3 新建数据的 abilityslice,xml 如下
< DirectionalLayout
    xmlns:ohos="http://schemas.huawei.com/res/ohos"
    ohos:height="match_parent"
    ohos:width="match_parent"
    ohos:orientation="vertical" >
    < Text
        ohos:id="$+id:mStartParse"
        ohos:height="100vp"
        ohos:text="开始解析"
        ohos:text_size="20fp"
        ohos:text_color="#ffffff"
        ohos:text_alignment="center"
        ohos:background_element="#ed6262"/ >
    < Text
        ohos:id="$+id:mTo"
        ohos:height="100fp"
        ohos:text_color="#ed6262"
        ohos:background_element="#ffffff"/ >
    < Text
        ohos:id="$+id:mfrom"
        ohos:height="100fp"
    < Text
        ohos:id="$+id:mheading"
        ohos:height="100fp"
    < Text
        ohos:id="$+id:mbody"
        ohos:height="100fp"
< /DirectionalLayout >
界面效果如下
HarmonyOS
第二步数据解析 2.1 参考资料如下
SAXParser
https://developer.harmonyos.com/cn/docs/documentation/doc-references/saxparser-0000001060039145
XMLReader https://developer.harmonyos.com/cn/docs/documentation/doc-references/xmlreader-0000001060837300
在上述四个接口中,最重要的就是 ContentHandler 这个接口,下面是对这个接口方法的说明:
// 设置一个可以定位文档内容事件发生位置的定位器对象
public void setDocumentLocator(Locator locator)
// 用于处理文档解析开始事件
public void startDocument()throws SAXException
// 处理元素开始事件,从参数中可以获得元素所在名称空间的 uri,元素名称,属性类表等信息
public void startElement(String namespacesURI , String localName , String qName , Attributes atts) throws SAXException
// 处理元素结束事件,从参数中可以获得元素所在名称空间的 uri,元素名称等信息
public void endElement(String namespacesURI , String localName , String qName) throws SAXException
// 处理元素的字符内容,从参数中可以获得内容
public void characters(char[] ch , int start , int length) throws SAXException
新建 SaxHelper 代码如下
import ohos.org.xml.sax.Attributes;
import ohos.org.xml.sax.SAXException;
import ohos.org.xml.sax.helpers.DefaultHandler;
 * Created by Jay on 2015/9/8 0008.
public class SaxHelper extends DefaultHandler {
    //当前解析的元素标签
    private String tagName = null;
    private  note mNote;
     * 当读取到文档开始标志是触发,通常在这里完成一些初始化操作
    @Override
    public void startDocument() throws SAXException {
        mNote=new note();
     * 读到一个开始标签时调用,第二个参数为标签名,最后一个参数为属性数组
    @Override
    public void startElement(String uri, String localName, String qName, Attributes attributes) throws SAXException {
        System.err.println("####=== >>"+localName);
        this.tagName = localName;
     * 读到到内容,第一个参数为字符串内容,后面依次为起始位置与长度
    @Override
    public void characters(char[] ch, int start, int length) throws SAXException {
        //判断当前标签是否有效
        if (this.tagName != null) {
            String data = new String(ch, start, length);
            //读取标签中的内容
            if (this.tagName.equals("to")) {
                mNote.setTo(data);
            } else if (this.tagName.equals("from")) {
                mNote.setFrom(data);
            }else  if(this.tagName.equals("heading")){
                mNote.setHeading(data);
            }else  if(this.tagName.equals("body")){
                mNote.setBody(data);
     * 处理元素结束时触发,这里将对象添加到结合中
    @Override
    public void endElement(String uri, String localName, String qName) throws SAXException {
        this.tagName = null;
     * 读取到文档结尾时触发,
    @Override
    public void endDocument() throws SAXException {
        super.endDocument();
        System.err.println("#####=== >>"+mNote.toString());
//        Log.i("SAX", "读取到文档尾,xml解析结束");
    public note getmNote() {
        return mNote;
AbilitySlice 代码如下
package com.harmony.alliance.mydemo.slice;
import com.harmony.alliance.mydemo.ResourceTable;
import com.harmony.alliance.mydemo.model.SaxHelper;
import com.harmony.alliance.mydemo.model.note;
import ohos.aafwk.ability.AbilitySlice;
import ohos.aafwk.content.Intent;
import ohos.agp.components.Component;
import ohos.agp.components.Text;
import ohos.javax.xml.parsers.SAXParser;
import ohos.javax.xml.parsers.SAXParserFactory;
import ohos.org.xml.sax.InputSource;
import ohos.org.xml.sax.XMLReader;
import java.io.InputStream;
import java.util.Locale;
public class myXmlParseAbilitySlice extends AbilitySlice {
    private Text mStartParse,mTo,mfrom,mheading,mbody;
    @Override
    protected void onStart(Intent intent) {
        super.onStart(intent);
        setUIContent(ResourceTable.Layout_my_xml_parse);
        mStartParse= (Text) findComponentById(ResourceTable.Id_mStartParse);
        mTo= (Text) findComponentById(ResourceTable.Id_mTo);
        mfrom= (Text) findComponentById(ResourceTable.Id_mfrom);
        mheading= (Text) findComponentById(ResourceTable.Id_mheading);
        mbody= (Text) findComponentById(ResourceTable.Id_mbody);
        mStartParse.setClickedListener(new Component.ClickedListener() {
            @Override
            public void onClick(Component component) {
                try {
                    String rawFilePath = "note.xml";
                    String filePath = String.format(Locale.ROOT, "assets/entry/resources/rawfile/%s", rawFilePath);
                    InputStream     is = this.getClass().getClassLoader().getResourceAsStream(filePath);
                    InputSource is2=new InputSource(is);
                    SaxHelper ss = new SaxHelper();
                    SAXParserFactory factory = SAXParserFactory.newInstance();
                    factory.setNamespaceAware(true);
                    SAXParser parser = factory.newSAXParser();
                    XMLReader xmlReader=parser.getXMLReader();
                    xmlReader.setContentHandler(ss);
                    xmlReader.parse(is2);
                    note mNote= ss.getmNote();
                    mTo.setText("to: "+mNote.getTo());
                    mfrom.setText("From:  "+mNote.getFrom());
                    mheading.setText("heading:  "+mNote.getHeading());
                    mbody.setText("body:  "+mNote.getBody());
                    is.close();
                }catch (Exception e){
                    e.printStackTrace();
HarmonyOS
