鸿蒙NEXT实战开发:【截屏】
1.2w人已加入
展示全屏截图和屏幕局部截图。通过[screenshot]模块实现屏幕截图 ,通过[window]模块实现隐私窗口切换,通过[display]模块查询当前隐私窗口。
效果预览
鸿蒙
使用说明:
  1. 点击右上角图标打开弹窗,选择截屏,展示全屏截图;选择局部截屏,选择截屏区域,点击右下角完成,展示局部截屏;
  2. 点击滑块切换窗口隐私模式,隐私模式下截屏会弹出提示,拒绝截屏。
具体实现
本示例通过screenshot接口实现屏幕截图 ,通过window接口实现隐私窗口切换,通过display接口查询当前隐私窗口。
  • 源码链接:[Screenshot.ets]
 * Copyright (c) 2022 Huawei Device Co., Ltd.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
import screenshot from '@ohos.screenshot'
import { Logger } from './Logger'
import { getCurrentWindow } from './WindowPrivacy'
// 屏幕截图 默认参数screenshotOptions为空时 截全屏
export function getScreenshot(screenshotOption = {}) {
  return screenshot.save(screenshotOption)
// 设置全屏展示 isFullScreen: boolean
export function setFullScreen(context: Context, isFullScreen: boolean) {
  getCurrentWindow(context)
    .then(res = > {
      res.setFullScreen(isFullScreen, (err) = > {
        if (err.code) {
          Logger.error('failed set full-screen mode cause: ' + JSON.stringify(err))
          return
        Logger.info('success set full-screen mode')
  • [WindowPrivacy.ets]
import window from '@ohos.window'
import display from '@ohos.display'
import { ResponseData } from '../models/ResponseData'
// 获取当前窗口
export function getCurrentWindow(context: Context) {
  return window.getTopWindow(context)
// 判断隐私窗口
export function hasPrivate(): ResponseData {
  let currentDisplay = null
  try {
    currentDisplay = display.getDefaultDisplaySync()
  } catch (exception) {
    return { status: 'failed', errorMessage: JSON.stringify(exception) }
  if (currentDisplay === null) {
    return { status: 'failed', errorMessage: 'get current display failed' }
  let ret = undefined
  try {
    ret = display.hasPrivateWindow(currentDisplay.id)
  if (ret === undefined) {
    return { status: 'failed', errorMessage: 'ret is undefined' }
  return ret ? { status: 'success', errorMessage: '', result: true } :
    { status: 'success', errorMessage: '', result: false }
// 设置隐私窗口
export function setWindowPrivacyMode(context: Context, windowPrivacyMode: boolean) {
  let currentWindow = null
    .then(res = > {
      currentWindow = res
      try {
        currentWindow.setWindowPrivacyMode(windowPrivacyMode, (err) = > {
          if (err.code) {
            Logger.error('set window privacy mode failed cause: ' + JSON.stringify(err))
            return
          Logger.info(`set window privacy mode success ${windowPrivacyMode}`)
        Logger.info('set window mode failed cause: ' + JSON.stringify(exception))
鸿蒙
